My washing machine goes up to the rinse cycle, the tub is filled with water, but it does not move forward to drain and spin. It sounds like the dial on top of the machine stops moving forward. It won't go past rinse
    Brigadier General:
  • Washing Mach... Master
  • 3,614 Answers
Have you check for the belt?
Posted on Apr 19, 2008
  • micromaster
    micromaster Apr 19, 2008
    **or have you done initial check to the unit, that will help us to give a clear solution..
2 Suggested Answers
  • 245 Answers
SOURCE: Tub filled with water. It's not washing, rinsing,
looks to me ur timer or programmer is faulty possible needs replacement or looked after from a manufacturer for help
Posted on Apr 19, 2009
Roper washing machine does not fill for rinse cycle. Goes directly to rinse agitate without water.
Without Model number I am only guessing but I suspect you have a blocked sensing tube that travels from the Level selector switch to the side of the tub somewhere. It is possible for this plastic tube to become partially clogged and not allow trapped air to vent when tub is drained of water. Usually this problem manifests itself as an overflow of the tub. Check the full length of this clear hose and see if the end nearest the tub looks like it may have debris or dirty detergent clogging it.
This hose is pushed onto a nipple mounted to a reservoir on the side of the tub. Push a thin copper wire 4-5 inches into the those after removing from nipple and also down into the nipple an inch or two before reinstalling the hose to the nipple. You MIGHT even blow into the hose while you have it off and you SHOULD hear a clicking sound coming from the level selector switch body.
Good Luck. Come back with Model number under lid if that doesn't help.
Nov 28, 2015 | Roper Washing Machines
Whirlpool washer model lsr8233eqo
So when the cycle first starts, it will fill and agitate and spin. But then on the rinse cycle it stops?
Feb 03, 2013 | Whirlpool Washing Machines
My maytag mtw5600tq1 washer won't hold water. Its
Its sounds like you have a siphon going on, this happens when the drain hose it too low during fill and as the water enters the unit it exits through the drain hose. To stop this the drain hose needs to be higher than the tub itself, meaning: raise the drain hose behind the washer to about control panel area. This will or should stop the siphon effect and allow the water to remain in the tub. If the drain hose is low this siphon will start again.
I hope this helps
Aug 26, 2011 | Maytag Washing Machines
Hi, our simpson enduro 701 washing machine does not spin back and forward in the deep rinse cycle. but operates ok and spins in spin cycle. thankyou Tina.
Hi Tina just read your posting. From the information in your posting the machine fills, then when the machine is full of water the agitator moves clockwise then anticlockwise until it gets to the rinse cycle then drains the water ,then it fills for the rinse cycle but does not move the agitator in the rinse cycle.Then it drains and spins the clothes dry .Is this assessment of your posting correct.If it is not 100% correct please reply to tell me what the machine is doing or not doing.If it is correct then the problem with your machine is the control board.Is your model the electronic one with the push buttons?Looking forward to your reply.
Jun 26, 2010 | Washing Machines
Kenmore Heavy Duty Series 70 washing machine gets stuck in cycle.
Either your timing motor has broken or the gears that it drives are stripped. The timing motor is easy to replace but if the gears are stripped you will need a whole new dial assembly.
May 09, 2017 | Kenmore Washing Machines
Kenmore front-load washer stops at rinse cycle
When the washer initially fills for the wash, is it only hot water entering the drum? Try switching the water temperature between hot and cold as it fills. If any of them show little or no water getting through, it sounds too easy but check to make sure water supply taps are on, and that the cold/hot fill hoses aren't reversed. Remove the fill hoses and check any of the screen filters for blockage (in the hoses and in the inlet water valve). When the machine stops and waits to fill but all you hear is a hum, it sounds like there is power going to the valve but water is not able to get through it.
Mar 03, 2009 | Kenmore 43142 Front Load Washer
New Whirlpool washer model WTW5700SW rinse cycle doesn't worker properly. The water never fills the tub & continues to drain. You have to manually move the dial to the end of the rinse cycle to have...
Sounds like what you are describing is the timer on the dial is not activating the next cycle. Timers are usually the problem when the cycles do not complete there cycle
Dec 03, 2017 | Whirlpool Washing Machines
Kenmore washer
ckd wires to motor timer slim chance could be water level switch most likely motor wire
Jul 21, 2008 | Kenmore 24032\24036 Top Load Washer
Whirlpool filling and washing, not draining, rinsing or spinning
Check out your outlet filter, probable it is clogged. Clean this out and refit. Most cases when the drain or spin does not work, it is the filter. This is a suggestion.
Apr 01, 2007 | Frigidaire FWS833A Top Load Washer
Washing Machines Logo
Top Washing Machines Experts
