Question about Morphy Richards 44336 4Slice Toaster
How do I remove the special screws in the base.
How do I remove the bottom of my Bravetti EK109B kettle to fix the contacts?
Methinks YOU are going to have TWO problems! The two screws shown are quite 'special' and you will need special BITS to remove them!
Bravetti EK109B kettle Google Search
But check THIS out!
33 Pc Security Bit Set ($7)
And if THAT is not enough, see THIS! ($10 and a MUCH better buy ~ AND you could be the envy of all men on your block!)
100 Pc Security Bit Set with Case
PERFECT if you need to modify your Cable Box!!
(just kidding)
Anthony
PS eBay has them too but BE SURE it is a USA seller or you MAY be waiting from that slow boat from China!
Apr 04, 2018 | Bravetti Kitchen Appliances - Others
What is the application or use of z6000 compressor oils?
The MSDS sheet on it may answer your questions.
Mineral Based
Compressor Oils are mineral based air compressor oil designed for use in many rotary screw, reciprocating and rotary vane compressors needing an ISO 100 oil of this type, providing up to 2000 hour oil drain periods.
Synthetic Based
Are a full synthetic, special, ashless, synthetic based oils, designed to provide extended oil drains in both oil injected and oil flooded rotary screw compressors. They contain a special shear stable synthetic base oil to help reduce deposit formation.
http://www.mitsuiseiki.co.jp/Portals/0/images/catalog/pdf/Z6000%E3%83%BBCOMPRESSOR%E3%83%BBOIL-E.pdf
Jan 13, 2016 | Air Tools & Compressors
Any advice for removing a waterpump that seems to be locked in?
i posted the answer on one of your triple posts.
buck up one, and read.
try posting how far into the the proceedure. you got.
eg: offed all the stuff to get pump pulley removed.
then we removed all screws in pump base.
then forgot to smack the pulley base hub with rubber mallet.
unsticking the old gasket. (all do that)
Jun 30, 2014 | 1994 Mercury Villager
How do I remove the shroud on my Excell XC2600 pressure washer so that I can replace the pulse hose?
I am having the same issue. I need to remove the shroud so I can replace the pulse hose. Did you ever figure out how to do this?
Jun 08, 2012 | Garden
My Cuisinart electric tea kettle just stopped working - where can I get a new base? Model is discontinued CJK -17bc
I took the base apart an repaired the electrical connection. You need a special screwdriver to remove the 3 base screws. I took an old, cheap flat-head driver and filed a v-notch in the middle of the blade so it would work to remove the screws. Had to replace the connector because of corrosion. That fixed the problem for me.
Sep 18, 2010 | Cuisinart CJK-17BC Cordless Electric...
Repair of Steam Iron
I just removed the two screws on the bottom of the cord winder and made the screws tight again, works like a charm.
Feb 17, 2008 | Irons
Olevia 227V LCD
I just repaired a 26" in which the stand came off after I took the primary panel off in the middle of the back then the screws were visible that Olevia is talking about. You might have a different style but it does come off.
Feb 12, 2008 | Digital Lifestyle FA1B32Z 32 in. LCD...
LCD TV Set up
no tips, but if you have tip on how to remove base that would help us out..we hung on wall and cannot remove the 4 screws to remove base, only 2 would come out.
Jan 01, 2008 | Samsung LN-R409D 40 in. LCD Television
Rowenta Iron
Special screw called "Torx tamper proof" call 925 8271011 and order "Rowenta tool" $10.00 plus shipping-this place also sells Rowenta parts
Apr 09, 2007 | Rowenta Professional DX8800 Iron
Morphy Richards 44336 4Slice Toaster Logo
73 people viewed this question
Top Morphy Richards Kitchen Appliances - Others Experts
Oloyede Monsuru
Mike
Are you a Morphy Richards Kitchen Appliances - Other Expert? Answer questions, earn points and help others
