Laptop not starting properly
Laptop will not start (no bios screen) unless I remove and then reinsert cmos battery, once this is done it starts as normal but when it's shut down it will not restart and I have to repeat the procedure to get it started again?
  • Tony Groves
    Tony Groves Jul 12, 2010
    Thanks for your suggestions but I've already tried all this with no satisfactory result, apparently a lot of people who own Advent and E-Systems notebooks have the same problem it was a vista update that has corrupted the bios and as yet there is no fix! I really need someone with and E-Systems 4115C Notebook to make a copy of their BIOS so I can flash mine with it and hopefully fix!
    Problem Solver:
  • 15 Answers
Follow these steps & ur issue might get resolved(80% chances):
turn off ur notebook-->take out the laptop battery(not the cmos battery)-->disconnect the charger if its connected to the notebook-->now press & hold the power key for atleast 20 seconds, remember that u have to press & hold the power key & dont release the power key till 20 seconds are over--> & ensure that the notebook is not connected to any power source while u r performing this step niether the battery nor the charger--> also there shouldn't be any peripherals connected to the notebook-->once 20 seconds are over & u have released the power key-->connect the battery & the charger back to the notebook & now try to turn on the notebook-->u might not get a blank screen & ur issue might get resolved, turn off ur notebook again & restart to ensure that its not reoccuring....(This whole step is known as power drain & it is done to remove the extra static electricity which sometimes get stored in the notebook & gives a blank screen in return.)
Posted on Jul 11, 2010
Laptop stop on post screen
chek the "RAM" , remove and reinsert again.
if not work, reset CMOS battery maually, CMOS battery located under
remove CD drive
keyboard or backside
one is start plese update bios.
Apr 19, 2012 | Fujitsu Siemens Computers & Internet
I forget the enter password for start and bios i need cd start.
Remove the CMOS battery from your Laptop for 3-5 minutes then reinsert it...
Aug 04, 2011 | Computers & Internet
In the top left of the screen appears a padlock, apparently requests a password or something like that, I can unlock it? Thank you
Your machine has a Supervisor password enabled. It is usualy the last 4 digits of the serial no of the laptop. If that doesn't work then the other thing you can try is to remove the BIOS battery and reset the BIOS.
You will need to open up your laptop. The laptop CMOS battery is shown below.
Disconnect it for 15-30 minutes or more, then reinsert it and the data in the BIOS memory should be reset. If at first it doesn't work, try to remove the battery overnight. Once the battery has been reinserted power up the PC and see if the reset was successful.
Feb 25, 2011 | Lenovo ThinkPad R61 Notebook
Bios password crack
Remove a small coin sized CMOS battery to store all BIOS settings along with the password. To reset the password, unplug the PC, open the cabinet and remove the CMOS battery for approx. 15-30 minutes and then put it back. It'll reset all BIOS settings as well as the password and you'll need to re-enter all settings.
Under the keyboard or bottom of laptop - If you are working on a laptop computerthe location of the dipswitch (almost never a jumper) can be under the keyboard or on the bottom of the laptop in a compartment such as the memory compartment.
If it fails, then try to remove the battery for at least one hour.
hope this helps
Feb 04, 2011 | Biostar U8668D (802700113338) Motherboard
Cmos reset
I have not specifically worked on this make/model of computer.
Technically, you cannot reset this ... I think what you are asking is how can your modify the settings. Typically one would press F2 or F8 or F11 to enter the setup during the boot process. It may be a different F key, it should flash on the screen when you boot.
You could disconnect the battery back up if you can locate it. ..This will remove any custom setting, but will not let you get back in to change it unless you find the correct F key to press.
On the other hand ... there are no more than 12 F keys. You should be able to find the proper one.
If this doesn't work, you should go to www.fujitsy.com/support for assistance.
Thanks for visiting today.
Jan 31, 2011 | Fujitsu Stylistic ST5112 Tablet PC
I have forgotten my BIOS start up password for Sony VGN-CS31S, could you please help?
To reset the bios password on your laptop, you will need to remove the cmos battery on your laptop for some minutes and insert back, the cmos battery is located on the motherboard of your laptop, once the cmos battery is removed from the motherboard for some minutes, the bios password will be reset, and that fix the problem.
Jan 04, 2011 | Computers & Internet
How to reset laptop compaq nx6325 bios password
To remove the bios password you need to clear the CMOS.
Open your laptop casing look at your motherboard. locate the CMOS jamper it is near the battery. To clear remove the jamper and turn your computer on with in 5 to 10 seconds and turn it off. Reinsert the jamper back to there proper place and try to turn go to BIOS if there will be a password box appear.
You need to open your laptop and look at the motherboard and locate the CMOS battery. Just remove it with in 5 minutes to clear BIOS password.
Nov 30, 2010 | HP Compaq nx6325 Notebook
HOW TO REMOVE BIOS PASSWORD AND FINGERPRINT PASSWORD
Actually you can clear the BIOS password by resetting the CMOS jamper. If you are familiar with CMOS jamper it is easy for you. Open your laptop with the use of screw driver. Once you are already open it locate the CMOS jamper near the CMOS battery at the south bridge of your laptop motherboard. Remove the jamper with in 5 seconds after that reinsert and trun on your laptop.
Feb 24, 2010 | Toshiba Tecra A7-S712 Notebook
Bios password cant boot password protected
I have found that BIOS/CMOS Password Recovery Tool is the most effective.:
BIOS/CMOS Password Recovery Tool is a program that works instantly to remove any lost or forgotten BIOS/CMOS password. Simply boot your PC to DOS and execute the program, and get access to forgotten BIOS/CMOS passwords in just seconds
BIOS/CMOS Password Recovery Tool Service: http://www.biospasswordrecovery.com/
Oct 09, 2009 | Dell Latitude D505 Notebook
Foget the bios password
To reset a bios password you need to remove the CMOS battery in the laptop. Here is a link to the manula from the Thinkpad T20:
ftp://ftp.software.ibm.com/pc/pccbbs/mobiles_pdf/62p9631.pdf
If you have some technical knowledge then you can try the following procedure. If not then I would recommend leaving the laptop into a professional to do this instead.
First off go to page 66 of that manual. You should see a picture of the battery pack on the bottom of the laptop being removed.Make sure that the A/C adapter is unplugged from the laptop. First slide the switch indicated by the number 1 in the drawing and then lift up the battery.
On page 67 you should see a smaller battery being removed (which is the CMOS battery we are looking for). First remove the screw indicated by the number 1. Then, gently lift out the piece as shown in the bubble with number 2.
After 10 seconds then reinsert the CMOS battery and screw it in again. Then reinsert the battery pack and start the laptop. The bios should be reset and the password should be removed. Any settings that were stored in the bios will be reset to their defaults. Unless you have changed these settings before then they were probably at their defaults anyway.
I hope this can help,
Adam.
Oct 31, 2008 | IBM ThinkPad T20 2647 Notebook
Computers & Internet Logo
184 people viewed this question
David Payne
David Payne
