Question about Keurig B60 Coffee Maker
Large cup not consistently filling up each time
Also the de-scale msg on but I have descaled with vinegar and run severeal clean wanter bres through..still saying de-scale. every tother cup from the large button seems to be normal size....what is going on
  • 2,359 Answers
I will answer your question in four parts.
1) Use a hot towel to clean the bottom side of the B60 brewer.
I circle the area in red.
Dry the wet area before the next brew.
2) test the unit with different height cups. Dirty sensor (step 1) can off set the fill sensor on short coffee cup
3) Keurig is full aware of the de-scale problem on user that has hard water.
The has there own de-scale product line.
See the original link HERE
Dezcal Descaling Cleaner (to descale brewer) T41502
$2.95 Café EXPRESS price: $2.65 (You could save $0.30!) based on 4 customer reviews Write a review When your Keurig Brewer display screen tells you it is time to descale, turn to Dezcal! Ensure that you are getting the most out of your brewer and your coffee. Dezcal™ will help you keep your brewer at its top performance.
  • Recommended for use every 6 months on a Keurig Brewer
  • Activated scale remover
  • Thoroughly cleans your coffee brewer
4) Use filtered water to keep the de-scale sensor clean.
I hope combination of all four steps can get your B60 brewer back in service soon.
Posted on Jul 11, 2010
Why is my Kuerig B60 coffee maker not filling the correct amount of water. ie. a cup instead of a mug or 2 instead of 3rd level?
Your b60 may need to be descaled. There might be scale built up on the water level probes in you machine. I have listed the directions below:
Brewer De-Scaling Instructions
Brewer Model: Elite B40 ' Classic B44
Special Edition B60 ' Platinum B70
To begin, you will need the following:
• 48 ounces of undiluted white vinegar
• Large ceramic mug (do not use a paper cup)
• Access to an empty sink
PREPARE
Step 1:
Empty the water in the Water Reservoir.
Step 2:
Disable "Auto Off features."
FILL AND CLEAN
Step 1:
Pour approximately 48 ounces of the vinegar
into the Water Reservoir.
Step 2:
Place a large mug on the Drip Tray Plate and run a brew cycle.
DO NOT USE A K-CUP
, just press the BREW Button. Pour the contents of
the large mug into the sink.
Step 3:
Repeat the brew process without a K-Cup until"ADD WATER"
is indicated.
Step 4:
Now let the Brewer stand for at least 4 hours while still on.
Step 5:
Discard any residual vinegar and rinse the
Water Reservoir thoroughly.
RINSE
Step 1:
Ensure the Water Reservoir is filled with fresh water.
Step 2:
water brew cycle. Pour the contents of the
Step 3:
Repeat brew process until "ADD WATER is indicated.
Step 4:
You may need to perform additional water brew
cycles if you notice any residual taste.
NOTE:
If "DE-SCALE" is still displayed after
completing the procedure, repeat the
descaling procedure above.
Apr 14, 2013 | Coffee Makers & Espresso Machines
Keurig b60 won't dispense water
PREPARE
Step 1:
Step 2:
FILL AND CLEAN
Step 1:
Step 2:
DO NOT USE A K-CUP
Step 3:
is indicated.
Step 4:
Step 5:
RINSE
Step 1:
Step 2:
Step 3:
Step 4:
NOTE:
Dec 14, 2012 | Keurig B60 Coffee Maker
The descale light keeps blinking, what should I do?
The 'Descale' light that turns on indicates that it is time to de-scale the machine.
Scale - or mineral deposits- form from the water you run through your Keurig coffee machine. If not cleaned regularly, the buildup can clog the lines in your machine and ruin the heating element. The manufacturer recommends you descale Keurig coffee makers once every six months for normal water conditions and once every three months if you live in an area with hard water.
You will need :
  • Keurig coffee maker
  • 48 oz. white distilled vinegar
  • Water
  • Large ceramic cup
  • Sink
Instructions :
  • 1 Unplug the coffee machine and remove the cup.
  • 2 Turn the coffee machine upside down over the sink in order to fully drain it of water. Be careful of the plug and avoid getting it wet.
  • 3 Pour undiluted white vinegar into the reservoir up to the top edge of the viewing window.
  • 4 Place a ceramic cup under the machine, plug it in and press "Brew" for a large cup. Pour the cups of vinegar into the sink and repeat the process until the reservoir is empty.
  • 5 Remove the final cup of vinegar and empty it. Fill the coffee maker with clean water and allow it to sit for four hours, remaining on.
  • Good luck ;)
    Dec 14, 2011 | Keurig Elite B40 Coffee Maker
    I lost my manual. How do I de-scale? Does this not allow you to brew a cup until it has been de-scaled?
    From http://www.keurig.com/customer-service/brewer-registration-and-support/~/media/Files/Keurig%20Brewer%20Manuals/De-scaling_instructions.ashx
    PREPARE Step 1: Empty the water in the Water Reservoir. Step 2: Disable "Auto Off" features.
    FILL AND CLEAN Step 1: Pour approximately 48 ounces of the vinegar into the Water Reservoir. Step 2: Place a large mug on the Drip Tray Plate and run a brew cycle. DO NOT USE A K-CUP, just press the BREW Button. Pour the contents of the large mug into the sink. Step 3: Repeat the brew process without a K-Cup until "ADD WATER" is indicated. Step 4: Now let the Brewer stand for at least 4 hours while still on. Step 5: Discard any residual vinegar and rinse the Water Reservoir thoroughly.
    RINSE Step 1: Ensure the Water Reservoir is filled with fresh water. Step 2: Place a large mug on the Drip Tray Plate and water brew cycle. Pour the contents of the large mug into the sink. Step 3: Repeat brew process until "ADD WATER" is indicated. Step 4: You may need to perform additional water brew cycles if you notice any residual taste. NOTE: If "DE-SCALE" is still displayed after completing the procedure, repeat the de-scaling procedure above.
    Mar 17, 2011 | Keurig Special Edition B60 Coffee Maker
    My keurig says I need to descale.How?
    Descaling depends the size of the reservoir. I see the B60 but not the B66 at the Keurig site. The two units are apparently the same from searching the support side of the Keurig site: http://www.keurig.com .
    For the Mini coffee makers, you use 20 oz of vinegar (2 10 oz cycles). For the larger Keurig units, it takes 48 oz of vinegar.
    In either case, fill the reservoir with vinegar and put a large ceramic (12 oz mug for the mini unit) mug on the drip tray. Do not add a K-cup. For the B60 (and probably the B66), press the Brew button. Discard the vinegar after the cycle. Repeat the brew process until Add Water is indicated. Discard the vinegar each time. Then wait 4 hours with the unit on. Discard the remaining vinegar and rinse the reservoir. Fill the reservoir with 48 oz of water and brew several cups without a K-cup until the "Add water" message appears. Discard the water in the mug each time. Repeat the vinegar cleaning if De-scale still appears in the LCD. Run more water without the K-cup if you notice a remaining taste in the coffee after the rinse procedure.
    For the mini, fill the reservoir with 10 oz of water, lift the Brewer handle and lower it after 5 seconds with no K-cup in the unit. Press the Brew button. Discard the vinegar after the cycle. After the first cycle, pour the other 10 oz of vinegar into the Cold Water Reservoir. Lift the handle and lower it after 5 seconds. Press the Brew button and wait until the light becomes steady. When vinegar starts to be dispensed, power off the unit. Wait 30 minutes. Then power on the unit and lift and lower the handle again. Then discard the vinegar after the cycle. Next run 4 rinse brew cycles with 10 oz of water each time. Discard the water each time. The unit should be ready to brew with a K-cup after the 4 rinse cycles.
    I hope this helps.
    Feb 22, 2011 | Keurig B66 3-Cup Coffee Maker
    Inserted K cup and closed machine. Says Brewing but coffee machine only dispenses a few tablespoons of water...tried turning machine off and off, but same amount of water is dispensed each time, no matter...
    Sorry to read about your issue.
    The brewer should be de-scaled at least every 3-6 months. Scale is harmless, but if left unattended, it can hinder optimal brewer performance. De-scaling your brewer regularly helps maintain the heating element, removable water reservoir and other parts of the brewer that come in contact with water. Better water quality and water heating means a better cup of coffee, tea, hot cocoa or iced beverage. We recommend de-scaling your brewer at least every 6 months (every 3 months if your water has a high mineral content). The de-scaling process involves using 48 ounces of undiluted white vinegar.
    Take 48 oz of white vinegar. place in tank. pretend you are making coffee (Do No Use K Cup). let the water fill you mug. then empty that mug. Do it again until tank is empty. then let sit for 4 hours.
    Then fill with fresh water to the top. let that tank of water run thru. towards the end taste the water.
    If you taste vinegar..use more clean water, until the taste is ok.
    I tried to help you. Please help me and Vote/Rate this response. Thanks and good luck
    Jan 01, 2011 | Microwave Ovens
    My keurig says descale
    I tried to help you. Please help me and Rate/Vote on my response. We take the time to answer your question. take the time to rate us.Thanks and good luck
    4 Thumbs - Very Helpful
    3 Thumbs - Helpful
    Jan 01, 2011 | Coffee Makers & Espresso Machines
    It's blinking de-scale side water holder gets r4eally hot water is not coming out properlywhen u press one of the cup size bottons
    This is the time, you need to Descale the machine. The simple procedure is :-
    Unfortunately, in spite of the best-laid plans of mice and men, espresso machines often get clogged by scale, deposits of minerals from hard water. Scale can cause serious damage if untreated. If your espresso machine's water flow has decreased a lot, it's probably because of scale. Fortunately, there is an easy and inexpensive way to descale your espresso machine.
    1. Obtain some citric acid. You can either order this online or find it in the kosher foods section of the supermarket (usually marketed as "sour salt"). Acid solutions dissolve scale, which is made of calcium carbonate. There are special solutions marketed specifically for descaling, but citric acid works just as well and is much cheaper.
    2. Prepare the descaling solution by mixing citric acid with water (I use two tablespoons of acid and a quart of water).
    3. Put the descaling solution in the water tank, turn on the machine, and run water through the steam wand until the cup is filled, to expose the parts to the solution. Turn off the machine, and leave it for 20 minutes so that the solution has time to dissolve scale.
    4. After 20 minutes, run more water
    5. Run solution through the machine every 20 minutes, until the water tank is empty.
    6. Fill the water tank with plain water, and run water through the machine until output water no longer tastes sour. This is important, because excess citric acid does not make coffee taste good.
    Let me know, if need further assistance.
    Hope i helped you.
    Thanks for using ' Fixya ' and have a nice day!!
    Oct 12, 2009 | Keurig Coffee Makers & Espresso Machines
    Descaling light on
    Per Pages 9 and 10 of Keurig Model B40 Use and Care Guide,
    1) turn off the "Auto Off "feature
    2) fill empty water reservoir with 48 ozs of undiluted white vinegar.
    3. Place ceramic cup on the drip tray and run a brew cycle. Do not use a K-cup!
    4. Press the large mug Button
    - let Keurig coffee maker fill mug with vinegar & empty in sink.
    5. Repeat brew process until water reservoir of vinegar is empty. (remember to open and close lid between each cycle so large mug Button will flash.
    6. Rinse the water reservoir thoroughly and fill with fresh water.
    7. FINAL STEP RINSE CYCLE
    a) place a ceramic cup on the drip tray
    b) run regular brew cycles WITHOUT using a K-cup.
    c) pour rinse water into sink each time.
    d) repeat brew process until water reservoir is empty.
    d) perform additional rinse cycles if you notice any residual vinegar taste.
    e) if the red "De-scale" light remains illuminated after completing descale and rinse cycles, repeat the descaling procedure above.
    Otherwise - you're good to go!
    Apr 16, 2008 | Keurig Elite B40 Coffee Maker
    I assume your coffe maker used to produce more coffee for each use. Roughly 6 ounces per large cup, and now is only making 3 oz. cups.
    If your coffee maker is sputtering and not able to "suck" enough water to fill your cups of coffee it is most likely due to cavitation caused in the little pump due to a stoppage, which is most likely lime or scale buildup somewhere in the pump line.
    To fix it, don't take your coffee maker apart. Get a bottle of distilled white vinegar, and pour it straight into the empty water resevoir. Press brew with no coffee pod so you are just running the vinegar through the system. Pour the vinegar out of the cup and back into the resevoir. Add some ice to cool it off. Repeat about 10 times. This should clear out the toughest lime scale clog.
    After you notice the cups are filling full of water, Replace the vinegar with fresh water. Run about 5 or 6 cups of fresh water through the system to get rid of the vinegar.
    Make coffee/tea/whatever.
    Jade
    Oct 06, 2007 | Keurig Special Edition B60 Coffee Maker
    Keurig B60 Coffee Maker Logo
    584 people viewed this question
    Top Keurig Coffee Makers & Espresso Machines Experts
    Lisa
    Lisa
    Jason
    Oloyede Monsuru
    Are you a Keurig Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
