Question about Nokia N79 Cellular Phone
My n79 stops working after a few seconds when i turn it on and some times it shuts off and restarts, and the keys wont work only the on/off. it will charge the battery and still except calls but i cant answer cuz the keys wont work. or it does the annoying on/off thing.
  • claicorp Jul 13, 2010
    no tht didnt solve the prob cuz i still couldnt use the keys. i am wondering if my phone software is corrupted or has a virus?
    New Friend:
  • 41 Answers
Your keypad is in good condition? cause sometimes the keypad is still in press. if is not try format your phone but first back-up your files. when format press * key, call key and 3 key and power key. always update your phone to the latest firmware.
*#0000# to check the firmware
Posted on Jul 11, 2010
SOURCE:
Cruise control wont engage after restarting vehicle
The fact that the light comes on is a good indication that the electronics are working, the most common problem is a vacumn leak. This can be a damaged or cracked vacumn line, a bad check valve, or the dump switch on the brake pedal
Mar 28, 2015 | 2008 Buick Lucerne CX
My 1993 nissan sentra 1.6 wont run and check engine light wont turn on,bulb is ok
Could be any of several things. If the crank sensor is marginal and not sending pulses, the fuel pump is shut off. This is for safety. The pump is energized for a few seconds as key is turned in preparation for starting then engine must rotate normally to keep the pump on. If it stops, in a few seconds the fuel is cut off.
Aug 17, 2012 | 1993 Nissan Sentra 4 Door
2003 chevy malibu 3.1 shuts off and wont stay on
Check the idle air control valve for carbon buildup. Also check for a vacuum leak.
http://ricksfreeautorepairadvice.com/bad-idle-air-control-valve/
High idle rough idle Ricks Free Auto Repair Advice
Jan 12, 2018 | 2003 Chevrolet Malibu
How do you reset the oil change after the oil is changed
Turn key to on position,but do not start. Immediatly after turning the key on press excelerator to the floor three times within five seconds of turning key on. Oil light may or may not flash after this. If it does it will flash for about 5 seconds and go out. After five seconds of pressing the excelerator start your truck let run for a few seconds or drive if you feel like it and shut off when done. Your light should be reset. Restart truck to see if it worked. If it did not repeat process making sure pedal goes to the floor all three times in the time frame noted above. Piece of cake.
Apr 03, 2012 | 2002 GMC Envoy
How to open front cover on nokia N79
just update your phones firmware using nokia software updater. it will then be fine if this is a software fault.
goodluck
Oct 23, 2011 | Nokia N79 Cellular Phone
Hi I have a nokia N79 which stops working and freezes after turning it up , and it,s impossible to use it. each time to swich it off ; I did the *#7370# I did the reset factory, I install the antivirus and...
hard reset - hold the following buttons *, 3 (number button) and talk/green key. turn on the phone and do not release those buttons until you see the Nokia boot up screen. once you feel the phone power up you can let go off the power button while still holding all three buttons ...if this doesn't resolve the issue only option is to go to nokia store...for n79 this type of formatting will fix lot of software issues like this
Oct 02, 2010 | Nokia N79 Cellular Phone
1992 Chevy s10 wont shut off
if it was me i would go to a good salvage yard and see if they have one the same color as my and then take it to a locksmith and have my new steering wheel rekey to work with my key i have now and if you have a hard time finding one here is a place that sells only GM-parts Schram auto & truck parts number is 1800-292-1032
Feb 25, 2009 | 1992 Chevrolet S-10
97 chevy cavalier z24 2.4L wont start
sounds like a fuel pump. check for the car losing fuel pressure and you probably needed to turn the key a few times on off on to build enough pressure to start it. it wouldn't hurt to check the fuel pressure regulator as well a good throttle body cleaning won't hurt as well.
But worst case scenerio would be a timing chain with too much slack. those motors are known for it.
Feb 08, 2009 | 1997 Chevrolet Cavalier
Hello.My Motorola A1000 have a big problem.
Turn off phone.
Press and hold this 3 keys as in the picture.
Then release keys and wait few seconds.
After tahat phone should reebot.
May 08, 2017 | Motorola Mobility A1000
Nokia N79 Cellular Phone Logo
178 people viewed this question
Top Nokia Cell Phones Experts
jonathan mariano
jonathan mariano
Ekse
