Question about Hitachi C1424T 14" TV
Can't get my XBOX 360 to play on my portable TV
The scart adaptor for my 360 is broken, so I'm using the white and yellow AV plugs, but i just can't find the channel. The 3 channels I get by pressing the AV button are called ''AV-1'' ''F-AV'' and ''RGB''
There must be a way to get it or why would they put the ports on the front of the TV...?
Also, its not a C1424T, its actually a C1426T, but there was no option for for that
  • 979 Answers
SOURCE: 3 Digit Channels
Make sure the tuner is set for Cable and not broadcast...accordianman
Posted on Oct 20, 2007
jerryg50
  • 1689 Answers
SOURCE: Hitachi 27
If the sat feed is on channel 3, and the TV is tuned in and still does not get the feed, check the feed wire to be okay. If all is okay, there is a possiblity that the tuner module in the set has failed.
Jerry G.
Posted on Apr 29, 2008
SOURCE: Can't change channels
I had exactly the same problem. I finally found the power button on the underside of the TV. It is well hidden and to find it, you need to run your fingers underneath the panel. Turn it off for a minute or so and turn it back on and then turn on the switch on the panel on the upper right side where the channel and volume buttons are. It works.
Posted on Nov 14, 2008
  • 3 Answers
SOURCE: Hitatchi 42HDF52 only receives channel 5 and 6 on analog RF input
If you have tried autoprogramming and have found nothing it may be a bad tuner. Is your VCR is hooked up via coax or into a video input? If it is hooked up via video and is working but the coax connection direct isnt it will be a bad TV tuner. Easiest cheapest fix is to use you VCR to change channels or get a Digital Cable Terminal from you cable provider and hook it into video or compnent.
Posted on Jan 29, 2009
SOURCE: Hitachi 42PD6600 - Picture Problem when changing AV channel
I Have the same problem but with the EXT6 channel HDMI.
have you solved the problem yet?
Posted on Mar 02, 2009
What lead do I need to connect a DVD to Tv with no scart socket Technika 40E21B-FHD
the TV has component input so if you get an AV lead will come with 1 white leade and 1 yellow lead at each end, plug them diectly into TV and then at other end of cable get an AV to scart adaptor for your DVD had to same for my daughters TV and dvd as had no scart
Dec 12, 2014 | Televison & Video
How do I play my xbox 360 on it I can't figure out what Chanel to play it on
xbox 360`s work on a scart connection if you dont have the scart adapter for the cables then plug them into the red yellow and white scokets on the tv at the front and with the remote controll select av3 this should cure your problem
hope this helps
John
Jul 10, 2011 | Sansui DTV2760 27" TV
How to hok up xbox 360
Use the Scart adapter that comes with your xbox. If one did not come with it visit this link. http://www.amazon.co.uk/Xbox-Scart-Cable-AV-Adaptor/dp/B00005Y4BQ
Feb 01, 2011 | RCA F25261 25" TV
I have a jvc i'art tv. model # av-27f476. i have an xbox 360. how do i hook em up? i have plugged the red, white, yellow cables to the corresponding colored jacks on the front of my tv. i turn my xbox 360...
on the xbox i think the hd works with all 6 cables connected so you will need to switch it back to standard definition. if its still not working try it via scart m8
Mar 06, 2010 | Video Game Consoles & Games
Where do i plug the different leads in the back of my tv i havn,t got a yellow port for the yellow connecter
What sort of tv do you have, is it new? If its new it may well have an Hdmi connection which gives you the sweetest graphics....
If your tv is older you probs have a scart connection, the yellow lead carries the video signal, some tv's have three little socket that the red yellow and white leads plug into if you cant find anywhere to plug it in you will need one of these , a scart adaptor
http://cgi.ebay.co.uk/ws/eBayISAPI.dll?ViewItem&item=120439215212&category=11319&refid=store
(thats just an example of what one looks like, you can buy them all over)
THe red white and yellow cables plug into the scart adaptor which usually plugs in the back of your tv, done
Jul 29, 2009 | Microsoft Xbox 360 Console
XBOX 360 NO PICTURE
if using hd tv then use the cable with the blue lead, if not using hd tv then use the red, white and yellow leads. If using the scart connection to put the leads into make sure that you have it set to the correct av or ext channel
Dec 28, 2008 | Video Game Consoles & Games
I am Unable to connect my Aduio cables from the xbox 360 to my TV
1) Connect the red, white & yellow audio leads in to the 360 scart adapter and then plug this in to the scart socket on the tv
2) change the xbox 360 selector at the back of the console from HD to TV
2) Select the input of scart on the tv
You should now get pictures & sound.
Dec 28, 2008 | Televison & Video
My 360 when i start up it does everything in black and white
You can send your broken xbox 360 to my shop Fixit repair service and I can send you a refurbished xbox 360 system for $80 and one year warranty here is the number 206-271-0529
Nov 08, 2008 | Microsoft Xbox 360 Console
Xbox/TV
Try using a scart switch, therefore you only have to use a basic scart lead from the TV to the switch. then plug your xbox scart into the switch and it should work
Nov 03, 2008 | Televison & Video
Xbox 360
Yes I have mine hooked up to a old Tv
Regards
Mick
Nov 12, 2007 | Microsoft Xbox 360 Elite Console
Hitachi C1424T 14" TV Logo
97 people viewed this question
Top Hitachi Televison & Video Experts
Jaime Hernandez
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
