Question about Microsoft ARC Mouse
Arc mouse - click a window, everything fades to the back
Within the last week....every time i use my arc mouse on my laptop and click on a button....the window fades to the background along with the desktop, i then have to click on the window again for it to become large so i can see it, but once i click on the window again...it goes right back...it has a cascading effect with the other windows i have opened...so basically i click and it drops back...i click on the window again and it turns into a full screen...but then when i click a link..it drops back..can't get anything done....any suggestions? thanks
My arc mouse just quit working, Try putting it in the freezer with the USB. Leave it in for a while. when you take it out, it should work. it did for me
Posted on Jul 14, 2010
Within the last three weeks the cordless mouse which came with the HP Media Centre PC I purchased in November 2006, has begun to behave strangely. When text, especially in a Word document, is highlighted...
You might check for a driver update.
To do this, right click on 'My Computer', Then click on Device Manager, Then click on the [+] sign by 'mice and other pointing devices', Then right-click on the appropriate mouse, Then click on 'Update Driver'
Mar 14, 2011 | HP Computers & Internet
My microsoft arc mouse just stopped working after 2 weeks of usage. It looks like it couldn't connect to the receiver, i've changed batteries, indicator turns on, and fades off in a second and nothing...
If it is only two weeks old, return it under warranty.
You have done what is reasonable to get it to work, and the only thing I could suggest is to make sure the new battery is a good one.
It is not reasonable to have to do more on a new item.
Feb 08, 2011 | Microsoft ARC Mouse
When I put in new batteries, the green light comes on... but, within seconds, the light gradually fades away. so... no mouse. how to solve this issue?
same too with my mouse!!! its driving me mad... green light appear but u just cant use it! and after the light will fade...
Oct 30, 2010 | Microsoft ARC Mouse
I have a Dell studio laptop. Recently, within the
1. In order to fix this, you go to control panel > mouse
the last tab is called "Device Settings" click it and make sure you have "static tray icon in taskbar" selected.
(You can always remove this later.) Apply the changes and click the red coloured icon in your task bar. An option will be available called "Tap to click." Clicking it will enable you to tap with your mouse pad instead of the keys! Hope this helps you out, I know it helped my friend.
2.
In the Control Panel open Accessibility Options Icon and click Mouse Tab and than Setting.
To move the mouse pointer by using MouseKeys
If you have not already done so, turn on MouseKeys.
To turn on MouseKeys, open Accessibility Options, click the Mouse tab, and then select the Use MouseKeys check box. Use the buttons on the numeric keypad to move the mouse pointer. If MouseKeys doesn't function, press NUM LOCK, and then try MouseKeys again.
To move the pointer horizontally or vertically, press the arrow keys on your numeric keypad.
To move the pointer diagonally, press HOME, END, PAGE UP, or PAGE DOWN on your numeric keypad.
Notes To open Accessibility Options, click Start, click Control Panel, and then double-click Accessibility Options.
To specify whether NUM LOCK must be on or off for MouseKeys to function, on the Mouse tab, click Settings, and then for Use MouseKeys when NumLock is, click On or Off.
To change the pointer speed and acceleration when using MouseKeys, on the Mouse tab, click Settings, and then move the sliders to adjust the pointer speed and acceleration.
To temporarily increase or decrease the pointer speed, on the Mouse tab, click Settings, and then select the Hold down Ctrl to speed up and Shift to slow down check box.
Jul 27, 2010 | Dell Studio 1737 Laptop
The mouse won't work at all. I've plugged the usb into all the ports and it just won't work. It won't move scroll or click. The green light comes on then gently fades away. The batteries are new and I've...
The light is supposed to go dim after few seconds. it's not lit all the time. So it works propperly.
2 of my arc mouses stopped working too after 6-12 months and i got new ones but now after 4 months with the new ones, they failed too.
The problem is within connection between USB-device and mouse. the USB device gets overheated and destroys it self in extensive use.
Get it back to store and swap it to new one.
Jun 17, 2010 | Microsoft ARC Mouse
Scroll wheel not working.
try installing the MS Intellipoint drivers http://www.microsoft.com/hardware/mouse/download_ns.asp
Jun 26, 2009 | Microsoft ARC Mouse
I have a dell 8300 I copied data from. Problem can not find data on my Toshiba satellite 35xm-s149 laptop
Alright, this will be painless. Click on Start, then Search. Click on Documents. Click on within last week (or whatever time frame you think it was). Then in the box use a wildcard like *.doc for all word documents or *.* for everything. Click on start and let all the file be retrieved. Then on the top toolbar click on View and Details. Now pull your window on the right edge as far to the right as possible. You will see date modified. Click on date modified and it will toggle between lastest date to oldest date. Your file will be there.
Don't forget to vote 4 stars for this solution.
Jan 17, 2009 | Toshiba Satellite A135-S4467 Notebook
For some reason my font seems to fade from blue to black and then back to blue again. The font should be black and I see it on everything I do. I've only noticed it today. My Acer Aspire 6920 is only 4...
You could have a corrupt windows
if you bought the laptop new try this
click start
click all programs
click accessories
click system tools
click system restore
follow the on screen instructions
what this will do:
it will restore your computer to the way it way on the day you bought it or the last time you made a restore point
Hope it helps
Nov 30, 2008 | Computers & Internet
Microsoft ARC Mouse Logo
957 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Alun Cox
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
