Question about Zebra Thermal S4m Dt Zpl 203dpi Rs232/par & Usb Label Printer
Says paper is out says ribbon is out. Both are loaded properly. Says head is open. It's not. Turned off and on. Received error code bblock v23
I am having the same issue. Please help. Not having luck with this printer. I thought it was easier to print some labels.
Posted on Feb 24, 2011
PLZ HELP ME MY PRINTER
Posted on Sep 21, 2012
I installed the Sharp ar-5220 and received an error message. CH keeps blinking and does not allow me to press any buttons.
Make sure your toner catridge is installed properly then open the side door and front door , and close it properly the code CH means your machine door interlock is open. Vote for this rate this
May 27, 2011 | Sharp AR-5316 Advanced Digital Imager...
Epson 800 Artisan printer was bought 2 years ago and I just opened the box set up the printer and it displays the following message. "An error has occured. Turn off all power. Check for and clear the...
I cant take credit for this fix, but it worked on my Artisan 800 with the same error. My error occurred right after a paper jam where i had a tough time removing the paper.
"Open the printer. See a 1/4" grey plastic band that is attached to the
print head. This is the CR (carriage return) guide that tells the print
head exactly where it is. During a paper jam it is sometimes pulled out
of the slit on the head carrier that it has to be in to tell the print
head where it is on the carriage. Pull the print head out about half
way, and with a flashlight look behind the head carrier. You will see a
small plastic u-shaped piece. Make sure the CR ribbon is INSIDE the
slit, or u-shaped device. When this happens you will usually hear the
print head hitting the side of the printer twice while it tries to
determine its position. Be very careful not to damage the ribbon. It
will slip back into the slot quite easily"
My print head didnt want to pull out, so i took a small inspection mirror and had a look behind the print head. Sure enough the ribbon was outside of the sensor. I easily pushed down on the ribbon gently with my finger and pulled it towards me just a little bit and it popped back up into the slot. Closed the printer up and no more message.
Hope this helps some other poor soul.
I’m happy to assist further over the phone at https://www.6ya.com/expert/larry_0800578514b4ccdb
May 11, 2011 | Epson Artisan 800 All-In-One InkJet...
Hi hp designjet t1100ps plotter showing error code 86:01, paper jam. but physically there is no paper or obstacle in print area. carriage block also moving one time right to left then the error code is...
This error can be caused if there is anything blocking the movement of the carriage. I just had a client with this problem on Tuesday and it turned out that they had opened the print head cover and had not closed it properly. This caused the metal latch to block the movement of the carriage. I would check that first, as well as look for any small bits of paper that may be blocking the complete movement of the carriage.
Apr 01, 2011 | HP Designjet T1100ps Printer
LCD Display "BBLOCK V23" ?
it;s not a problem, they come like that dy default.
Feb 10, 2011 | Zebra S4M Thermal Label Printer
I recently received lift off tapes for my nakjima typewriter. We have no user manual. I cannot get the ribbon and lift off tape to correct my errors. Please help or tell me if I am doing something wrong...
The ribbon may be noncorrectable, the knob must be orange or yellow. The lift off may be very old, or not properly installed, the dull side must face the paper.
DickyO
Sep 17, 2010 | Nakajima Office Equipment & Supplies
Error condition head open
First test this: remove the ribbon close head if the error goes away it is not your sensor. Most of the time someone has loaded the ribbon on a little to hard and broke the plastic tab that insure it loads correctly. With the tab gone you may get lucky and load it right sometimes and other times not this is why some ribbons work and some do not.
Aug 04, 2010 | Zebra Z4M Printer
Oven seems to have some sort of electrical problem
I just solved a similar probelm with my Kenmore oven, gave error code f7, among others. The control panel is manufactured by General Electric. Turned out that the control panel has a electrical ribbon that goes to the relay panel. The ribbon is actually two ribbons pressed together. They should easily pull apart. They are not insulated properly, and the ribbon leads short together or cross. Just put a piece of paper between them to act a an insulator. Good luck!
Nov 08, 2009 | Ovens
I have canon s 300 printer sr no FAYS 12715 some how it does not take paper and green and subsequent yellow light blinking
here are some error code list for you for your s300 printer.
Got this from slayo.com
hope this list will help you find answers to your questions. Goodluck!
ERROR CODE LIST
Error codes are displayed on the monitor of the host computer connected to the printer. For error
code display, keep the status monitor open.
Error Code
Error Corrective Action
1000 Paper out error Load paper, and press RESUME button.
1200 Front cover open error Close front cover.
1300 Paper jam error Remove jammed paper, and press RESUME button.
1401 Head ID error Replace print head, as it has failed.
1403 Head temperature sensor rank error Replace printer, as it has failed.
1405 Head EEPROM error Replace print head or printer, as one of the two has failed.
1700 Waste ink near-full error Replace printer, as it has failed.
5100 Carriage error Replace printer, as it has failed
5200 Head temperature rise error Replace printer, as it has failed
5400 Printer temperature rise error Replace printer, as it has failed
5B00 Waste ink full error Replace printer, as it has failed
5C00 Purging operation error Replace printer, as it has failed
5800 EEPROM/NVRAM error Replace printer, as it has failed
6810 EEPROM print head information error Replace printer, as it has failed
Operator Call Error
Orange lamp
2 times Paper out error Load paper, and press RESUME button.
3 times Paper jam error Remove jammed paper, and press RESUME button.
6 times Print head not-installed error Install print head.
7 times Print head error Replace print head, as it has failed.
8 times Waste ink near-full error Replace printer, as it has failed.
Service Call Error
Toggle blinking
2 times Carriage error Replace printer, as it has failed.
4 times Purge error Replace printer, as it has failed.
6 times Internal temperature rise error Replace printer, as it has failed.
7 times Waste ink full error Replace printer, as it has failed.
8 times Print head abnormal temperature rise error Replace printer, as it has failed.
9 times EEPROM error Replace printer, as it has failed.
10 times EEPROM print head information error Replace print head or printer, as one of the two has failed.
Sep 11, 2009 | Office Equipment & Supplies
Zebra 140xi II error
If you open the case there is a sensor that detects whether the head is opened or not that is connected to the open and close lever. Sometimes the tab that blocks the sensor when it is closed get out of alignment or comes loose or the sensor is jarred loose. Make sure the tab breaks the beam.
Jan 31, 2008 | Zebra Printer 140-751-00000
Zebra Thermal S4m Dt Zpl 203dpi Rs232/par & Usb Label Printer Logo
1,906 people viewed this question
Top Zebra Office Equipment & Supplies Experts
Marvin
Marvin
mukhtar21 shaikh
mukhtar21 shaikh
Computer Links
Are you a Zebra Office Equipment and Supply Expert? Answer questions, earn points and help others
