Question about Ryobi Cultivator
Will not start. If it should start once you ingage the throttle it dies.
2001 explorer sport , fuel pump? vacuum leak? 619 scan tool data provided, any suggestions/solutions
The fuel pump is suspect but I believe there's also a fuel filter inline on the underside of the drivers side chassis. Fuel works off pressure so if the filter is clogged, the pressure remains between the fuel tank and the filter. Once the fuel has siphoned off between the filter and injectors, it dies but because there's positive pressure at the fuel pump, it won't come on until the pressure slowly seeps past the clog after hours. It's worth a look!
Apr 08, 2017 | 2001 Ford Explorer Sport Trac
Why does 1996 Volkswagen Jetta Gl start very hard and dies with quick throttle push? Slow and
What is the fuel pump pressure? When you put the throttle down, there is not enough fuel to match the air inlet and it dies.
Apr 06, 2015 | 1996 Volkswagen Jetta
HUSQVARNA Z4824 O TURN MOWER - NOCKS WHAN PTO IS INGAGED & STALLS
need throttle adjustment govenor adjustment possiblt new pto clutch you have to take in to shop adjustmets 50.00 pto clutch 200.00
Sep 03, 2014 | Garden
Will idle but when ingage clutch and give it gas it spits and sputters and dies?
Sounds like coil packs are shot! Suggest replace and it should run great. The coil pack it what sets the fuel injectors to perform at peak proficiency on post 1990s cars because they did away with the distributor & rotor (use to be able to just turn distributor to rev it up or down "my wife use to be able to adjust the old ones".)
May 03, 2014 | 1992 Mercury Capri
Engine dies idle wont start
Hi Anonymous, for more information about your question please visit the website below. Good luck and have nice day.
Harley Davidson Magneti Marelli Fuel Injection Settings
Aug 16, 2013 | Harley Davidson Motorcycles
Engine dies
check carbon build up on throttle body use throttle body spray cleaner
and wipe out with clean rag.
Jun 08, 2012 | 1994 Pontiac Grand Am
1989 pontiac 6000 le, car died while driving, had it towed , it started several times afterwards. Car was driven 1/2 mi and it died again, this time for good. Car will crank but will not start. Have...
check to see if the starter is ingaging or making a clicking sound when you have the hood up. If you do not hear the starter ingaging then its your starter but also you might have a ground issue too so use a multimeter if you know how and have one check things with this to see if there might be any short to the ground of car plus there might be bolts lose or missing as well you should check.
May 27, 2011 | 1989 Pontiac 6000
Craftsman lt1000 18 hp briggs keeps wanting to die
could be a dirty carb. Did you use stabil over the winter. Also could be a govener problem.
Jun 23, 2009 | Garden
Ryobi Cultivator Logo
18 people viewed this question
Top Ryobi Garden Experts
Nick Olsen
Rexter1
Roland W VanLue
Roland W VanLue
Are you a Ryobi Garden Expert? Answer questions, earn points and help others
