Question about Whirlpool Duet GHW9150P Front Load Washer
I am getting a F1 code when pushing the start button on a ge duet sport
  • 15,935 Answers
F01 - There may be an internal problem with the control, attempt a Hard Reset.
Hard Reset - In some cases the control can be non-functioning or may not accept activation from the control panel. To clear and restart the control follow the these steps:
* Unplug or turn the circuit breaker off for 30 seconds.
* Reconnect the unit to the power source by turning the breaker back on or plugging the unit back into the wall outlet.
* Press the Pause/Cancel/Stop button twice to clear the "PF" in the display.
* Start a short cycle to check the operation of the machine by selecting a cycle and pressing and holding the start button until the machine starts.
The F01 generally indicates a failed electronic machine control board.
This error code can sometimes be caused by a glitch or power surge through the electrical lines.
You may be able to clear this code by unplugging the washer for 5 minutes.
If the code returns after plugging the washer back in, then the electronic machine control board will need to be replaced.
The procedure for accessing and replacing this control board is shown in this image...
http://media.fotki.com/1_p,wkwdftgtbkdgfrwxgtqsskgwtqkq,vi/ksrttqdqrxkssrqtgsd/1/1303472/5961857/image12917img-or.jpg
Be sure to unplug the washer before accessing internal components.
When you access the control board, I recommend transferring the wires from the old control board to the new replacement control board one connection at a time.
Once you have all of the wires transferred, remove the old control board and mount the new control board in the washer.
Reassemble and test the washer.
The "F01" error code indicates a communication error between the Central Control Unit (CCU) and the EEPROM onboard the CCU.
The "F01" can also be displayed if the onboard "Pump Driver" fails to activate.
Generally in order to correct this failure will require replacing the CCU.
There is no way to test and verify if the control board has failed.
The technical data sheet basically states to replace the CCU.
http://media.fotki.com/1_p,wkwdffkrdwtbgwsxgtqsskgwtqkq,vi/ksskgsfwrxksrttqdqr/1/1303472/5961857/image12923img-or.gif
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question%%$$
Posted on Sep 29, 2010
What does the f1 code on whirlpool duet sport mean
think its a thermal fuse code not a hard fix and not expensive
Aug 22, 2014 | Whirlpool Dryers
Whirlpool duet sport
F1 code is a control failure but lets not panic yet as a tech I have seen plenty machines work with this code, the click is what is important that tells me the contact in the heat relay closed the unit is calling for heat there is an open thermal fuse you didn't provide a model # so I don't know if gas or electric the I could tell you the location of the safety fuses.
Apr 02, 2014 | Dryers
F1 and beep on my GE spectra oven XL44 what is that
The F1 error code means that the computer thinks a button on the touchpad is stuck. Sometimes this can be resolved by making sure the touchpad connector fits tight into the control board. The F1 code can be cleared by pushing CANCEL/OFF. If it returns the touchpad needs to be replaced GENE
Aug 16, 2011 | GE Profile Spectra JGBP79 Gas Kitchen...
AI'm renting a place and have a Whirlpool Duet Sport front loader - last night it was in the final stage of a CASUAL wash cycle and it started making this HORRID noise, so I ran to it and hit the "pause"...
Check around the edge of the boot to see if anything stuck. You mus remove the spring around the boot to front panel and pull boot out of it'd groove. On the left side you will see the end of the tube coming down from the dispenser. Check to see if something is blocking it. I found a thong inside this tube one time.
Oct 16, 2010 | Whirlpool Duet Sport HT WFW8400TE Washer
My front loading washing machine started and then displayed f1, now it will not start at all and when I pushed the start button it beeps three times and does nothing.
The "F1" error code on the Whirlpool cabrio is quite common, and generally has to do with the control board. Replacing the control panel may resolve this issue. However, I believe Whirlpool is aware of the F1 issue with the Cabrio, and is fixing some machines for free. Please call 1-800-253-1301 for more details and see if you are eligible for a free repair.
Thank you !!
Aug 13, 2010 | Whirlpool Duet GHW9150P Front Load Washer
F 01 code comes on when trying to start another load. Pushed the cancel button and the machine shuts off also tried unplugging it and that does not work either
F1 error means a communication error, if you unplugged it, for more then 2 mins that should have work, but you also have to verify ccu operation by running a diagnostic test
Jan 11, 2010 | Whirlpool Duet Sport HT WFW8400TE Washer
Whirlpool Cabrio Washer Error message code F1
HELLO, Error code F1 indicates a control failure and most likely the machine control board will have to be replaced. Depending on when you purchased the machine, the board may be covered under extended component warranty.
I had the same F1 problem and they had to replace the control board and something relating to the balance. The tech told me this is a common problem.
Apr 06, 2009 | Whirlpool Duet 3.8 cu. ft. Front Load...
F1 code for duet sport
you have a bad machine controller, check the warranty in your use and care guide to see if the part is covered under manufacturer warranty.
Jan 28, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool Duet GHW9150P Front Load Washer Logo
Dan Webster
Dan Webster
Sal DeAngelo
