Question about Kenwood KDC-MP235 CD Player
Unit is blinking when putting cd in
We have changed radio to the KDC-139 and when we insert a CD the unit flashes and the reset button will not stop it
    President:
  • 4,070 Answers
Hi! Does it have the same wiring harness from the old one? If none then theres a problem. Something might be grounding. May I know what was the old cd player? Thanks!
Posted on Jul 11, 2010
  • 10 more comments
  • donnacrai416 Jul 11, 2010
    no, the wiring harnesses are differentand there is no wiring diagram for the 1998 festiva so we can match them up
  • dj_relly999
    dj_relly999 Jul 11, 2010
    Alright then. Try this, remove the positive connectors under the hood to reset the radio system, let it sit for atleast 10 mins. then see how it goes.
    that worked and thank you but i can not get any sound
  • dj_relly999
    Alright, atleast the problem is solved. What you need to do now is try to tap the wirings of the speakers to the cars harness to know the speaker lines.
  • dj_relly999
    If thats the case, since you know where the body ground and power is located you can start tapping the wires to the cars original speaker wirings and see if it will make a sound. Its just nice to know that the problem is solved and the radio is not resetting anymore.
    i have tried changing wires over but still no sound
  • dj_relly999
    Alright, have you tried checking the speakers if they are working good? Try to tap the speaker to a home stereo and see if it will create a sound, just to make sure its working good.
    speakers are fine
  • dj_relly999
    If the speakers are fine and theres still no sound coming out then the problem could be on the radio itself. Is this radio came out of the box as in brand new?
  • donnacrai416 Jul 12, 2010
    braand new out of the box
  • dj_relly999
    dj_relly999 Jul 12, 2010
    Alright, please turn up the volume for the factory stereos are set to zero. Insert a cd to play then try tapping the wires.
    turned the volume up and have tried tapping wires
Kdc-mp
put a cd cleaner in your cd player see if that helps.
Feb 16, 2014 | Kenwood KDC-MP435U CD Player
I have a Bose Wave radio AWRC-1g. The CD player
Yes you have a defective laser assembly. The 139 is a great price as buying the laser lens alone will cost you around 70 .Bose will also upgrade with any new software and will also provide you with a 1 yr warrenty.
Mar 21, 2010 | Bose & Wave& Music System
I have a Kenwood KDC 135 car stereo wont un mute.
behind the face plate there is a little recessed reset button. push it using the tip of a pen or similar. that will fully reset the radio to like it was when you bought it.
Some times head units hicup. this is how you reset it. In most error cases this solves the problem.
Dec 15, 2009 | Kenwood KDC-135 CD Player
Eurovox 'Maestro Series' 10 stacker displaying 'E-99'
CD ERROR DISPLAYS
CD Changers
E01:
The disc magazine is not inserted in the cd changer
E02:
No disc is inserted in the disc magazine
E04:
The disc is dirty, or the disc is inserted into the disc magazine
upside down
E99 RESET PROCEDURE:
Remove CD magazine by pressing eject button on changer.
Remove all discs from magazine and re-load empty magazine into
changer. Using the Radio RESET CD system by pressing and
holding the “ON”/”POWER” button for about ten seconds, or in
earlier models the “EJECT/6” button.
FM/RF Remote Controls
E99 RESET PROCEDURE FOR REMOTES:
Remove disc magazine from changer by pressing eject button.
changer. Press RESET button on interface unit
WAIT:
The temperature is exceeding more than 55c(130f) and the cd
changer cannot be operated. When the cd changer cools off, this
wait disappears. When the RESET button on the interface unit is
pressed, this WAIT appears for a few seconds.
IF THESE ERROR CODES STILL KEEP APPEARING
CONTACT YOUR DEALER.
Jun 21, 2009 | iLO CA3000V CD Player
I HAVE A KENWOOD KDC 122 CD CAR STEREO. THERES A CLOCK ADJUSTMENT BUTTON,WHEN I PRESS THE CLOCK ADJUSTMENT BUTTON THE CLOCK "FLASHES" BUT I DON"T KNOW HOW TO SET IT,I DON"T KNOW HOW TO MOVE THE NUMBERS,IF...
For the manual for this unit head to this page
http://www.cartoys.com/cartoy/pdfs/kdc-122s_manual.pdf]
However im pretty sure you actually use the volume or tune/seek to change the numbers then when changed to what you woudl liek again simply hit the main button you used to get into the clock setting originally,
Hope this helps
Cheers
Steve
Mar 09, 2009 | Kenwood KDC-122 CD Player
Radio wont come on
There should be a reset button on the unit. That would probably be the first thing I would look at.
Feb 09, 2009 | Kenwood KDC-MP238 CD Player
Subs won't turn on
Hi Neo_69
i would love and try to help you. ok so your having a problem with your subwoofers when you put a cd in. well try to change the output of speakers to work when you put a cd in it should be on the car radio and also you can try reseting the car radio there should be a little button to reset it. If you need more help or this does really answer youe question let me know. Thanks
Dec 23, 2008 | Kenwood KDC-MP438U Car CD/ MP3 Player
Kenwood KDC-519 Faceplate Problem
Detach the faceplate and look at the electrical contacts on the back of it for damage/dirt - you can spray it with electrical contact cleaner. Do the same to the contacts on the head unit - it sounds to me like one or more of them are a bit loose or otherwise not working properly.
Feb 23, 2008 | Kenwood KDC-519 CD Player
Kenwood CD player KDC-MP825
Some units have a reset button, have you tried to reset the unit?
Feb 10, 2008 | Kenwood Sirius KDC-MP825 CD Player
Dead Kenwood KDC-128 CD Player Is there a "reset"
KENWOOD MADE TWO DIFFERENT EDITION FOR THIS AND SOME OTHER MODELS. YOUR WILL NEED TO CHECK THE SERIAL NUMBER AND YOU CAN CHECK WITH PACPARTS AT pacparts.com THEY WILL GET THE RIGHT ONE FOR YOU
Dec 13, 2006 | Kenwood KDC-128 CD Player
Kenwood KDC-MP235 CD Player Logo
41 people viewed this question
Top Kenwood Car Audio & Video Experts
xxxxxx xxx
Marvin
Marvin
Mike Duncan
Mike Duncan
Are you a Kenwood Car Audio and Video Expert? Answer questions, earn points and help others
