Question about Home
I have a Eago bathtub and most of the times I
I have a Eagi bathtub and most of the times don't have hot water from the termostatic mixed. In other mixers in the bathroom everything is ok
    Scholar:
  • 56 Answers
Then i would defnetly recogmend replacing the thermostat inside your mixer with new one
Posted on Jul 20, 2010
Richmond water heater
The water inlet to the heater must be plugged.
May 16, 2017 | Water Heaters
Shower is hot- bathtub is not- tempra tankless hot water heater
1) Test for crossover:
http://waterheatertimer.org/Crossover.html
2) Add a comment and say what you discover
If you need further help, I’m available over the phone at https://www.6ya.com/expert/gene_9f0ef4df2f9897e7
Dec 29, 2012 | Stiebel Eltron TEMPRA 24 Tankless Water...
We have a Moen tub/shower faucet and when turned to the hot water position no water comes out at all. We feel like this is an issue with the valve but aren't sure how to replace it.
the valve has a cartridge that controls hot and cold water mixing. 21-t2opdcnl._sl500_aa300_.jpg the valve at one time had a smaller spindle built into the valve to prevent scolding. this item is located in the right hand side of the valve behind the plate next to the cold shut off valve. there is also a hot shut off valve located on the right hand side of the valve. Most times it is the cartridge itself and this can be found at all hardware stores.
here is a link that shows ALL THE TUB/ SHOWER VALVES PARTS.
http://www.moen.com/shared/pdf/tl3450pt.pdf
Hope this helps.
Dec 29, 2010 | Home
We have a Reliance 501 Electric Water Heater. We get only very hot water in bathtub in one bathroom but not the other bathroom. Could the problem be the water heater?
No, the problem is not in the water heater. It could be the plumbing pipes were installed incorrectly.
A common problem with hot water is also found in the settings of anti-scald and pressure balance tub and/shower valves. You may only need to reset the temperature control on each faucet. Every faucet brand has a slightly different adjusting system. Hopefully you can find the faucet's brand name, and then visit their website to find the owner's instruction manual for your model.
A cross connection in the water piping system is rare, but it does happen from time to time. It would allow cold water to mix with the hot. You would need a plumber or leak detection company to locate every water pipe connection in and/or under your home to confirm and correct the issue.
Sep 05, 2010 | RELIANCE ELECTRIC WATER HEATER
Hello, Hot to very warm water comes out of the regular COLD water faucets throughout the house for about 45 seconds whenever the COLD water faucets are opened. I suspect that the thermostatic...
Yes the mixing valves do wear and give out........I had to put a micron filter in the input line to the hot water tank and solved the promlem for around 8 tears now. knock on wood....Hope this helps.
Aug 12, 2010 | Home
My Reliance 606 40 gallon water heater only heats up enough hot water to fill a bathtub. We've drained it, the pilot light is fine, it heats up the water really hot, but it just doesn't seem to be able to...
How big is your bathtub? Is your water heater set on the hottest setting? What is the temperature of the hot water at the tap?
Keep in mind that hot water can cause severe burns. Children and those with diminished mental capacity can be seriously harmed by hot water.
The "40 Gallon" rating on the water heater is usually the amount of hot water the unit can produce in one hour. So the tank, and the amount of immediately available hot water, might be smaller than 40 gallons.
My bathtub is 2 feet wide by 1 foot deep and 4 feet long. This is 8 cubic feet or almost 60 gallons. So a 40 gallons of water at 120 degrees, mixed with 20 gallons of cold water (60 degrees), fills the tub with 100 degree water. My January cold water is 42 degrees, so it will take 40 gallons at 129 degrees to fill the tub. If the tub is cold to start it will take even hotter water.
So the water heater might be just fine.
Possible solutions:
1. turn the temperature up on your water heater- or the temperature control could be malfunctioning and not getting the water hot enough.
2. insulate your hot water pipes so that the water loses less heat on the way to the tub.
3. bigger water heater.
4. smaller bathtub, or less full bathtub.
Jan 04, 2010 | RELIANCE ELECTRIC WATER HEATER
My shower is running cold water only, the rest of house has hot water
sounds like you have a single lever shower, in this case the valve stem which mixes the hot and cold has a clogged hot side , you'll need to remove and replace the cartridge or valve stem
Sep 12, 2009 | Price Pfister RT6-E0XC/HHL-ELBC/0X6-040...
I have an Eago AM128JDCLZ Deluxe Whirlpool Bathtub and cannot for the life of me get any hot water when filling it up. It has a thermostat control dial but no matter which way I turn it the water...
turn the thermostat all the way to the right to its highest setting and leave it there. it will only maintain the temperature of the water you put in the tub. so if you start with 98 F water it will not heat it up to hot water. Bathtub heaters ONLY maintain the temperature of the water.
Feb 24, 2009 | Home
Jacuzzi Hot Water Heating Capacity
Depending on how you heat the hot water, whether gas or electric, is a missing detail in your problem, but if it is electric then your problem is the size, being only 40 gal, and needing probably about that to fill the tub, will always lead to your current position.
If the hot water heater is gas, the chances of it keeping up are slightly better, but again things like the temperature of the water leaving the tank, any mixing valves, etc. will effect the water temp at your tub.  Before raising any temps, make sure you follow local code, as not to scald yourself or others.
Sep 28, 2008 | Home
Home Logo
59 people viewed this question
Top Home Experts
john h
Tom Chichester
Are you a Home Expert? Answer questions, earn points and help others
