Question about Sony Handycam DCR-TRV19 Mini DV Digital Camcorder
I have a handycam DCR-HC39E which shows no image in viewscreen or through view finder. Was working fine when last used. Can hear that it turns on and can select tape/memory/play function but nil visible. Yes, lens cover is open.
  • beetle77 Jul 11, 2010
    Since it was working well before, I'm not keen to have to buy replacement parts just yet. Any other ideas? no joy from tapping around the lens
  • 10,515 Answers
This is a common problem with most of the Sony handycams. These symptoms are highly suggestive of bad image sensor. One thing needs to be checked that your iris is not set to manual and is closed. Since the viewfinder takes the image from the sensor, i am almost certain that image sensor is at fault. You need to contact Sony,if they are repairing it for free ( recalls were there for few models ) or at discounted price or you need to pay the complete repair amount or upgrade it.
Let me know,if needed further assistance.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
Posted on Jul 11, 2010
    President:
  • 1,197 Answers
Before deciding whether it is required to open the unit and check out for any faulty parts.... usually the Ribbon cables or CCD image sensor (if there is no play back only while recording).....
tap around the lens area with a hard object (tip of a screwdriver) and it works! It may be well worth you tapping the case in this way (without pulling the camcorder to bits) on the top, about an inch back from the front of the lens a couple of times. Since you say that it was working fine off late this should mostly do the trick. a pen rather than a screw driver would also suffice and wack a little bit around the lens and it should work. do this with the camera on so you would see the screen come back on. And let me just say, you dont have to wack right on the glass part of the lens, around it does the trick.
if that does not do the trick . It is adviced that you would be required to replace the ribbon cables. find below the link which you can use as a reference to replace your ribbon cable this is not an exact model as you have and should only be used as a reference.
http://www.skateperception.com/instructional/instructional.php?id=ribbon
If your cam doesnt show picture only while recording then its the CCd image sensor problem which i would not advice you to handle it unless you are comfortable doing it. there are thousands of minute parts inside the handy cam a wrong nudge here and there would ruin the cam than what it already is.
If your cam is under warranty please do not try these fixes as it would void your warranty. Its always a better thing to call on sony support and explain them your problem. coz these are very common problems and they could have a service recall for your model where they would do the repair free of cost.
good luck with your Fix
Thank you for using Fixya
SONY DCR-HC21
try compressed air. the lens some times gets stuck.
Dec 24, 2007 | Sony Handycam DCR-HC21 Mini DV Digital...
How do I get the sony handycam dcr-hc30ntsc to show me a pictuer wale recording or any thing
If camcorder does not show live view in view finder and lcd screen but shows good picture in play back of old recorded tapes then ccd imager chip is defective in camcorder and need to be replaced.
It is not user level repair as soldering work is needed to replace ccd imager chip.
Let me know if you have additional question.
Thanks.
Oct 18, 2010 | Sony Handycam DCR-HC30 Mini DV Digital...
When I turn my camera on and try to record, nothing shows up on the screen.
Make sure lens cover is open, if still camcorder does not show live view then it is bad ccd imager chip problem that will be replaced.
Let me know exact model of your Sony camcorder to provide you part number info of ccd imager chip.
Thanks.
Sep 24, 2009 | Sony Handycam DCR-HC20 Mini DV Digital...
No image display on lcd screen
When i turn swicth onto Cammera, LCD screen and view finder is black ,some smears.Some time see a pictuer.
Any esle is Working good.
Mar 22, 2009 | Sony Handycam DCR-TRV33 Mini DV Digital...
LCD and view finder not working
Well I saw on other post you can turn the screen outwards. It is very difficult to use....but you have to do what you have to do. For the view finder I am still searching for an answer..
Dec 12, 2007 | Sony Handycam DCR-HC42 Mini DV Digital...
Camera mode recording/displaying right
what is the model number? if it's 10 years or older you are most likely dealing with bad surface mounted capacitors.
Sep 16, 2007 | Sony Handycam DCR-TRV140E Digital...
Sony Handycam DCR-TRV460E Digital-8 Digital - Blurred LCD & View-Finder Images
Hello, you should contact Sony Service again. There is a chance that this camera is under so called Sony recall. If you need more info please advice.
Mar 09, 2007 | Sony Handycam DCR-TRV460E Digital...
Sony Handycam DCR-TRV19 Mini DV Digital Camcorder Logo
69 people viewed this question
Top Sony Video Cameras Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Video Camera Expert? Answer questions, earn points and help others
