Question about Boating
I have a 2002 electric start, 9.9 Mercury Bigfoot. It is a tiller model..I am trying to make it into a remote controlled motor. I have a Quicksilver Control unit, key operated... Can I change this motor over to utilize my Controls? The last Mercury 9.9 ran from the controls..but it was stolen.
  • cksmiles Jul 11, 2010
    Thank you, you have been very helpful! I appreciate your research and not blowing me off!
  • 2,359 Answers
Check out this company for a remote steering kit.
Is your boat between 8 to 20'?
I hope the picture come though.
You may have to print this page to get the full view of the picture on the remote control cable requirement and measurement.
I only has the new Mercury catalog at home. I will check an 2002 book for official Mercury "remote / big tiller kit" for Bigfoot on Sunday morning.
I will email you more information around 2pm PST Sunday.
SS141 Teleflex Rack Steering
(Free Wheel) 14 Foot System
TheTeleflex Rack features the precision and comfort of four turnslock-to-lock and replaces 1984-date Teleflex and Morse rack steeringwithout dash modifications. (Requires use of included SSC134 Back MountRack cable.) For single station use only. Components are available fordual cable systems, but we recommend No-FeedBack steering for all dualcable steered outboards. Precise, easy 4 turns lock-to-lock. Fast, easyinstallation: back mount design allows quick placement in dash PLUSmounting hardware fits industry-standard Telflex "The Rack" and MorseCommand 200 rack holes.
How to measure for Rack Steering System
HowTo Determine Cable Length. For New Installation: Measure cable routingpath in boat as follows: A= Center line of wheel to gunwale. B= Dash totransom. C= Gunwale to centerline of cable connection at the center ofthe tiller. For Tilt Tube Mounting, add A, B & C + 6", round up tonext even foot. For Transom/Splashwell/Stringer Support Mounting, addA, B & C, then subtract 6" and round up to the next even foot.Measure Existing Cable as Follows: Measure Existing Cable as Follows:Measure Existing Cable as follows: Measure plastic cable jacket(casing, dimension "Y") in inches, add 30", and round up to the nexteven foot. Order that length cable. If you have any questions about howto measure for your cable call toll free. 1-888-923-6558
Cables available 8ft-18 & 20ft.
Please call for Additional Sizes
Posted on Jul 11, 2010
  • 3 more comments
    Thank you for this info. I'm looking for a kit to convert the outboard to a remote... as far as steering I can utilize a tie bar. I hooked the battery cables and gas line up, just need to find the way to convert the shift and throttle to control cables, choke and ignition conversion also. From the wiring diagrams I believe my Quicksilver controls are for an 8 pin .....my Bigfoot a 14 pin (once converted) ?
    The picture and/or link you sent did not come through.
    Thanks for any more info you have for me!
  • Vincent_G
    Vincent_G Jul 11, 2010
    Can you identify the color on the wiring inside the Bigfoot twist handle and internal wiring inside the QControl?
    Example:
    Purple, Green and Red are the default control wires to tilt sensor on QSilver.
    Making a 14 to 15 pin adapter is not a tough task but getting the correct pin-out is not easy.
    I will do my research if your are an above average do it yourself person.
    I'm above average in intelligence, so do some research for me. :-) Ok here is what I see as the wire colors
    Tiller Handle
    Red Yellow/Red
    Black Black/Yel
    Quicksilver
    Purple
    Yellow
    Red
    Red/Yel
    White/Black
    White/Blue
    Black/Yel
    Black going to ground and then to key
    Black going to ground and then to run switch
    Gray looping into cable ? Doesn't connect at control.
    I looked at the throttle connection and shift connection, I believe I can hook up the remote cables to both of these. Question... is there a cover that in the event I need to take of shift lever box, will go on to keep out water? Tiller handle same question.
    Thanks! Connie
  • Vincent_G
    Information on 6 pin system plug.
    Just for reference on color convention system.
    This is not what you need.
    Please bookmark it just for reference and compare not with other expert's color codes/wiring diagram.
    Link is HERE (6 pin plug)
  • Vincent_G
    This site has a lot of color code information.
    Link HERE
    I strongly recommend you to call QControl at
    Address
    QuickSilver Controls, Inc
    712 Arrow Grand Circle
    Covina, CA. 91722
    USA
    Phone
    +1 626-384-4760
    (International)
    888-660-3801 (USA Only)
    Fax
    +1 626-384-4761
    FAX
    Skype
    QuickSilverControls
    Sales Email
    sales@QuickSilverControls.com
    Support Email
    support@QuickSilverControls.com
    and ask for an adapter cable to mate both system.
    More information from iBoat forum.
    Black - All Ground
    Brown - Reference Electrode MerCathode System
    Orange - Anode Electrode MerCathode System
    Lt. Blue/White Stripe - Trim UP Switch
    Lt. Green/White Stripe - Trim DOWN Switch
    Brown/White Stripe - Trim Sender to Trim Gauge
    Purple/White Stripe - Trim "Trailer" Switch
    Gray - Tachometer Signal
    Black/Yellow Stripe - Shorting or Stop Circuit
    Pink - Fuel Sender to Gauge
    Red - Unprotected Wire from Battery
    Red/Purple Stripe - Protected (Fused) Wire from Battery
    Red/Purple Stripe - Protected (12 Volt +) to Trim Panel Control
    Purple - Ignition (Switch) to 12 Volt Positive
    Tan - Temperature Switch to Warning Horn
    Tan - Temperature Sender to Temperature Gauge
    Tan/Blue Stripe - Temperature Switch to Warning Horn
    Yellow - Starter Solenoid to Starter Motor
    Yellow - Stator to Regulator (Charging Circuit)
    Yellow/Red Stripe - Start Switch to Start Solenoid to Neutral Start Switch
    Yellow/Black Stripe - Choke (Enrichener System)
    Green with Color Stripe - Switch Box to Coil - Striped and Numbered
    White/Black Stripe - Bias Circuit (Switch Boxes)
    Blue with a with stripe
    Green with a white stripe
    Black with a white stripe
    Yellow wit a red stripe
    Yellow with a black stripe
    Black with a yellow stripe
    Brown with a blue stripe
    Grey
    Purple
    Black
    Brown
    Red
    I hope your can enjoy your boat soon.
    Please do not forget to give me a good rating.
Need the schematic diagram for YARD MACHINES electric rototiller model y155
anything in particular, or for everything in the world? ;>)
Google is your friend in such questions. The search query is
make model schematic
Then look at the images tab. If it is something complicated, the search query needs special treatment, click COMMENT under my post.
Jul 23, 2018 | The Computers & Internet
Mercury EFI Bigfoot 40 outboard motor turns over but will not start. Has fresh fuel. Any ideas?
Is the gas getting to the spark plugs? Is the kill switch clip in on your controls? If yes to all that try disconnecting the power for your kill switch so it's disabled. ( open the control shift box ) locate the two wires coming off the kill switch , follow them out until you find the bullet connectors ( quick connections ) pull the wire apart. And see if it starts. If it does you have a bad kill switch.
May 27, 2018 | Mercury Boating
I am re-wiring my electric start on my 15 hp mercury mariner Bigfoot outboard motor. There was a problem in the 8 pin plug - inline between motor and key.
Don't waste your money on unnecessary sources and unwanted repairs.. get this manual online at www.reliable-store.com u will know whether to repair or not, service it, and
how to
repair etc
Mar 07, 2018 | Mercury Cars & Trucks
2009 Mercury bigfoot 60 outboard will not go into gear? What could be the problem? Runs fine otherwise.
Good Morning Anna,
Start At The Control Box,
Safety
1.Disconnect The Battery
2.Remove The Kill-Switch Lanyard
3.Remove Engine Cowl
Whilst Someone is turning the propeller operate the control lever into forward gear.
Check- Does The Control Cable Move a Lever At The Motor Side
Yes/No
Move The Control Lever Into Neutral Does The Lever Move at The Motor Side Yes /No
If Your Answer Is No Then The Problem Lies With The Control Box And Cables.
If Yes Then The Problem Lies Between The Lever You See Moving In The Engine And The Internal Gear Selectors Inside The Gear Housing.
If You Are able To Open The Gearbox And You Require Further Assistance I Can Guide You Further.
Hope This Helps
Regards
Gordon
Jul 09, 2017 | Mercury Boating
Snow joe tiller does not run
Have you tried to reset the circuit breaker on the tiller?
Mar 14, 2014 | Snow Joe Sun Joe Tiller Joe Max 9 AMP...
The motor runs but the tines no longer turn
Does the drive shaft turn and the tines just spin around it ? if not then on the drive shaft there is a gear box and you need to open that up (without the machine plugged in) and check to see why the gears aren't meshing properly.
Oct 12, 2013 | Snow Joe Tiller Joe - TJ601E - 9 AMP...
2005 mercury 9.9 hp bigfoot motor
does it get faster with speed the clicking ? could be a bearing !
Apr 28, 2013 | Mercury Four-Stroke Outboard Motors, Model...
9-3 Aero 2002 won't start
How bad was the damage and where? Do you ahve any power at all?
Aug 03, 2009 | Saab 900 Cars & Trucks
What type of tiller
# Gas vs. Electric * Some smaller models are electric. o Limited range based on length of extension cord. o Electric doesn't have the same amount of power as a gas-powered motor. * Most of the larger models are gas-powered. o Gas-powered machines are more powerful. o Keep in mind that gas-powered machines require more maintenance, including refueling, engine fluid changes and refills, and winterizing in cold climates.
Aug 27, 2008 | Mantis Tiller
Boating Logo
377 people viewed this question
Top Boating Experts
Steve
Steve
ray gallant
Fabrice Wolters
Are you a Boating Expert? Answer questions, earn points and help others
