Question about Eiki LC-XB28 XGA LCD Projector Multimedia Projector
When I on the projector on blue screen one black big spot coming
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 84 Answers
Broken lcd panel, entire optical prism assy to be replaced, costly !!
Posted on Apr 17, 2014
5 Suggested Answers
SOURCE: blue spots on screen
Obviously this is not the first lamp you have replaced in you projector. These are great projectors however, the LCD panels expire quite quickly. You will find that the spots are related to the LCD panels needing to be replaced. This is not an inexpensive maintainence solution as the panels cost about $1500 each.
Posted on Jan 25, 2008
SOURCE: Wonderwall projector has black spot in middle of screen
My guess is that you have the projector flat on something? I did that and got the spot right away. The directions says NOT to lay flat, you must use the arm/handle so it will not overheat. Next time you get the spot pick the projector up and it should go away in about 10 seconds. It is overheating. Use the arm/handle, if you need it to sit level place a wii game or something similar size in the back to level it out.
Posted on Dec 26, 2009
projdoc
  • 2237 Answers
SOURCE: my 3m s20 projector has a big yellow spot
the polarizer on the blue lcd panel is fried due to excessive dust and heat. you may have to replace the whole optical engine.
Posted on Jan 27, 2010
  • 16 Answers
SOURCE: Hitachi projector model CP X260 projects yellow spot on screen
blue blotches on screen due to dust get optics cleaned should then work ok...yellow spot more likely to be lcd or lens burn a much more serious and expensive problem
Posted on Mar 17, 2010
Black spot on projector image
Unfortunately, the DLP chip of your projector is defective, and will require to be replaced/repaired.
Mar 25, 2014 | Acer Office Equipment & Supplies
Yellow spot on VPl x1000 Sony projector screen
one of the three polarizers is burned up It can be repaired
Dec 27, 2012 | Office Equipment & Supplies
Blue pixelation spots all over main viewing screen.
Your dlp chip needs replacing. It's a job to do but you can do it.
Jul 23, 2017 | Sony Video Cameras
My 3M S20 PROJECTOR HAS A BIG YELLOW SPOT
seems like the blue polarizer is overheated. you would have to check out inside the optics to see if the light that enters the blue lcd is coming from the overheated glass plate just in front of it.
Apr 04, 2011 | 3M S20 Multimedia Projector
My 3m s20 projector has a big yellow spot in the middle of the screen even without a video signal. changing lamps did not help.
Nov 23, 2009 | 3M S20 Multimedia Projector
I have a Sony WEGA backlit LCD 42 with a blue spot.
sony canada is replacing the color block on all of the 2006 2007 model year of the Grand wega
Oct 16, 2009 | Sony (XL-2400) Projector Lamp for...
Tranlucent dark spot on Optoma image. Looks like something is on the lens.Off center--top to bottom. Cleaned lens, blew out case, changed bulb, still with dark spot.
Aug 08, 2009 | InFocus LP70+ Multimedia Projector
Large dot in the middle of the projected display
there is a burned-in spot on the polerizer light filter for the blue lcd. it makes sure the light is blue coming through, that's why it is black on a blue screen, and yellow when the red and green are the only light showing through. it needs to be replaced. pat # PFiLW0213CEZZ.
May 21, 2009 | Sharp XG-E3500 Multimedia Projector
This is probably the polarizing filter. It will need to be replaced. It should not cost very much to fix.
Jan 07, 2009 | Office Equipment & Supplies
Yellow spot
the problem is in the light path starting with the blue input polarizer then the blue lcd hopefully its just the input polarizer. worst case you will have to replace the LCD block witch is expensive to do. the polarizer ia a speacialy tinted glass designed to help with the LCD's temp.
Oct 23, 2008 | Mitsubishi SL4SU ColorView Multimedia...
76 people viewed this question
Top Eiki Office Equipment & Supplies Experts
jasbo
jasbo
neOen
Level 1 Expert
Jaime Hernandez
Are you an Eiki Office Equipment and Supply Expert? Answer questions, earn points and help others
