Question about Maytag MDB7100AWB Dishwasher
Maytag legacy door panel replacement
My husband is trying to put on the new door panel, but is unable to get the door off the front of the dishwasher.
couple of questions: how do you get it off and are the electric connections supposed to uplug. it appears as if they should, but he is afraid to really force the plug as it doesn't seem to want to come off.
  • 246 Answers
Try going to, you don't have to take the old door off
Posted on Aug 27, 2009
  • Grant Smith Sep 09, 2009
    Maybe you should leave it on and just cover it. I saw a site on apartment therapy NY called It covers your appliance witha new look without taking the panel off or out.
  • Grant Smith Apr 11, 2010
    Try just covering your current panel. has a bunch of colors and designs that go over your current panel. They even have stainless steel panels and a foil that goes over your dishwasher and matched your other stainless appliances.
2 Suggested Answers
SOURCE: 1.5 year old Maytag Legacy Series Quiet Series 300 Lock Light on
Hold down the heated-dry button for 3 seconds and the light will clear.
Posted on Dec 19, 2009
I have a maytag dishwasher with a touch panel and all lights work but the power button will not turn on. Any ideas?
Might need a new panel -- on mine I found that the ribbon that went from the panel to the circuit board was either shorted out or unseated. try disconnecting the power to the unit (circuit breaker) taking the panel off the inside of the door and inspecting the ribbon for short (looks like a burn mark) disconnect it from the circuit board and putting it back together. if that does not work then a new front panel is needed since the ribbon is attached to that panel.
Jan 20, 2011 | Maytag 24 in. MDB9750AW Dishwasher
The latch is sticking on my dishwasher. How can I
replace the door latch and the handle check to see if the console loops that hold the latch are broken if so replace the console
Jun 02, 2010 | Maytag 24 in. MDB9750AW Dishwasher
Nov 07, 2009 | Maytag 24 in. MDB9750AW Dishwasher
My Maytag washer leaks at the door. It doesn't
f you have nuisance water leaks around the base of your dishwasher, you may be using a detergent that is sudsing too much. Cut back on the amount of detergent you use, and see if that makes a difference.
Water that spills through the door vent is usually caused by improperly loading dishes. Leaks from the door itself may be caused by a faulty door gasket or door tightness adjustment.
Also make sure the dishwasher is sitting level (you can adjust the front feet up or down, and many units have some type of levelers at the rear).
Water under the dishwasher may be originating from a leaky hose or loose hose connection. Remove the lower front panel, and check the hoses. The pump seal may be defective, too; replacing this is a job for an appliance repairperson.
An older dishwasher may corrode at the bottom, but this is fairly uncommon. If this is the case with your dishwasher, it's time for a new one.
Rate the solution..
Jul 10, 2009 | Maytag 24 in. MDB5600A Jetclean II...
Want to replace painted front panel with stainless steel
The installation instructions and the Owner's Manual do not say how to replace the panel.  It may not be possible to change without replacing the entire door.
Look for trim near the top of the door that is attached by screws.  If the trim can be removed the old panel can be slid up and out and the new panel can be slid in.  Alternatively look for side trim piece(s) that might be removable allowing the panel to be slid in.
Jun 02, 2009 | Maytag MDB9600A Jetclean II Built-in...
How do i change front panel on maytag dishwasher seris 300? just the panel
There are a couple of ways. Forst, you may not have to do anything. If you want a great new addition to your kitchen, try these covers are applied without removing the front door. They also have stainless metal ones. To remove the panel there are 2 screws on the sides of the doors. Once removed, the frame will come off and you will be able to slide the panel in and out. DONT LOSE ANY OF THE SCREWS They are not normal screws.
Feb 24, 2009 | Maytag 24 in. MDB9750AW Dishwasher
Maytag Legacy top load washer is SMOKING!
this is a bogus website that is trying to push smelly washer real fixes and there are other products out there for less just use bleach first
May 05, 2008 | Maytag Legacy Series Top Load Washer
Maytag MDB7100AWB Dishwasher Logo
215 people viewed this question
Top Maytag Dishwashers Experts
Charles T Nevin
Charles T Nevin
Are you a Maytag Dishwasher Expert? Answer questions, earn points and help others
