Does the dc power jack have 2 be soldered back on when being replaced or does it just plug back in 2 motherboard .thank you
  • 69 Answers
Depends on the board,,but yes most times it must be soldered,,,and most times it has a 50/50 success rate
Posted on Jul 11, 2010
Compaq CQ1-1225 AIO Wont Start at all. Removed all components
Suggestions;
Anti-Static wrist strap connected to ground source, and your wrist;
1) The jack your AC adapter plugs into on the motherboard, is the DC Power Jack.
Motherboard out of case, power to motherboard, take your multimeter and see if you are getting 19 VDC at the DC Power Jack's positive solder joint, on motherboard.
The center pin of the jack is Positive. (The inner cylindrical shell is Negative)
Follow the DC Power Jack's positive pin from the Center of the jack, to the motherboard.
You probably won't be able to touch your meter's Positive (Red) probe, to the DC Power Jack's positive pin under the jack; so touch it's solder joint on the opposite side of the motherboard.
(DC Power Jack should be soldered close to the motherboard, is why)
Of course also touch the Negative lead, (Black probe), of your meter, to the Negative, (Ground) solder joint for the DC Power Jack.
Getting 19 volts DC?
See if there is a cracked solder joint, for any of the DC Power Jack's pin connections to the motherboard.
ANY perceptible movement of the DC Power Jack on the motherboard, indicates a bad power jack, and may indicate a broken/cracked solder joint.
Center pin of DC Power Jack is loose? Bad DC Power Jack. Replace.
2) DC Power Jack is determined to be in good repair? No cracked/broken solder joints?
The next components in the power circuit on the motherboard, leading From the power jack, are P. MOSFET's.
Power MOSFET.
Power MOSFET Wikipedia the free encyclopedia
More information using a prior solution,
Dv6000 power light does not come on any more
Check the links given.
3) The last thing that concerns me, although I probably should have listed it first; is the AC adapter you are using.
Concern is that it doesn't have the 'intelligent chipset' that matches the Compaq CQ1-1225 All-In-One desktop PC's circuitry.
AC Adapter For Compaq Presario All in One CQ1 1225 Desktop PC Charger...
Just my thoughts..........
Regards,
joecoolvette
Jan 15, 2015 | HP Computers & Internet
Amilio laptop not charging in spite of new charger
please measure the output for your charger,normally they have 19.5 vdc exactly, if they do not measure the adapter is faulty, repair or replace.If the output is o.k the battery can be faulty. Use the software diagnostic coming with the computer, restart the computer HOLD the key f2 or esc depending of your computer model, and make the diagnostic.try again and see what is the result, if the battery is o.k or faulty.God bless you
Apr 05, 2013 | Fujitsu Computers & Internet
Charging light wont come on
A) AC adapter (Charger) is bad.
Use a multimeter, and check it out.
[ DC Voltage.
Test plug of cable that plugs into laptop.
Positive (Red) probe lead of multimeter, to Center Hole of plug on AC adapter.
Negative (Black) probe lead touches outside cylindrical metal shell.
You should read close to 19.5 Volts (DC) ]
AC adapter checks out OK?
B) DC Power Jack is bad
[The DC Power Jack is the port on the laptop, that the AC adapter plugs into. On laptop may be marked DC_IN ]
Damage to DC Power Jack prevents laptop from charging, or running strictly off of the AC adapter.
Battery removed take a No.2 pencil's eraser, and see if you can gently move the Center Pin, of the DC Power Jack.
ANY perceptible movement means replacement of the DC Power Jack.
The pin itself may not move, and the entire jack moves.
The good news is the DC Power Jack is not soldered to the motherboard.
It is soldered to a separate, therefore replaceable, small circuit board,
http://www.parts-people.com/index.php?action=item&id=3698
Click to enlarge. In the photo the DC Power Jack is at the back on the right.
This is is what the DC Power Jack, looks like not installed on that small circuit board,
http://www.elept.com/dc-power-jack-for-dell-inspiron-xps-m140-m1710-m1210-m2010_p2971.html
Looking at the view on the right, note the pins sticking out.
You are looking at the back view, and the jack is laying on it's side.
The pins go through the laptop's motherboard, and are soldered to the motherboard.
Where the pins are soldered to the motherboard is a solder connection. Commonly referred to as a Solder Joint.
Plugging in, and missing the hole of the jack, can cause the AC adapter plug to damage the DC Power Jack, by bumping into it.
Bumping into the plug of the AC adapter, while plugged into the DC Power jack, can cause damage to the jack.
Can cause cracking of the above mentioned solder joints. This leads to an intermittent contact, and eventually no contact, of the DC Power Jack TO the motherboard.
In this case the solder joints are just re-soldered.
Damage to the body of the jack itself means replacement of the DC Power Jack, or replacement of the USB/DC Power Jack circuit board, itself.
(Unless you, or an acquaintance can un-solder, and solder real well, the option may be to just replace the USB/DC Power Jack circuit board)
DC Power Jack proves to be OK?
Problem is one, or more Power MOSFETs on the motherboard.
These determine if the Battery needs a trickle charge, or a full charge, or no charge at all.
Also determines if the laptop is to just run off of the AC adapter, and not the Battery.
This example is for HP Pavilion dv6000 and Pavilion dv9000 series of Notebook PC's. You can use it for cross-reference information.
(Location of the Power MOSFETs on your laptop's motherboard. General idea of what they look like ),
http://mayohardware.blogspot.com/2010/04/important-parts-on-dv6000-and-dv9000.html
What? Looks like motherboard replacement to you?
OK
Let's price a Fairchild Semiconductor International - FDS6679 - Power MOSFET,
http://www.mouser.com/Search/Refine.aspx?Keyword=FDS6679
If you buy one the cost is $1.01 USD
Look to see if the Power MOSFET/s are burned. Blackened, bubbled, or blistered.
There is one more small component, that if bad will produce the same results;
Ceramic Capacitors.
Look back at the Mayohardware blog. Look at the second photo down with the AO4407 Power MOSFET circled in Yellow.
Note the small rectangular shape to the immediate right, that has the wide dark band on it. There is one above it, one above that, and one to the right of the top one.
See if any of these, (No matter what the size. Look at all of them), are burned. Blackened, bubbled, or blistered.
http://www.mouser.com/Passive-Components/Capacitors/Ceramic-Capacitors/Multilayer-Ceramic-Capacitors-MLCC-SMD-SMT/_/N-b2cj?P=1z0wquyZ1z0t6fg
NOT stating these are ones to use. Just showing average cost.
.42 to .76 cents USD. Approximately a half dollar to three-quarters of a dollar.
Motherboard?
Average example,
http://www.amazon.com/Dell-Inspiron-M140-Motherboard-HC425/dp/B001155N0U
$200 USD
Average example of the -> package type of the Power MOSFETs used,
https://docs.google.com/viewer?a=v&q=cache:oER5NNz8cwcJ:www.fairchildsemi.com/ds/FD/FDS6675BZ.pdf+Fairchild+FDS6675BZ&hl=en&pid=bl&srcid=ADGEEShOhWPjm_M-ROHme4iEMrztCTOd-28jNiy1hVLQQh_VOyv8zcXEVDB_iTQA6MuZO88UmRkDgjyW9j4CP2aIJ-4DS-h6JNM3lvxldeApQeecmz_DADCw1s7tmNLxfPknqX14SZP6&sig=AHIEtbS_rYUAeo_8rB9YHkW05ZjLqeH4Jg
http://www.youtube.com/watch?v=5uiroWBkdFY&feature=fvwrel
You don't need a Soldering Station. A low Wattage soldering iron, and that tip.
http://support.dell.com/support/edocs/systems/xps140M/en/sm/index.htm
Regards,
joecoolvette
Oct 08, 2012 | Dell Inspiron XPS M140 Notebook
Hey, I have a samsung R60 Plus laptop for a few years now, and its out of warrently and the DC jack power socket has just stopped working. I ordered in a new DC jack for the power socket and soldered out...
When the short happened it caused a feedback in the power supply charger, I would sub out the power supply with a replacement as a first important step to see if the laptop will come back online.
May 21, 2012 | Samsung Computers & Internet
Hello, power failur on mother board p/n cp298380-01
So how is the DC Power Jack solder joints on that Fujitsu Lifebook?
The DC Power Jack (DC IN) is the jack on the laptop where the AC adapter (Charger) plugs into.
Do any of them look oxidized?
Dull finish on any of the solder joints holding the DC Power Jack to the motherboard.
De-solder and makes fresh solder joints.
Are any of the solder joints cracked?
Cracked at the area of the solder joints to the bottom of the motherboard.
Re-solder.
What condition is the DC Power Jack itself?
Physical condition of the jack.
Bad physical condition requires replacing.
Do you see any discoloration, or burn spots on the chips on the motherboard?
(I.C., Integrated Circuit = Chip and Chipset)
There is a sensor chip on the motherboard for power. Senses when the battery needs to be charged, or doesn't, and when the laptop is to just use the AC adapter power.
If so replace the motherboard.
Post any questions about the above in a Comment.
(Believe upper right of your page > Comment)
Regards,
joecoolvette
Dec 02, 2010 | Computers & Internet
Hello my laptop t41 power is not even flash but the adapter is working,am technician and i have troubleshoot allot.
I concur with what Diegotech stated.
To iterate further;
1) The DC Power Jack (DC IN), may have cracked solder joint/s on the motherboard connector, (Female), where the DC Power Jack plugs in.
Resolder
2) The DC Power Jack may be broken.
Center Pin mount, and/or body of DC Power Jack, and/or Outer Shell mount.
Replace DC Power Jack.
3) Wires from the DC Power jack plug to the female connector on the motherboard, may be bad.
Two examples, of a place to buy an IBM ThinkPad T41 DC Power Jack,
1) http://www.buy.com/prod/dc-power-jack-connector-socket-for-ibm-thinkpad-t40-t41-t42-r50-r51-r52/q/sellerid/23962916/loc/101/215782035.html
2) http://www.machinaelectronics.com/store/buypart/IBM_Thinkpad_T41/DC-P001
Past this point it's a bad DC sensor on the motherboard.
Replace motherboard.
IBM ThinkPad T41 Service Manual, (Free),
http://www.tim.id.au/blog/tims-laptop-service-manuals/#toc-ibmlenovo
On this page go down to the 8th line.
The one that starts with > ThinkPad T20.
Go across, and click on > T41
Takes approximately 2 seconds to see the first page, and additional time to fully download.
Page 142 for 14.1 inch LCD screen
Page 151 for 15 inch LCD screen
(PDF file page number box at top)
Dec 01, 2010 | IBM ThinkPad T41 Notebook
Laptop won't power on with ac adapter or battery
Could be a combination of things.
1) Battery is low. Not enough power to turn the laptop on.
Caused by;
2) AC adapter has a plug on the end of the cable. The plug plugs into a DC Power Jack on the laptop.
The DC Power Jack is bad.
2a) The DC Power Jack has a bad connection to the motherboard, (Cracked solder joints), and/or the jack itself is bad.
2b) Center Pin is loose in the jack's mount.
The back of the Center Pin where it mounts has become loose.
2c) The plastic body of the jack, which composes the jack's case, is cracked. This allows movement of the Center Pin.
2b, and 2c cause a bad connection with the AC adapter plug.
No charge to the Battery, no power to the laptop.
http://www.laptopjacks.com/view_part/For-Gateway-MX6920-DC-Power-Jack-GW51425.html
[ If this is the case the DC Power Jack needs to be resoldered to the motherboard. The cracked solder joints need to be re-melted, (Reflowed)
Entire laptop needs to be disassembled down to the bare motherboard in your hand.
(No Processor, Ram Memory, or any adapter cards mounted to the motherboard. Nada)
OR,
The DC Power jack needs to be replaced.
This entails disassembling the entire laptop, down to just the motherboard in your hand. (Same as above)
The old DC Power Jack is de-soldered, and a new one soldered in place.
Very FEW computer repair shops have the necessary skill level.
They just want to replace the entire motherboard.
IF one is available.
More Ka-Ching for them also. ]
3) The AC adapter is bad.
Not providing power to the laptop, to charge the Battery, nor give power to the laptop without the Battery.
AC adapter cord from adapter to plug, which plugs into the laptop, (DC Power Jack), may have a break in it.
May be an intermittent contact provided by wiggling the cord.
If this is the case the wires have stretched, and broken.
Wiggling causes the wires to briefly touch, and make contact.
Where this cord meets the plug itself. A lot of times there is a break in the wires in this area.
Solution is to replace the AC adapter. There are universal AC adapters you can buy, or perhaps Gateway still has some for sale.
(Ka-Ching)
Oct 21, 2010 | Gateway MX6920 Notebook
MY GATEWAY LAPTOP NO LONGER RECEIVES POWER.
Motherboard or harddrive? I'm betting it's more towards the motherboard. The DC Power Jack to be more specific. This is the port where the AC adapter, (Charger), plug is plugged into.
The DC Power Jack is not much bigger, than the plug for the AC adapter that plugs into it. There are small pin leads that are on the bottom of this jack, and they go through the motherboard, and are soldered to the motherboard.
Accidental bumping of the AC adapter plug, while plugged into the DC Power Jack, can damage the jack. It can break the connections for the adapter plug, and/or can crack the solder joints for those small pin leads.
[Laptops use DC electricity. A flashlight battery, and a laptop battery, are examples of stored DC electricity. DC electricity has two poles. Positive and Negative. The DC Power Jack has two connections. Positive and Negative. {Even if the DC Power Jack has multiple holes in it]
There is also another known problem associated with DC Power Jacks. It may stem from a bad motherboard design.
More to the point, the area where the DC Power Jack mounts on the motherboard. In this design, the DC Power Jack motherboard area, is almost a separate part of the motherboard. It's shaped like a Peninsula. (Think of an island, with one side connected to the mainland)
This peninsula shape, has the tendency to crack away from the main body of the motherboard. Circuit traces are broken.
When the AC adapter plug is setting in a certain position, it presses the two broken halves of the circuit traces together, for a momentary contact. As the AC adapter plug is moved from this position, the circuit trace halves are moved apart, and there is no contact.
(No distribution of electricity from one circuit trace half, to the other circuit trace half. Think of a circuit trace as a very, thin, flat copper wire. When a circuit trace is broken, there is essentially a wire that is broken into two parts)
Solution?
See if the DC Power Jack can be repaired, (Solder joint connections re-soldered), or replaced.
If the DC Power Jack motherboard area is the aforementioned peninsula shape, it may require replacement of the motherboard.
There are very FEW, computer repair shops that have the technical expertise to replace a DC Power Jack. Easy fix is to simply replace the motherboard. (More $$$$$ too)
However, some laptops DO require replacement of the motherboard for this repair.
Bad motherboard design, for the DC Power Jack area on the motherboard.
Re-solder DC Power Jack solder joints? (IF, this is the problem) Average is $50 to $75 (US)
Replace DC Power Jack? Average is $125 to $150. (US)
Replace motherboard? Depends on the Gateway model. Could be $225 to $400 (US)
[Yes, most of the time the cost warrants just replacing the laptop itself, as the cost of replacing, is close to the repair cost)
Just to SHOW you ab average DC Power Jack, and the repair involved of replacing. (Doesn't show you, that the entire laptop needs to be disassembled, down to the bare motherboard in hand)
This is NOT a recommendation to replace the DC Power Jack yourself! It is just for knowledge of what is partially involved. (You can accidentally burn the motherboard when desoldering, or soldering, rendering the motherboard useless)
http://www.laptoprepair101.com/laptop/2007/12/06/dc-power-jack-repair-guide/
Sep 09, 2009 | Computers & Internet
Toshiba plug-in ac adapter LCDlight flashing and wont boot up
It may be that you need a new, (Or good condition used), motherboard. You may not.
The problem could be the DC Power Jack. The DC Power Jack is small, and the body is made of plastic. Sometimes there is a metal shell around the plastic body. (The jack is a rectangular shape, and is just a little larger, than the outside portion of that AC adapter plug!)
This is an example of a DC Power jack for a Toshiba Satellite a215-s5807,
http://www.notebookworks.net/ProductDetails.asp?ProductCode=NBW52-0133
As you know there is a metal pin in the center, and at the back of the round hole, there are flat metal contacts.
Let me explain the construction of a DC Power Jack, and how it's mounted to a motherboard. This all has relevance to the solution.
Your laptop uses DC electricity. (The AC adapter converts AC to DC. Your laptop battery, and a flashlight battery, are examples of stored DC electricity)
DC uses a Positive connection, and a Negative connection. The metal pin in the center is Positive. The flat metal strips at the back are Negative.
That laptop DC Power Jack has metal prongs, that come out of the plastic body. One prong, (Or pin), connects to the Positive metal round pin, in the center of the jack.
There may be one, or two prongs, (Or pins), that come out of the plastic body, and connect to the Negative side of the jack. (Flat metal strips)
These prongs go down through holes in the motherboard, and are soldered on.
With the AC adapter plugged in, an accidental bump on the plug itself, could break the body of the jack, or break solder joints that hold the jack to the motherboard.
AC adapter removed, and battery removed. Use a NON-metallic object, and see if you can make the center pin of the jack move. See if the entire jack itself seems to move.
A.If the center pin moves, you have a broken DC Power Jack.
B.If the entire jack moves, you have cracked solder joints. (Broken)
Replacement of the DC Power Jack for A.
Re-solder the solder joint/s for B.
Cost of replacing a jack at a reputable computer repair shop? $90 to $150
Cost of re-soldering solder joints? $50 to $90
Cost of replacing the motherboard?
$250 on up.
If you are a skilled person with the correct tools, it is feasible for you to replace the jack, or re-solder the solder joints.
It is also feasible that you yourself, could replace the motherboard.
Some laptops have a poor motherboard design, for where the DC Power Jack is mounted to the motherboard.
Crude explanation would be, that the main body of the motherboard is a 1 foot square. Then a 2 inch square comes out of the side of the main body.
The DC Power Jack is mounted to that 2 inch square. From accidental bumping, OR just normal usage of inserting, and removing the AC adapter plug, this 2 inch square can crack away from the main body.
This, of course would require a motherboard replacement.
Disassembly instructions for a Satellite A200 and A205 Series laptops. Very close to the A215 Series,
http://www.irisvista.com/tech/laptops/toshiba-satellite-a205/laptop-disassembly-1.htm
(Don't forget to buy, and use a cheap ESD wrist strap, to prevent static shock to the delicate hardware components, inside your laptop. Average cost is $7)
Aug 04, 2009 | Computers & Internet
Acer 5920g no power
Your DC Power Jack is bad, or the area of the motherboard where the DC power jack attaches to, is bad.
The DC Power Jack, is the small port where your AC adapter,(Charger), plugs into.
This is an example of an average DC Power Jack, for an HP Pavilion laptop, not installed in a laptop yet,
http://www.megaemarket.com/dc-power-jack-hp-pavilion-ze4200-zt117420011721182125.html
If you click on the photo it will enlarge.
The DC Power Jack in the photo is upside down, in relation to how it sits on your laptop's motherboard.
Those flat metal pins shown on top, go down through the motherboard, and are soldered on the other side.
1.Sometimes when the 'charger' plug is in the jack, and is bumped, it can crack the solder joints for the DC Power Jack's flat pins. This makes an intermittent contact. Eventually there is no contact at all.
2.Sometimes it's a bad design of the DC jack, and just from ordinary usage of the user plugging in the charger, and removing it, this can crack the solder joints.
3.Sometimes the small area of the motherboard where the DC power jack is mounted, can crack away from the main body of the motherboard.
To explain:
Crude example;
Envision a laptop's motherboard as having a 1 foot square shape. (It isn't. It's irregular shaped) Now on one side attach a 2 inch square. This 2 inch square, represents the area that the DC power jack is attached to. A 'Peninsula', if you will. There are circuit traces that go along a motherboard. Think of them as Very, flat, thin, strips of copper wire. These 'wires' become stretched, and break as the 'peninsula' cracks away from the main body of the motherboard.
Solution?
Have the DC Power Jack replaced, or the motherboard.
DC Power Jack cost? About $6 to $8 dollars.
Labor? $100 to $150.
The tech has to completely disassemble the laptop, to just the bare motherboard in hand. Then unsolder the DC power jack, resolder a new one in, and reassemble the laptop.
Motherboard cost? About $150 on up. Depends on where you obtain it. (Ebay?)
Labor? $100 to $200.
Jul 12, 2009 | Acer Computers & Internet
Computers & Internet Logo
29 people viewed this question
Alun Cox
David Payne
David Payne
