Question about LaCie d2 Extreme 250GB External with Triple Interface USB 2.0/Firewire 400/800 - 300790U ... Hard Drive
Lacie External harddisc is not visible hi there I
Lacie External harddisc is not visible hi there I am using a Lacie Extreme Bigger disc 1TB. It is connected to a laptop running Windows xp Service pack 3. The disc appears in Disc Utility in the usb dropdown menue as "unknown device" The blue light is on and the disc appears to be spinning without any noise. I think it is either the power supply or the driver. I have tried installing the latest driver update from Lacie but there is no change. thanks for your help don
SOURCE: deference Lacie d2 Quadra1TB/Lacie big disk ?
It's all about the interfaces.
The Quadra has four interfaces: • eSATA • FW 400 • FW 800 • USB 2.0
The triple has all but the eSATA interface listed above.
For doing video work you want a big drive with a fast interface. If you have eSATA available then that's the fastest. If you don't then you're just as well off to go with the triple interface. The FW 800 would be the next fastest, then the USB 2.0, then the FW 400.
Because of the way that data is transferred I believe that when doing video work you would be best served by the FW 400 instead of the USB 2.0 even though the USB is faster I don't believe it is a full duplex communication so the FW 400 is actually better for video.
Posted on Apr 06, 2009
  • 696 Answers
SOURCE: LaCie Big Disk Extreme 1TB Hard Drive - continuous beep, no power
Hi, Lacie isn't very forthcoming with beep codes but it definitely means one of the two. You can try moving the hard drive into a new enclosure, if it works it was the enclosure, if not the HDD. Hate to say it but warranty on these drives is a moot point the moment unique data is stored on them as you can't even diagnose the problem properly without voiding it and no drive manufacturer will waranty data. If you have no unique data and it's under warranty, send it back. If you have unique data on it that you value, take it to a local computer store and have them move the drive to a new external enclosure and test it. If it works, you're done. If it doesn't, you've confirmed that the HDD is faulty and you will need the help of a data recovery Pro. If the latter is the case, reply by commenting here with your location (country, state city) and I'll recommend a closeby facility for you. Chris
Posted on Jun 05, 2009
  • 13433 Answers
SOURCE: From customer no"GBW 051809". MY D2
The power adapter must be faulty, replace it with a new one.
if you are on warranty please contact your dealer or lacie directly for warranty support / replacement.
Posted on Jun 26, 2009
  • 10406 Answers
SOURCE: Help is it possibol to upgrade lacie big disk
Maybe. If the current disk-drive has an IDE interface, then your 500GB disk-drive already is the largest IDE disk-drive ever produced. Or, if the current disk-drive has a SATA interface, then the sky (or the thickness of your wallet) is the limit.
Posted on Nov 15, 2010
  • 80 Answers
SOURCE: My iMac does not recognize
the first step will be to verify your power supply. When it is plugged to the wall power outlet, it should be silent (no hissing or high pitch noise) and the green light should be on on the power supply.. If it is not the case, replacing it might solve your problems.
Second step is to verify if it is an interface problem. Try using a different port on the drive.
If no success, start Disk Utility and look to the left if you have any mention of a drive of 1TB. If you do, the partition of your drive might be corrupted. You can try running First Aid from Disk utility if its available, else you will need to try a partition repair software or a Data recovery program.
There are a few available that you can get a free copy to see if the data is available before you buy.
Posted on Jan 12, 2011
I have a Toshiba 1tb external hdd (px1396-3t01) and when i connect it to my laptop i see a blue flashing light..The disc is not recognised by the laptop! what can i do..???????
How old is your laptop? Are you running at least Windows XP Service Pack 3? If so, Right-click My Computer, then left-click Manage\Storage\Disc Management. Do you see your 1TB HDD listed? If so, is it described as Unallocated Space. If it says that it's Unallocated, then right-click in the black area and choose format, then follow the prompts from there. You should probably format it as NTFS. Be careful not to accidentally format a drive other than your 1TB HDD. If you don't see your drive listed in Disc Management then double check your connections. If all is connected well, then you should probably return it to wherever you bought it.
Nov 30, 2009 | Toshiba (1TBEXT-HDD) (1TBEXTHDD) 1000 GB...
Lacie 1tb external hard drive into ps3 is not regconised
I have the same issue, however with my verbatim 500g its ok. i believe it is because the lacie is a desktop external and therefore is compatable with windows xp and 7 alone.
Verbatim is a "portable" external hard drive which makes it compatible with several different systems. I would suggest returning it, I just formatted my old verbatim harddrive and set up mediaasharing. Through my router. You can actually route the lacie harddrive by going to my computer and right click the icon. Next go to share with; advanced settings and allow all. Then when you turn your ps3 on search for media servers... I would suggest to google media server for ps3 to get it all seet up. GOOD LUCK
Jun 07, 2009 | LaCie Hard Disk 1TB Desktop with Hi-Speed...
Lacie extreme drive 1TB not recognised?
not sure if it will help, but try setting upnp active in your windows services. seem to remembrr my network assistant not being able to see my lacie network drive due to this in the past
Mar 14, 2017 | LaCie Big Disk Extreme (300797U) 1000 GB...
Lacie 1tb hd
You can try to boot up with Linux LIVE cd and plug on the external HDD.
Apr 24, 2008 | LaCie d2 Extreme 250GB External with...
Lacie 1TB external hd won't mount!
check wires connecting them together first, ok?
then, turn off the LaCie, connect to your MacPro, and then turn on the drive..
that should show as a mounted drive.
need printer drivers update?
Mar 09, 2008 | LaCie Big Disk Extreme with Triple...
Daisy chain my external hard-drives
I don't think these drives are designed to be daisy chained. This worked for SCSI drives, but not for USB drives.
Dec 20, 2007 | LaCie d2 Extreme 250GB External with...
Help with big extreme disk partition access.
Don't know what operating system your using but in Windows 7 and up it's easy to partition any drive even while windows is running.
Go to --> Control Panel\Administrative Tools\Computer Management\Disk Management and right click - set the size.
You can change it any time as long as whats in it isn't bigger than the size you want to make it. I have a 1 TB in this computer and that's how I did it after discovering that my old drive tools didn't work on this.
For any info on this procedure (or darn near anything you can think off) you can always go to youtube for step by step instructions.
Just watch a few first because some people are better teachers than others.
Mar 13, 2017 | LaCie Bigger Disk Extreme 2000 GB Hard...
Computers & Internet Logo
139 people viewed this question
Top LaCie Computers & Internet Experts
Raj Patel
Are you a LaCie Computer and Internet Expert? Answer questions, earn points and help others
