Question about ASUS Eee PC 900 PC Notebook
Laptop won't read sd card , ASUS laptop. It makes a sound when inserted or ejected but how do I see the Pix on it?
    Genius:
  • 1,121 Answers
Which model? can update bios.
Posted on Jul 11, 2010
How do I mount my sd card
You will insert the SD card into the SD card slot on your device then you will power on the device and tap settings from the main menu click free format and then pick mount SD card when reformatting has completed.
May 04, 2016 | HP Computers & Internet
Laptop won't read SD card
have you been tried to use other sd card ? or have you been tried to use other usb slot of the laptop just to know if where the main cause of the problem.
Mar 25, 2013 | Acer Aspire 5736z 4460 Laptop
Why wont my toshiba sd card read on my camera nikon cool pix ?
Make sure your memory card is an SD card and not an SDHC card. If it's larger than 2GB then it won't work with the 3200.
May 26, 2012 | Nikon Coolpix 3200 Digital Camera
Laptop wont read sd card
You do not say, but before ejecting an SD card you should use the Safely remove hardware feature. If you do not do so you may damage your SD card, and you run into problems such as you describe.
Apr 06, 2012 | Dell Inspiron Computers & Internet
My va10 is not reading an sd card i have inserted into the slot
Open computer window and check the drives to see if any show your card. If so double click to open, if not, check device manager to make sure the drivers are installed for your portable devices. On the start menu, right click computer and click manage, in the left pane under computer click device manager and look for portable devices in the main window. Check there is no yellow or red icon next to it, if there is you will need to install a new driver.
Mar 11, 2012 | Sony VAIO VGN-AR605E 17" Laptop
Can't figure out how to insert SD card in Lenovo thinkpad T420
Typically there is an spring-load eject on laptop card readers. If you inserted it correctly, then you can gently push the card in about 1/4 inch, it will click, and it will eject when you release it.
Nov 28, 2011 | Lenovo ThinkPad T420 Notebook
I have a Asus K60ij laptop and I cannot eject my
If when you press the card in to eject it, it doesn't come out, you can use a pair of tweesers to gently pull the card out. There are no mechinisims holding it in place.
Nov 22, 2009 | ASUS A6U Notebook
Insert memory card
I am assuming you are trying to read a SD card from a phone or a sim card. If it is an SD card it will be a micro SD. You will need an adapter to make it a full sized SD card and then it will in the card slot on your laptop If it is the sim card you would need a special machine for that and there is nothing there but the phone's codes anyway. You should be able to find a cheap micro SD card at CompUSA - I think about $6 - $8, and it should come with the adapter.
JC
Nov 17, 2009 | Compaq Presario M2000 Notebook
I insert a sd/mmc card in the slotwhich is same as
Sounds like the drivers might be missing which is why there is no response.
Depending on which operating system your running on the laptop will determine what file you download.
Go to this page:
http://support.dell.com/support/downloads/driverslist.aspx?c=us&l=en&s=gen&ServiceTag=&SystemID=VOS_N_1500&os=WLH&osl=en&catid=&impid=
Choose your operating system, either XP or Vista and then under where it says chipset choose Ricoh Driver and download now. choose download by internet browser. Save it to the desktop if possible and then run the file so it installs.
If you go thru installing the drivrr and the card is still not being read by the laptop then the motherboard is bad.
Aug 22, 2009 | Dell Vostro 1500 Notebook
Sd card jammed in sd card slot
This may sound bad, but I promise it isn't. Have you tried removing the SD card with a small pair of needle nose pliers or even some twizzers? It sounds like the spring mechanism failed, so your only solution now is to pull it straight out, a little force and it should come right out. There are no pins to bend on an SD card.
Apr 21, 2009 | Computers & Internet
ASUS Eee PC 900  PC Notebook Logo
528 people viewed this question
Top ASUS Computers & Internet Experts
David
David
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
