Question about Toshiba 44NHM84 44" TV
Is there a factory restore for the toshiba 44nhm84 and how do get to the lamp inside
    Brigadier General:
  • 8,619 Answers
Hi
Thanks for using FixYa. To reset the TV you’ll need to disconnect the TV from the power socket and mains, remove all the cables from/to the TV and let it without power for about 10 minutes and after it plug all the cables back and switch it on. To replace the lamp use a Philips screwdriver to open the small square shaped lamp compartment panel on the side or back of the TV and pull the lamp out slowly to remove it. Now clean the lamp holder and new lamp with a micro fiber cloth. Please make sure to turn off and unplug the TV for at least 1 hour to drain off current from all components especially capacitors before you perform any repairs. Also note that the TV consists of very high voltages even when it is in off position. Before performing any repairs I’ll suggest you to try and reset the TV by unplugging it for 8-10 hours. Please do accept the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
Posted on Jul 11, 2010
The picture on my toshiba 44nhm84 does'nt seem bright enough.can you help?
hi,
check the brightness setting on ur tv. if u have already checked it, then check ur tvs lamp. its time to replase the lamp. may be its reflector get damaged. thats why the brightness is low.
ok
Dec 31, 2010 | Toshiba 44NHM84 44" TV
I have a Toshiba model 44NHM84 DLP projection TV that will either attempt to power on but then shuts down or when it has powered on there is good sound but no picture.
You will probably find, cahnging the lamp and resetting the timer will fix this problem.
Contact Toshiba for more information if you need to.
Toshiba.com
Oct 24, 2010 | Toshiba 44NHM84 TV
I believe I need to replace the bulb on my Toshiba 44NHM84 but I dont know where the bulb is. I've watched some videos and I cant find anythng that looks like what i'm seeing in the video. What I see is a...
This is lamp of your tv (lamp with housing) that you will see inside tv.
Click Toshiba Support to download user manual copy and check page-50 to 52 for lamp replacement instructions.
Thanks.
Jul 31, 2010 | Toshiba 44NHM84 44" TV
My Toshiba 44NHM84 does not power up. The
It is possible the ballast has failed
Mar 04, 2010 | Toshiba 44NHM84 TV
My picture is foggy is there coolant that needs to be replaced in a toshiba 44nhm84
This type of TV doesn't use coolant. I would suggest to clean the mirror that reflects the image from the optical engine to the screen before replacing the lamp.
Let me know if you need further assistance.
Jan 01, 2010 | Toshiba 44NHM84 44" TV
Toshiba 44NHM84 has no picture just red flashing standby light
during transportation your TV was suddenly shock. then causes your TV lose connection on main circuit board. trust me!
May 21, 2009 | Toshiba 44NHM84 44" TV
How to replace Power Supply in Toshiba 44NHM84 44" TV
Since this is a DLP type set, there is a lamp and ballast involved. When the set shuts down, are there any indicator lights on the front? If so, check the owner's manual for an explanation of their meaning. Typically, the lamp can cause this or the ballast. If either of those are the problem, usually the lights on the front panel will indicate it.
Keep us posted.
Dan
Sep 21, 2008 | Toshiba 44NHM84 44" TV
Toshiba 44nhm84
Hello.. Has anybody found a fix for the dim picture?
Feb 07, 2008 | Toshiba 44NHM84 44" TV
Toshiba 44NHM84 44" TV Logo
42 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Steve Allison
Steve Allison
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
