Question about Cyberhome CH-DVD 300 DVD Player
Screen is blank sound is there
I have tried all connection possibilties red,white &yellow, s-video and composite cables. It all began when I was trying to set up the dvd to play on a hd ready tv. Is there a system reset besides the one described in the manual. I cannot get to the set up screen to start over
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
  • 242 Answers
Sorry, only one reset.
Posted on Jul 14, 2010
How can i connect a video camera to play through tv. my camera cables are red-white-and yellow. tv. is white-red- green-green-and red.
Your camera has three cables, red and white for stereo audio, and yellow for what is called composite video. Composite video puts the three color signals into one composite signal. Your TV sounds like it has a component video connection, which wants all three color video signals separated onto three plugs. They are usually color coded green, blue, red. Not sure if you mistook a blue outlet for green..... In any case, on my TV, it will allow me to connect a yellow composite signal to the green component jack, the first (leftmost) of the three component video jacks. Not sure if your TV will work this way, but it is worth a try. Otherwise, you can look up accessories for your video camera and see if it can output true component video and stereo audio, but I tend to doubt it will.
Aug 27, 2014 | Televison & Video
Have to use composante video cords to connect home theatre now colour is funny, would help if manuals were colour
If you are using "composite" cables, the colors are:, yellow(video), red(right audio), and, white(left audio). Which you would match you yellow to yellow(in and out), and so on.This set of cables will give you picture and sound. "Composite" cables are blue, red, and, green. They provide a higher quality picture but, no sound. If you use composite cables, it sounds like you are with the funny color, you have to make sure that they are "pushed " in all the way or you will get off colors. if you used these cables either watch yourself or have someone watch while you twist and try to insert cable and you will probably find one wasn't in far enough. When using component cables for video you will have to use an additional, either red and white composite cables or digital optical(better) cables for audio.
Mar 31, 2011 | Audio Players & Recorders
With the use of rca/video cables and the Samsung composite cable, how do I connect to an audio/video receiver(surround sound)
There are alot of different options when it comes to your connection basically , it comes down to quality and what in and out jacks are available to use. To me 'composite cables" were always the red, white, yellow combo where, yellow is video and red and white are l/r sound. "Component cables" were always red blue and green. The component cable provides a higher quality picture but, does not carry sound, like composite. To gain sound using component cables, you have to add either your yellow composite or a digital optical cable, again, depending on what your system will accept. HDMI carries both audio and video at the best quality and is easy. To answer the question for what you have if you have "composite"(red, blue,green) this will provide the best picture but, you will have to use the red and white "composite" for sound.
Mar 25, 2011 | Audio Players & Recorders
Conecting Wii to a Phillips lcd tv. rwy cords. but the picture is in black & white ?? i have sound. tried different connections eg: red to green conections & the only one that works is still black...
it sounds like you may be trying to plug a standard composit video cable (yellow) into a component video input (red, green, and blue)
these are actually two different connections. Most LCD tv's will have both options (sometimes there in weird different spots on the tv tho) if you don't have a standard RGB (red, white, and yellow composite video input) then you may need to purchase a component cable either at a local store or you can get one for $5 on Ebay
hope it helps!
~good luck!
Mar 16, 2011 | Nintendo Wii Console
Dvd movies won't play in color, are my connections wrong?
in most cases its the tv not the player make sure the tv is set to nstc not pal
Dec 28, 2010 | Samsung HT-X50 System
What are the red yellow and white cords for i have a xbox
The side with 3 RCA jacks, red, white, and yellow, is for connecting the USB to a composite video cable. The black connects to an S-video cable; you would still use the red and white plugs to carry the audio. At least the older XBox's had composite video outputs; you just need the composite video cable (which you may have as they came with many video devices (VCRs, DVD players, video cameras).)
If you need to connect this Video capture device to another type of output, you will need a converter. Component to composite video would be one option. However, you will have signal loss with any converter.
I hope this helps.
(Composite video cables: yellow carries video, red and white connectors carry the Right and Left audio)
Nov 22, 2010 | Sabrent USB-AVCPT Video Capture
Trying to add Wii, but no video only sound.
The manual says you can get an optional Component Video cable (RVL-011) for the Wii. There is apparently one unused Component Input on theDenon where you could connect it. You would still have to use the Red/White analog audio.
The Yellow is for Composite Video only. It's lower quality and not compatible with Component Video (3-wire).
In the short term, why don't you just run the Wii's combined Composite video / analog audio cable to the provided Composite Inputs labeled DVD, VDP, TV/DBS, VCR-1 or VCR-2 on the Denon?
It would not be necessary to have BOTH Composite and Component video from any device, much less the Wii.
Ponder this, why do you need to run the video from anything to the Denon at all if your TV has mutliple video inputs? TV's specialize in video, theDenon specializes in audio. You can always extend the Red/White audio cables to reach the Denon.
May 06, 2010 | Denon AVR-2802
How to connect to an analog tv
Try to locate the composite video/audio in(1) and audio (2) out sockets of your tv.
(1): three small round sockets, one yellow, one white, one red (2): two small round sockets, red and white. (only if you want sound from your tv on your marantz receiver)
You will need a composite audio/video cable: 51433a4.jpg
and a composite audio cable: db5db51.jpg
Connect the composite video/audio cable (1):
the yellow lead to MULTI OUT (yellow) the white lead to MULTI OUT (white) the red lead to MULTI OUT (red)
on your tv: connect these cables to the respective yellow, red and white input. (there should be a text like: game in/dvd in/ext in/AV-1/VCR) If all you see at the back is a big socket like this one: 0f41fcb.jpg
you will need a SCART-to-composite adapter, like this:
(2) To get audio from your tv to your Marantz, locate an 'audio out' (red + white round connectors) on your tv, and connect these pins using cable (2) to TV (complete bottom left on your Marantz).
Dec 13, 2009 | Marantz SR7002 6.1 Channels Receiver
Proscan 26LB30Q Vs PS2 = HELP
The red white and yellow cables are composite connections. The red/green/blue connections are component connections.
The playstation's composite connections consist of two audio connections- red & white, and a composite yellow video connection. The TV's white connection is the audio, and the red/green/blue are component video. You need an adapter that will connect the one yellow(composite video) to the three red/green/blue (component video) connections
Feb 28, 2009 | Proscan 26LB30QD 26 in. LCD HDTV
No sound when connected to dvd player
If it's only connected with component video cable (Red, Blue, Green) cable set then no audio has been connected. You will still need to run a set of audio cables (usually White and Red). The other option is to use Composite cables (Yellow, White, Red). A composite cable set has the video on the yellow cable and the audio on the white and red. Component video breaks the video into the three channels.
I want you to know that I'm not paid for this, I just like trying to help. If I've misunderstood your question or this information does not solve your problem I'd be happy to try to help more. If you do find this information helpful I hope you'll give it a positive rating. Thanks and good luck.
Jan 01, 2008 | RCA P52960 52" Rear Projection Television
Cyberhome CH-DVD 300 DVD Player Logo
66 people viewed this question
Top Cyberhome Televison & Video Experts
zappal
Demonic-2011
Demonic-2011
Are you a Cyberhome Televison and Video Expert? Answer questions, earn points and help others
