Question about Audiophase J520 CD Shelf System
My Audiophase model NO. CD2768, stopped playing c.d's. It just spins and after a while when it finally loads a c.d, it does a disc skip as if there isn't a disc in it.
    Genius:
  • 1,121 Answers
Is laser unit end of life. needs to be replaced. better send to repair store
Posted on Jul 11, 2010
I have Audiophase 5 cd player stereo model CD2768, It does not eject the cds or change discs and it keeps making a noise from a motor inside.
mechanism is probably jammed. if you have confidence to open it, go ahead, otherwise, leave it to a repairman.
Oct 16, 2013 | Audio Players & Recorders
My sylvania sdvd6655-B skips and then stops playing. What can I do to fix it?
first time turning it on and all see is mod: not sopported
Mar 16, 2013 | Televison & Video
My AudioPhase model CD2572 stopped playing cds.It just spins around and stops. What do I do to fix it?
I would try a good brand name CD lens cleaner first and see if that makes any difference.
Jun 02, 2010 | Audiophase J520 CD Shelf System
My Sony DVP-cx995v stopped playing DVD's
I had the same "Cannot play" problem - happened suddenly, I don't think I was doing anything unruly at the time.
After checking repair (exchange) prices in excess of $250 from Sony, I decided to open the cover to see if I could see anything wrong - normally a futile exercise with electronics except that in the past I have cleared errant disks that have lodged themselves near the drive/player at the rear of the library.
Upon opening and watching the library try to load and play I noticed the drive itself was not spinning the disk once loaded. It would sit for awhile, thinking about it I'm sure, then would unload and load the next dvd, again failing to spin.
I thought okay, maybe try to spin the dvd while in the player to see if it's jammed or otherwise hard to turn. It was not hard to turn and spun freely. In fact, when I put my finger through the hole at the exposed side of the player at the hub to spin the dvd, clockwise, it suddenly started to spin - and play!
I put the whole thing back together to test and all seems to be working fine at this point. Not sure what would cause the motor to stop spinning and remain in that state through poweroff/on cycles etc. but I'm sure this is not the last time I will have trouble of this kind.
I would note that when replacing the library back in its home on the shelf, be careful not to tip the library, especially toward the player area because the disks will spill out of the carousel near the player and become jammed when you power it on and attempt to load. A final tip of the library away from the player area may clear this if you hear the disks rolling out of their slots and you don't want to open the top again (it's a darned heavy box when fully loaded).
Jan 05, 2009 | Sony DVP-CX995V Multi-disc DVD Player
One more Time CD Jukebox Skipping
The fault is one or the other unit unless you have some sort of physical drag on the CD. There is a problem playing copy CDs too. Some work some dont.
Jan 04, 2009 | Wurlitzer Jukebox 1015 One More Time...
Dvd do not loads
Our started doing the same thing about a week after the warranty ran out. It has to do with the alignment of the discs being loaded. here's a work-around that works for us:
Open the tray
Choose which disc you are going to watch and use the Change Disc button to push the selected disc to the back (ie, if you want to view Disc 1, discs 3 and 4 will be visible in the tray).
Look down the center holes of discs 3 and 4... manually move your tray left-or-right to align the holes with the tray.
Push the Direct Play button on the top right of the unit for your disc of choice (Disc 1 using the example above).
hope that helps... I've searched for a while and played around with the unit (with and without the cover on) trying to figure out a way to re-align the tray, but no luck.
--JeD
Aug 20, 2008 | Samsung HT-WP38 System
No final spin
I haven't experienced that problem, but is it possible that the machine becomes unbalanced with the spinning load and then aborts the spin, so it doesn't finish? Has the machine been properly leveled during installation?
Apr 09, 2008 | Malber WD1000 Front Load Washer/Dryer
Player won't load any discs
I don't have a solution at this time. I have the same DVD player and mine stopped working this past weekend. It is doing the same thing as yours. I opened the case and loaded a disc and watched the mechanism. The disc won't spin. if you tap the disc it will start spinning and load and start playing. I thought I had fully fixed it. It will load most times but now the video and audio stutters as if the discs is spinning at varying rates.
Apr 06, 2008 | Sony DVP-NC85H Multi-disc DVD Player
Audiophase KP1000 MP3 player
CHECK AND SEE WHAT FORMAT THEY ARE IN . SOME SONGS ARE IN A DIFERENT FORMAT WICH CAUSES THEM NOT TO PLAY AT ALL OR THEY PLAY ONCE OR TWICE BECAUSE THE FORMAT IS TRICKED INTO PLAYING ..
Apr 18, 2007 | Audiophase MDP-1 Personal MiniDisc Player
Audiophase J520 CD Shelf System Logo
296 people viewed this question
Top Audiophase Audio Players & Recorders Experts
Jaime Hernandez
 Grubhead
Grubhead
Are you an Audiophase Audio Player and Recorder Expert? Answer questions, earn points and help others
