Question about Philips SAA7130 TV Tuner/FM Radio/Video PCI Capture Card (683728017118)
I do not get any channel when i search even though all the connections are ok
    President:
  • 2,571 Answers
Is this an analogue or digital tv tuner card.
If it is not a digital tv tuner card you wont get any channels.
UK has gone fully digital now and you need a digital receiver(freeview)
If it is a digital receiver you may just have a poor signal from your ariel
Posted on Jul 11, 2010
Hannspree TV tuning from aerial problem.
do you mean if you hooked up the tv with the aerial antenna can not get any channel? ok if just a white raster only and doesn't scan or tuned even manually and auto search, the cause is bad tuner.
Sep 06, 2012 | Hannspree Televison & Video
Can't get local channels even though it is hooked up to an antenna
You may need to elevate the height of the antenna or verify the wire connections. If you have done that, try another convertor.
May 06, 2012 | Westinghouse TX-42F430S Television
How to get wirless internet
Turn on your Wii.
  • 3Select Wii Options, which is located on the bottom left of the screen. This is the button with the Wii logo.
  • 4Select Wii Settings.
  • 5Click forward to the second menu screen using the blue arrow to the right.
  • 6Select Internet.
  • 7Select Connection Settings.
  • 8Choose an open connection, indicated by the word: "none".
  • 9Choose a wireless connection.
  • 10Determine the best option for you: Manual configuration or Search for an Access Point.
  • 11On Search for an Access Point, your Wii will search for a wireless network to connect to and will display a list of available networks. Networks identified with a closed padlock require authentication to join.
  • 12Select your network.
    • If your connection signal appears yellow or red, the stability or strength of the connection is not strong enough for the Wii's Internet needs. If possible, remove any obstacles between the Wii console and the Access Point or change the channel on your router to avoid interference.
    • If your wireless access point does not show up when you choose, Search for An Access Point, your router may have Broadcasting set to "No" or "Disable." Some routers also refer to this security as "Stealth" mode. You can either change your broadcast setting to "Yes" or "Enable," or you can manually enter the SSID in the manual setup screen of your Wii console.
  • 13Select Save and OK.
  • 14Select OK on the next screen and the Wii will preform an automatic connection test.
  • 15Wait for the Wii to connect and download any needed updates.
  • Browsing the Internet
    1. 1Go to the Wii shop channel and download the Internet Channel. This channel is free.
    2. 2Select the Internet channel from the block on the main screen and follow the instructions to browse the Internet. Feel free to go on any site you want, like Facebook or Twitter. (or maybe even this website!)
    Aug 19, 2011 | Nintendo Wii Console
    How do i tune the channels on a toshiba rc3910
    Hi
    Before tuning the set to auto tune mode, make sure the antenna or cable, whatever may, connected to its appropriate sockets at the back of the set firmly. To make it autotune:
    As new services are broadcast, it will be necessary to
    re-tune the television in order to view them.
    Auto Tuning will completely re-tune the television
    and can be used to update the channel list. It is
    recommended that Auto Tuning is run periodically to
    ensure that all new services are added. All current
    channels and settings, i.e. locked channels, will be
    lost.
    [1] Select the SETUP from the main menu by using
    Up or Down buttons. Press OK and Setup menu
    will be displayed.
    [2] Select the Installation from the Setup menu
    by using Up or Down buttons. Press OK and
    Installation menu will be displayed.
    ]3] Select Automatic Channel Scan from the Installation
    menu by using Up or Down buttons and press OK.
    A screen will appear warning that previous digital
    programmes and settings will be deleted. Select Yes
    and press OK to continue with the Auto tuning.
    The television will start to search for all available
    stations.You must allow the television to complete
    the search. When the search is complete the Auto
    tuning screen will display the total number of
    services found.
    * After search is completed for digital channels, a
    message asking whether to search for analogue
    channels appears on the screen
    ** Press the OK button to search for analogue
    channels. The following menu appears on the screen
    for analogue channel search
    OK.
    Jul 10, 2011 | Toshiba Televison & Video
    We have a TCL 32"
    It sounds as though the battery backup for the memory has failed, some sets use a cell battery like the ones in a pc or some watchs, some have a plastic cover with a cble which connects to the circuit board. Have a look around inside if you are competant, but be careful, make sure the set is switched off and if you dont know what something is then dont touch it. Even when switched off, some tv's can store enough voltage to kill you.
    May 02, 2011 | Televison & Video
    My wireless connections will not work! last night both lap tops and my daughters zip it were unable to establish a wireless connection. It happened once before about a month ago and were able to...
    OK, to clarify.
    Ethernet = modem?
    Wireless box = router?
    Do you have hardwire connection to router?
    Check the wireless settings in router with hardwire connection.
    Most routers use random channel search for wireless.
    I usually set this for to use one channel only.
    Stops random interference and connections.
    FYI: Most routers are on 2.4ghz - same as cordless phones and some hand radios - the frequencies over lap sometimes - even though they aren't supposed to.
    Microwaves will also disrupt signals.
    Apr 04, 2010 | Computers & Internet
    New ariel installed on communal roof, have tried auto store, some channels now missing, samsung 23" LCD TV LE23R8
     you must run "auto program search"/"auto store" again and let the TV find the programs. then put them in order and store.
    If you feel some channels are missing, try to find them manually. The auto store function sometimes skips programmes with less tolerant range, even if they are watchable in a fairly good quality. And search slowly and pay attention and go back if you feel you just skipped something. Good luck and lots of patience!
    A new aerial sometimes might mean loss of some channels.
    I hope it was helpful
    Apr 17, 2009 | Samsung Televison & Video
    How do i tune my philips 3590H philips dvd recorder into digital
    The User Manual for your DVD Recorder is available here... http://www.p4c.philips.com/files/d/dvdr3380_05/dvdr3380_05_dfu_eng.pdf
    Info related to your specific problem is as follows...
    Setting your TV channel
    programmes
    Before the recorder can start recording
    the TV channel programmes, you need to
    search for the available TV channels and
    store them in the recorder.
    Note: Make sure you have successfully
    made all the required connections to the
    recorder, the TV and Satellite Receiver/
    Cable Box (if any) and switched them on.
    Tuner settings can only be changed
    when there is no disc in the disc tray.
    A Press SYSTEM-MENU on the remote
    control.
    �� The system menu appears on the TV.
    B Use ���� keys to highlight
    { System Menu - Channel Setup }
    and press ��.
    Modify Channel Information
    Sort Channels
    Channel Search
    Edit
    Sort
    C Use ���� keys to highlight { Channel
    Search } and press OK.
    �� The automatic TV channel search
    starts. This process may take several
    minutes. Once complete, the total
    number of channels found appears on the
    TV.
    Automatically scan all the receivable analogue local TV
    channels and store these channels on the recorder.
    �� Use ���� keys to highlight { Channel Search } and press OK.
    �� The automatic TV channel search starts. This process may take
    several minutes. Once complete, the total number of channels found
    and stored appears on the TV.
    Modify Channel Adjust a stored TV channel to your preference, improve the
    Information reception and the sound quality of that TV channel.
    1) Use ���� keys to highlight { Modify Channel Information } and
    press OK.
    �� The channel menu appears.
    2) Use ���� keys to select one of the options.
    { Name } – You can use the numeric keypad 0-9 to select
    the channel preset number which you wish to
    change.
    – Use ����keys to change alphabet/ number and
    use ���� keys to select different entry fi elds, then
    press OK to confi rm.
    { Scan Mode } – Select TV channel search mode based on
    channel allocation or frequency.
    – Use ���� keys to select { Frequency },
    { Channel } or { S-Channel } (Special Channel),
    then press OK to confi rm.
    { Frequency } – Shows the frequency of the current TV
    channel.
    – If required, use ���� keys to start the automatic
    frequency search and press OK to confi rm.
    { TV System } – Set the TV system that produces the least
    distortion of picture and sound.
    – Use ���� keys to select a suitable sound mode,
    then press OK to confi rm. (See chapter “TV
    System Guide” at the back of this manual for
    more information).
    { NICAM } – Turn on or off the digital sound transmission
    system which improves the sound quality of the
    TV channel.
    – Use ���� keys to select { On } or { Off }, then
    Dec 12, 2008 | Philips DVDR3380/05 DVD Recorder
    Tv not working
    Can you confirm that you didn't have any input signal? My wife once accidentally pressed the reset button on the remote and the TV was stuck in this state. I tried to hook up an antenna to the digital antenna input and let the TV search for a channel. It did find a station and got out of the channel search mode, which was all I needed. Then, I unhook the antenna and continued to enjoy my DVD movie. I didn't check the manual. So, it's possible that there is a better solution. My TV was working fine and I think it just has a terrible user interface. I'm not sure about your TV's condition, though.
    Sep 17, 2007 | Sanyo DP26746 26 in. LCD Television
    Philips SAA7130 TV Tuner/FM Radio/Video PCI Capture Card (683728017118) Logo
    153 people viewed this question
    Top Philips Televison & Video Experts
    matt martin
    matt martin
    Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
