Question about Samsung Heating & Cooling
My air conditioner SAMSUNG AQV12FAN doesn't start anymore after a power blackout. the three leds keep blinking and whenever i try to start it i got four diding from it. i'd try to set the option code, but which is the correct one? the only one i've found is for AQ12FAN (without inverter) and i'm not at all sure it is the same of mine. thanks in advance
  • 306 Answers
SOURCE: honewell air conditioner wont turn on
Sounds like with the limited infomation that you lost a capacitor inside the condenser. need more info. Does the fan inside the furnace come on?
Posted on Nov 23, 2008
  • 400 Answers
SOURCE: LG Inverter Air Conditioner showing CH 02 what can I do?
The model number would be on the right hand side of the outdoor unit and same on the indoor unit if it is a midwall split. If it is a flat cassette cieling type you may need to open the grill, which is simply two little levers either side of the grill, and the grill will swing open. Without the model number it is difficult to give accurate info. However, I can offer the following. One, check the condensate drain. You can just blow into the drain pipe from the outside and this sometimes clears clogged mud in the drainpan. Or two, error reading can also come from phase failure (in the case of a three phase unit) or power related problem. This can be solved by switching off the mains and then switching on again to reset. If you have a phase failure you would need an electrician to confirm that the power supply is good. Unless you have a volt meter.
Posted on Mar 04, 2009
co7196
  • 3433 Answers
SOURCE: has power doesn''t want to start up led keeps
You may need a start capsacitor or the compressor is locked up
Posted on Oct 05, 2009
SOURCE: SAMSUNG split AC AS09WHWE led keeps blinking.
Samsung Air Conditioners SAMSUNG split AC AS09WHWE led keeps blinking
Posted on Oct 26, 2009
SOURCE: Samsung AS09XLN air conditioner lights blinking
Sounds like a common problem I have found with Samsung mini split unit. When powering on, does the internal blower attempt to start, then the unit stops and lights blink? If so, on the circuit card there is a 1.2uf or 1.5uf (CBB61) that probably has gone bad. I have replaced several of these. Good luck.
Posted on Jun 13, 2010
Samsung AQV24U series - recent electrical blackout - now keeps beeping every 30 seconds and won't turn on - have switched off mains and separate cut off switch for air cond and still continues
It sounds like you had an electrical surge and it has damaged your unit. I would suggest contacting your home owner insurance and see what they recommend. This may not work depending on your deductibable.
Dec 05, 2014 | Samsung Heating & Cooling
Rheem furnace codes
Stuck pressure switch. Try removing small tube at inducer draft motor and pressure switch, located in the heating compartment, and making sure line is clear. Also try cleaning out small nipple on draft motor assy. with a small wire or paper clip as these get clogged easily too. You can also hook the small tubing to the pressure switch and blow and suck in and you should hear the switch opening and closing. The draft motor running is what causes the negative pressure to pull in that switch. Any debris or clogged with stop operations. Also make sure the flue is unrestricted if that doesn\'t fix it. Hope this helps. Happy Holidays!
Dec 07, 2013 | Weather King 12AJA4801AH Air Conditioner
My hp 2133 powers on but the power led doesn't light up I don't have any indicator as the power led blinks whenever I put my laptop to suspend.
can you just please completely remove your laptop battery --- keep it away for couple of minuets then put back run the pc i hope the problem is gone
May 24, 2011 | HP 2133-1 Mini-Note PC
Instruction Manual need for a Hitachi DC Inverter room air conditioner model RAS-50YH4
http://www.hapm.hitachi-asia.com/index/techsupp/operationmanual/RAS_RAC-50YH4.pdf
Sep 08, 2010 | Heating & Cooling
May 08, 2010 | Samsung AS18A6RB Air Conditioner
AQV12FAN
it sounds like a program feature once the unit reaches a certain temp it automaticly turns it self back on check program guid
Apr 08, 2010 | Samsung Heating & Cooling
Has power doesn''t want to start up led keeps flashing
Oct 05, 2009 | Samsung AS18A6RB Air Conditioner
Sep 02, 2009 | Samsung Heating & Cooling
Samsung aircon cuts off. lights green/yellow flashing
lg air cond.multi split led lamp blink power 1 times,good sleep 2 times
Feb 11, 2009 | Heating & Cooling
Heating & Cooling Logo
227 people viewed this question
Top Samsung Heating & Cooling Experts
gbob59
billconfused
Are you a Samsung Heating and Cooling Expert? Answer questions, earn points and help others
