Question about Refrigerators
I have a 2 door cornelius zenith beer fridge and it blows air its just not cold enough ive got the dial on full.
BNewberry
  • 93 Answers
SOURCE: Frigidaire Electrolux Not freezing but fridge seems cold
You may be having a freon issue. Read some more info about this here. I type the longer version on my site. There are also factory service manuals to that may be helpful.
Appliance Outlet
Thanks,
Bill
Posted on Nov 25, 2008
tborn6
  • 700 Answers
SOURCE: fridge not cold enough
temperature sensor for the refrigerator section is on the top above the light. there3's dual evaps on this model and what may have happened is that the refrigerator froze up and the styrofoam gets broken when you try to take off. that causes the air to bypass the coil causingg it to freeze up.
Posted on Dec 20, 2008
SolutionGuy
  • 331 Answers
SOURCE: Frost in frostless freezer, fan not blowing into warm fridge
There are 2 things that cause these to not defrost. Kinda like the "Achilles heel" of GE fridges. The first one is the Defrost heater itself. And the second is the evaporator thermister (GE calls it a "sensor"). They are both very easy to replace. The part numbers are; WR51X10101 (heater) and WR55X10025 (sensor). If you don't have a local appliance parts retailer, just plug those numbers into a search engine. I highly recommend getting both parts because if the sensor hasn't failed yet, it will. The same goes for the heater...
Now for the fun stuff... Turn the temp knobs all the way counter clockwise to kill power to the fridge. Unload all the food from the freezer and remove all the shelves and the basket. Remove the screws that are holding the evap panel (the flat panel on the back wall, it's about 2 1/2 ft tall). Remove the panel to expose the evaporator. You'll see the heater at the very bottom of the evap connected by 2 screws, remove these and pull the heater out. Your new heater comes with instructions on how to install it.
After you have done that, look at the top of the evap. On the left, you'll see a little white sensor clipped to one of the evap tubes (shiny little clip), that has 2 wires feeding it. Remember which tube it's clipped to then unclip the sensor and pull it toward you. Snip the wires right at the base of the old sensor and completely remove it (leave the wires in there). Now separate those 2 wires and strip about 3/8" of insulation off. At this point, you are ready to follow the instructions that came with your new "sensor". Oh! and if it's all frosted up on the evap? Take this time (before you re-install the panel) to use a blow dryer and melt it away. All that'll be left to do is rebuild it.
There ya go! Job completion time= ~45 minutes. Easy breezy, right?
If this has been helpful, please don't forget to rate my solution. Thanks!
SG
Posted on Apr 05, 2009
freetek
  • 5568 Answers
SOURCE: Candy Fridge - The freezer part is not cold enough, fridge ok!
A couple of things to check-
- Is the condensor cooling fan running? This will be located to push air through the external cooling coils, wherever they are located.
- Does the auto-defrost timer work? It may have failed and stayed in a position that has left the heating elements (for defrosting) turned on.
- Does it seem to be running way too long and not turning off as it once did? This could indicate either a loss of coolant (would need recharge and leak detection) or the compressor is reaching its end of life. If the latter is the problem, expect a cost of $200-$400 US.
Posted on Apr 07, 2009
SOURCE: My sub-zero fridge is about 20 years old. About a week ago, as it got hotter here in New Orleans, the beer bottles were sweating and not cold enough. So I adjusted the knob, and the next day everythin
what a **** way to make money. why can't you people just help people, instead of making it sound like you really wanna help, when all you really want is to make a buck. maybe i'd believe in your little program (sort of like a prob-specific online "Car Talk"), if I had some testimonials. Otherwise, find a better idea, guys.
Posted on May 13, 2009
I have a 98 Buick Lesabre Limited. It blows Cool air, but not Cold.And also, I can't seem to make it blow out of the Center Dash Vents.
Cornelius, vent problem could be a pinched or loose vacuum line on controller,faulty AC vacuum motor, faulty AC programmer,etc. needs to be checked out by a good Tech, diagnosed and estimate on repair.
As far as vehicle only blowing cool air, issue could be blend door issue, plugged AC condenser core dirt/debris, low AC refrigerant, plugged AC lines internal, failing compressor, etc., again should be checked out, diagnosed and estimate for repair by a good Tech.
Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
1998 Buick Lesabre No Air From Dash Vents
http://repairpal.com/ac-vent-problem-346
Car AC Not Blowing Cold Enough Car Repair Information From MasterTechMark
My Car Is Not Cold What Could be Wrong Elite Auto Repair
Jul 15, 2016 | Buick Cars & Trucks
FRIDGE TO WARM MODEL ED22DWXTNOO
It's a circulation problem so either the fan in the back of the freezer(circulates freezer and blows cold into fridge) or the defrost element. If the element is faulty the rear ices up and air won't flow. If fan is faulty it's not blowing the cold air. Remove rear panel if no ice it's the fan if its full of ice it needs the defrost element(usually get termination sensor also depending on type) If you open the freezer door and hold in the doorswitch you should hear the fan running if its working.
Jul 08, 2013 | Kenmore Ice Maker Kit For Sears Whirlpool...
Hotpoint RLA51 fridge keeps freezing up
A fridge makes cold air in the freezer only and blows it into the fridge throu a little air door with a small fan, one of your temerature adjustments will open and close this little door and the other ajustment (the thrmostate) will turn on and off the compressor at what ever temperature you have it set for. if the little door is closed to much the cold air can not get into the fridge fast enough to make the temperature cold enough to turn of the thermostate. This will cause items to freeze near the air door as the air comming out of it will be something like -20C. to fix this it sometimes helps to open this little door more... something like "freezer temp warmer" and also to turn the "fridge temp warmer". if that does not do it, then the thermostate may be faulty, to test it slowly turn it down untill the fridge turns off, if it only turns off at the off position, replace it. also one last thing , sometimes the airdoor can frost up and restrict the air from blowing into the fridge, so you can unplug the fridge and leave the doors open for the weekend and let everything thaw out. then set all the controls for normal and plug back in. Make sure you do not leave the unit plugged in or sometimes the little door light can get so hot it may melt the plastic lining in the fridge.
Feb 08, 2013 | Refrigerators
Fridge is warm, was collecting water inside. Freezer is working fine. Increased temp but not responding. It is a bottom freezer model
send the model number off of the fridge,if the freezer is working fine then no air is being blown up to the fridge section,all it does is blow cold air from the freezer to the fridge section so either the door was left open and this is very common with a bottom mount freezer or the evap fan isn't blowing or on some models there's a damper inside the fridge section,the damper door opens and closes to let cold air in,when it reaches temp. the door closes,sometimes the door gets stuck in the closed position or the open position and the fridge freezes or gets warm depending on where the door is.first thing open the freezer door,do you hear the fan blowing,if not you could have a bad evap. fan motor,next look at the ceiling and on the packages,do you see frozen water droplets,if so the door was left open and the air ducts are froze up from the warm air getting in from the door being open and mixing with the cold air freezes up the air ducts,also stick your hand onto the back inside wall of the freezer,if there's like snow or frost on the inside back wall of the freezer you could have a defrost problem,bad defrost thermostat,heater,timer or board depending on the model or last a bad damper,when you open the fridge door there are air ducts usually up top and in the middle you should feel cold air blowing in,this is your problem the air isn't making it into the fridge section.if the door was left open,unplug the fridge,remove the food from the freezer and with a hair dryer heat up the back inside wall of the freezer and blow the hot air into the air vent holes in the back wall to melt out the air ducts,keep heating it up until you don't see any more water dripping,you can see the water dripping through the vent holes.so let me know what you find,send the model number and we can go from there.look up near the ceiling in the fridge section on the right hand wall and you should see a tag with the model and serial numbers,send the full model number so i can see what you have in your machine.
Jun 12, 2011 | Maytag Refrigerators
Fridge/freezer not getting cold
As the weather is getting warmer for many people their freezer2_bing.gif and/or refrigerator do not work right because of a dirty condenser coil...
Check out this tip that I wrote about that... it is a great place to start trouble shooting your unit...and something that you can do rather then calling a repair person to do a simple thing for you...
http://www.fixya.com/support/r4024657-refrigerator_condenser_coil_cleaning
http://www.fixya.com/support/r3885294-refrigerator_troubleshooting
http://www.fixya.com/support/r4023749-refrigerator_compressor_start_capacitor
heatman101
Apr 04, 2010 | Kenmore 18.3 cu. ft. Top Freezer...
Fridge is 12 years old or so and freezer has been icing up. The fridge is now suffering from global warming and is near useless, being the same temp as the outside air (it's summer here in NZ, yipee!). But...
IF THE FREEZER HAS FROST AND ICE NO COLD AIR WILL BLOW TO THE REF SECTION, YOU MAY HAVE A DEFROST ISSUE. UNPLUG THE REFRIGERATOR OVERNIGHT THEN TRY TOMAROW IF THIS WORKS IT WILL FROST UP AGAIN UNLESS YOU CAN LOCATE WITCH DEFROST PART IS BAD.AND REPLACE IT. HOPE THE SURF IS GOOD! ANYHOW
If you need further help, I’m available over the phone at https://www.6ya.com/expert/dude_653d05454b389bba
Jan 13, 2010 | Refrigerators
Freezer Cold Fridge not cold, vents clear of obstructions. Vent at top left of fridge making a clicking sound, some cold air coming out of vent, probably not enough,Freezer control on 2 ,Fridge control on...
Need to defrost fridge completely for about a day then switch on again. Possibly door was left ajar on freezer, or auger motor iced up due to product being to close to outlet..
Sep 21, 2009 | Whirlpool 25.6 cu. ft. Side-by-Side...
Maytag side by side refrigarator Mod, RSW2400EAE refrigarator
The fridge gets its cold air from the freezer through a vent(damper) between the freezer and fridge.The fan in the freezer blows air through it. There is a flap you adjust with the fridge temp. control. Make sure it's opening and closing when you adjust the fridge temp.
Sep 16, 2009 | Refrigerators
Ive got a beko frost free frige freezer,the fridge is at the right temp but the freezer has all of a sudden started to warm up? the fan is going round and blowing out cool air but not cold enough to...
all working fine now, i took everything out of the freezer and turnerd it off for an hour then i cleaned it out and hoovered round the back and swiched it back on and straight away it was blowing freezing cold air, its still going now so i think its ok! thanks.
Jul 05, 2008 | Refrigerators
Refrigerators Logo
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Marvin
Marvin
