Question about Garden
Lawn mower runs and then putters down, won't die but runs slow.
Murray gas lawn mower runs and then putters down, won't die completely. Also some gray smoke out of the exhaust. Seems like it might not be getting air, or the oil is wrong. I got it from someone who left it sitting in their garage all winter, with the gas tank filled low. I put in new gas but did NOT drain the old gas and added oil. But not much improvement.
    Master:
  • 502 Answers
Clean the air filter,wash out in turps if foam type,then wash in soapy hot water,then rinse,let dry,then put litle bit of clean engine oil in it,squeeze.drain all fuel,and put fresh in.may have to pull carb to bits and blow out,and reassemble.put new spark plug in.is it a briggs engine,or tecumseh?
Posted on Jul 11, 2010
Have a black/decker electric mower that motor slows and dies while mowing.
Your battery is in its death throes and not charging properly. Ergo, it runs "out of gas" fast.
Mar 07, 2016 | Electric Garden
I have a Murray 20 model 20213A with a Tecumseh engine. The lawnmower will start but it dies a few minutes later. What could cause this and where can I get a manual for this model lawnmower?
Use high test fuel without ethanol, and
Murray 22" Lawn Mower - Carburetor Cleaning, Nasty ...
? 7:33
www.youtube.com/watch?v=_dzcDZUh1MY
May 10, 2013 - Uploaded by mountainbikekayak But here is the link for the start up of this Murray had to replace the plug as well also ... as well: Murray 22" Lawn Mower 6.5 HP OHV -- First Start after Carburetor Cleaning - Part III - May 9, 2013 ... When I start it, it runs for 3-4 seconds and dies. ... Youcan also find you engine Model # online and view the ...
Sep 09, 2015 | Tecumseh Garden
New Ryobi trimmer putters out at full throttle
Absolutely it can. Weight can slow it down, Friction can slow it down,. There are many things that will do exactly what you are talking but the #1 thing would be a Gummed up Carburator. EVERYONE is having the same problems right now.
Apr 07, 2013 | Ryobi 2-Cycle 26 cc Curved Shaft Gas...
Murray 21hp/46
Sounds like a micro switch issue shutting the engine down, start by checking the seat switch, make sure the connecter is pushed well in.
Mar 12, 2012 | Murray Garden
I have no rpm's mower only runs slow. plugs foul with black carbon after 30 minutes. This is a murray 6.5 hp brigs any solutions
CARB NEEDS TO BE REBUILT. FLOAT IS STUCK.. AND CHANGE OIL AFTER REPAIR OIL WILL HAVE GAS IN IT AND IT WILL JUNK THE MOTOR IN NO TIME ... VOTE !
May 20, 2010 | Briggs & Stratton Garden
Need manual for Murray 20'' 3.5 hp lawn mower
sounds like its running out of gas. I changed spark plug, still sounds like its about to die
Apr 11, 2010 | Garden
I have a murray centina 4.5 lawn mower and my
keep washing out the tank with water ? then try a can of starting fluid use it too keep it running until all the contamination is out of it ? if it still wont run the you must r&r carb and rebuild it also check for rust in tank?
Aug 26, 2009 | Garden
Lawn mower chugging
better late than never, I have the same mower
there is no throttle control on these mowers, if you look under the air filter the throttle is balanced by a spring pulling in one direction and a lever controlled by engine speed. if the spring breaks or falls off the lever will wiggle back and forth, more gas if the engine slows, less if it speeds up. you end up going fast/slow/fast/slow etc.
The tension spring slows the switching down and smooths out the engine speed.
Jul 11, 2009 | Mtd 22" Yard Machine Push Mower
Garden Logo
465 people viewed this question
Top Garden Experts
roeb
john h
Marvin
Marvin
