Question about Frigidaire Dryers
Hi, My stacked frigidaire model mlc275cw5 dryer give a loud squeaking sound whenever I use it, I don't know what is wrong and how to fix it. Please if someone can let me know how to fix it. Thanks Bob
  • 348 Answers
Sounds like your motor and/or pulley assembly are bad. Try turning the drum by hand. If it turns with some effort then you may have a drum bearing going bad. Does the squeaking sound start right away? Or does it start when the dryer warms up? If so then the bearing is going. If you can get to it spray WD40 for a quick fix.
Posted on Jul 11, 2010
I have a stacked Frigidaire FEZ831CA washer/dryer combo and when running the dryer it makes a very high pitched (AND LOUD) screeching sound. Any ideas as to what might be the problem? Thanks, Sean
screeching sound
Sean, Bad felt gasket body to drum, if belt drive on dryer, it could be worn and slipping, making a screech, or if not the belt, the drum may have a worn bearing on its hub allowing it to run crooked and rub where it should not.
Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
Disassembling reassembling stacked clothes dryer
Frigidaire Stacked Laundry with Noisy Dryer
How to Replace an Electric Laundry Center Dryer Drive Belt Kenmore...
Mar 29, 2016 | Frigidaire Washing Machines
Squeaky 4-yr old Frigidaire gas dryer
it's most likely the rear bearing that the drum rides on in the rear of dryer,you'll need the model number located around the door opening to order the right part.
Apr 25, 2010 | Frigidaire Dryers
The dryer squeaks loudly
The dryer has been over loaded too often. Try to determine if squeak is from the front or back. The felt pad dirty. If it is from the bottom, then the tension roller is binding and needs lubrication.
Nov 20, 2009 | Frigidaire FEX831CS Top Load Stacked...
Hi there. My stacker frigidaire model mlc275cw5
You have to take the front off and remove the drum. Our local appliance parts shop had the element in stock.
Oct 14, 2009 | Frigidaire FPDW1 Top Load Stacked Washer /...
Can I replace the dryer on my frigidaire stacked washer and dryer model # mlc275cw5?
I don't think you can replace the whole dryer section as a piece. If it just stopped working correctly you can replace internal parts to fix it. If it suffered some catastrophic damage (many parts destroyed) it will probably be less expensive to replace the whole laundry center.
Oct 11, 2009 | Dryers
Clothes dryer squeaks when running
Fixing Frigidaire model # FER641FSO, not stacking, but had similar problem. turnsout one of the coils came off. might try that...
Mar 01, 2009 | Frigidaire GLER331A Electric Dryer
Loud knocking on spin cycle with a little squeak
This is joyce
how old is your unit?
I just had to have my barrons replaced in my machine and it was sounding like a airplain taking off in house. so I know what you are going through. it cost about $80.00 for service call and $80.00 for barrons to replace in my machine I dont know how much for yours, just call your local dealership on monday and give them your model # and ser# and they will tell you, it took them over 2 hours to replace my barrons in my front loader, so its no easy job. if you need me to help you find someone to help just let me know,
thanks
and please grade my help
joyce
Feb 04, 2009 | Frigidaire GLEH1642DS Front Load Stacked...
Stacked washer dryer
It sounds like the belt or a pulley!
Anything more and it's not worth fixing if it's 10 years old .
Then better off replacing it with a newer machine which will be much more efficient!
Not worth the money to fix!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
Try You should call service.:
A&E Factory Service
1-800-905-9505
Nation wide / 7days/24 hours
Good work
Please give me a "Solution Solved Rating", in this site!
Thank You
Neil
Jul 27, 2008 | Frigidaire FEX831CS Top Load Stacked...
Dryers Logo
288 people viewed this question
Top Frigidaire Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Frigidaire Dryer Expert? Answer questions, earn points and help others
