Question about Kenmore 24032\24036 Top Load Washer
Kenmore Washer fills and then stops... Model 110-26742503 Series 70
My machine fills but does not do anything else. I read your posting about blowing into the pressure switch. I took off the tube initially to make sure I could get it off and then put it back on to fill the tub. The machine filled and then began to work without me ever blowing into the switch. Could there have been some type of vacuum seal or back pressure in the switch. I have run a load through and the machine seems to work fine now.
    President:
  • 878 Answers
Mark , sometimes where the tube goes into the tub, debris such as lint clogs the tube. This can cause this problem. Sometimes the pressure switch itself will hang. Glad to hear you have it going again. Catriver.
Posted on Apr 19, 2008
Kenmore 70 Series Washer Won't advance in the
Bad timer. Try to find a used one if possible, this item is a little expensive.
Aug 23, 2010 | Kenmore Washing Machines
Kenmore 70 series model# 22702 will not spin
Kenmore model 70 washing machine fills with water, doesn't agitate, spin or anything else. Could it be the closed lid sensor? Friend says it broke in two. I told them to unplug power, pig-tail two wires together to complete circuit isolate from all metal and plug power back in, and see if it cycles. Is that advice a good start? Will try to re-post if he calls back and says if it worked or not and we'll go from there. Thanks for replies.
Jul 08, 2010 | Kenmore 22422 Top Load Washer
Hello, Have a Kenmore series 70 (capcity plus).
Note after reading a bunch of information. I went home and removed the hose from the Level Switch and "clean it", if you will and re-attached. Started a load, and bingo bango bongo, it work. Thanks for the insight.
Nov 30, 2009 | Kenmore 22422 Top Load Washer
Kenmore series 70 washer will only fill with water.
I recently had this problem. It was found that the main drive belt broke and the washer would fill but not spin, agitate or drain. I replaced the belt and everything worked again. A defective or disconnected cover switch would also cause the same problem.
Jun 30, 2009 | Kenmore Washing Machines
Kenmore 70 series filled and stopped...
Lid switch problem. Press down on lid and try to start machine. Reply.
Jun 15, 2009 | Kenmore 22422 Top Load Washer
70 series kenmore washer won't agitate help model #82873120
No wash, no spin read THIS
Spins, pumps, won't agitate right: check THIS out
Mar 27, 2009 | Kenmore 22422 Top Load Washer
Fill with water - Stopped in the wash cycle - Blew Breaker
please put unit in a out by its self...recontact if still problem
Dec 15, 2008 | Kenmore 15864/15862 Top Load Washer
Series 70 Washer Won't stop filling
yes and also make sure fill tube is not clogged or debreed
Jul 05, 2008 | Kenmore 22422 Top Load Washer
Kenmore Washing Machine 70 series
You most likely have a broken coupler between the motor and gearcase.
You can buy the part for about $10 or have someone come out and replace it for about $150-200.
If you will post the complete model number from the the washer so I can see which style cabinet you have, I will try to walk you through the repair. It isn't very complicated if you are handy with home repairs.
With the age of the machine it probably just needs a coupler, but it could also have a problem in the transmission or basket drive that has caused the failure.
Nov 13, 2007 | Kenmore 22422 Top Load Washer
Kenmore 24032\24036 Top Load Washer Logo
192 people viewed this question
Sal De
fordexpert
Jim Goldsmith
Jim Goldsmith
