Question about Zenith E44W46LCD 44" Rear Projection HDTV-Ready Television
Loud popping and decrease in volume
A few months ago the tv would come on in the middle of the night at full volume. I figured it was remote control issue, lately, it has a loud popping sound and the volume decreases and slowly returns to normal. Is it fixable or dying a slow death?
  • robace May 27, 2008
    Had the same problem. Noticed that I was getting a power surge from the cable connection. Switched the input from cable to digital connector. Continued to happen for a few more weeks and then stopped on its own. I also noticed that the remote became intermittent around the same time. The picture is now turning green.
  • njpete65 Jul 01, 2008
    loud pop and decrease in volume problem,then it come back slowly , can someone help??
    Problem Solver:
  • 17 Answers
I'm guessing power supply problems fluctuating, or main control board.
Posted on Aug 19, 2008
I have a Sharp Aquos LC-46D43U TV and the audio control is continuously going down to zero although I use the remote to increase the volume. The TV is automatically decreasing the volume to 0. I hea
this is a problem I rectified yesterday.
the audio ic is overheating thats why the tv is fine when cold and
after a few hours the volume disappears.
I fitted a heatsink to the ic chip as the sharp one is very poor quality
Sep 19, 2014 | Televison & Video
Why does volume control not work?
I plugged in in the cable that works for the ears phones from the TV to my Lifestyle system and it fixed everything for me. Good luck hope this helps you.
Jun 29, 2014 | Bose Lifestyle 5 System
The volume on the tv at 100% is not loud, and I am not sure if there is a way to turn up the volume on the tv or through the HDTV cable box
There is something wrong with your cable box. Call the cable provider and they will walk you through setting it or do it remotely. They will not charge you for this.
Mar 30, 2014 | Televison & Video
Bush lcd42f1080p100hz remote will not turn tv on
I had come home about a week ago and pushed the power button from my remote but my tv did not respond. So I just went to the front panel and pushed power but once the tv turned on, the volume was on full blast! I used the front panel volume decrease to get the volume down, but when I stopped pushing the button, the tv increased its volume to full blast again by itself! Naturally I just turned the tv off for a few moments. I tried the remote again, no response again, so I used the panel power button. The tv volume was still full blast when it turned on but after I decreased the volume it stayed this time. The picture is and has been perfectly fine and the tv was working fine. The next day the problem started all over and now once we turned it off from frustration of having to manually use the panel to change channels, it now will not turn on at all. I have changed batteries from my remote, reprogrammed my remote, pushed system reset several times, unplugged it for a while, bought a new surge charge, and even held the menu and device panel buttons for 10 sec and tried to turn the t.v. on again! What other options do I have or what may be the issue at hand and possible parts that may need to be replaced?? Thanks!!
Nov 02, 2012 | Televison & Video
LG TV 32H3300 - volume increasing and decreasing by itself. It will increase if it was turned up via remote last and then will decrease by itself when volume is decreased via remote because it was too...
The cause of the problem is that the switch of your tv is dirty when cleaning it you must be familiar to the unit and the parts you will remove to prevent any damage you can use a contact cleaner, when applying a contact cleaner you must only spray it to the switch. Consult a expert technician to do it for you actual.
May 15, 2011 | Televison & Video
Very little volume, not very loud at highest
On the TV-use your finger to adjust the volume level, about midway, then use the remote to shut off the tv, then turn on tv with remote. Volume level should be better! If still not loud enough...using your finger on the tv...turn up volume & repeat remote steps.
Jan 19, 2010 | Universal Remote Control DIRECTV Universal...
Having connected up my PVR915OT I am unable to increase the volume on the TV to a reasonable level of volume using the Humax handset- can you offer a solution please?
As far as I recall, the volume control on the PVR remote only controls the volume from the PVR. So, select the volume fully up (using the PVR remote) then increase the volume on the TV (using the TV remote) until it's as loud as you can stand. You can then adjust (decrease) the the volume to suit using the PVR remote.
Jan 13, 2010 | Televison & Video
Pioneer SD-582HD5 - screen went black, no sound, Poor remote feed
The blue tube might be leaking coolant in the high voltage area, that is the cause of the POP. This repair might not be a DIY because of the lethal high voltage surrounding the CRTs tubes.
The slow response from the remote could be because the coolant has affected the main board where the IR signal are going to the remote sensor.
Let me know if you require further assistance.
Dec 20, 2008 | Pioneer SD-582HD5 58" Rear Projection...
Tv not responding to remote and now will not turn back on!
if the remote eye on the tv it will do all kinds of strange stuff once the eye on tv gets dirty the the tv will shut off after 2 seconds try cleaning it and see what happens the eye on tv is hard toget to so get a can of air to blow it out i took my pocket knife to clean mine i know that was ruff on eye but thats all i had if this dont work try unpluging your control board on front of set board may be bad or buttons are stuck email me at if this helps
Nov 01, 2007 | Mitsubishi WS-55613 55" Rear Projection...
Polaroid FLM 3232 is making a loud crackling noise overpowering volume
Your only solution is to change the sound to mono. Eventually the power supply will go and the tv won't work.
Mar 19, 2007 | Polaroid FLM-3232 Television
Zenith E44W46LCD 44" Rear Projection HDTV-Ready Television Logo
73 people viewed this question
Top Zenith Televison & Video Experts
matt martin
matt martin
Computer Repairing
Computer Repairing
Are you a Zenith Televison and Video Expert? Answer questions, earn points and help others
