Question about Microsoft Windows XP Professional for PC
Operating system problems - Microsoft Windows XP Professional for PC
  • 1 more comment
  •  Shayaan Tanwir
    Shayaan Tanwir Jul 11, 2010
    Please identify the problems!
  • Tony Rose
    Tony Rose Jul 11, 2010
    Hi, can you explain the problem your have, in as much detail as posible?
  • Yateesh Varma
    Yateesh Varma Jul 12, 2010
    well there are quite a lot of problem's in Operating system's, so please specify what exactly is the problem or post the error message that you receive....
    Brigadier General:
  • 10,406 Answers
... and the error-message caused by the problem is ___________________________________________ ???
Posted on Jul 21, 2010
I wanna know the solution to this problem
If the problem with your operating system wont reboot the system. You need to reformat it and re-install the operating system again. If you don't know how. Just call a technician to do for it...
Sep 17, 2011 | Computers & Internet
CANT TURN VOLUME UP ON LAPTOP
Hi...
Your problem may be due to some problems.
among these are problems in the audio driver or settings problem ataupau speaker on your computer's sound system has changed.
The first thing you need to ensure that the whole setting on your sound system is activated or the situation could possibly use.
if the same problem, do troubleshooting on your speakers using the ear phone to troubleshooting.
If the status remains the same, check your sound drivers or remove the existing driver and then re mamasangnya the updated driver from the manufacturer.
if all these measures are not successful, you need to reinstall the operating system (reformat) to identify whether the problem comes from the operating system or device. but if you do not want to take the decision to reformat the operating system, you can just change the sound device and all your problems should be done, unless there is a problem of your operating system from virus attacks, it is likely it also will disrupt the operation of a voice device.
TQ
Sep 16, 2011 | Computers & Internet
How can i fix the problem of my Dell mini 10...no operating system showed..when i can i get the hard disk and connect to other computer as slave i recover the files..when i use an external harddisk to load...
the problem is with in your hard disc since you can not install the operating system as the same time you can boot the system. you can recover files but you can not install the operating system their might be a bad sector. try to reformat the hard disc and re install the operating system. hope this may help good luck.
Jul 26, 2011 | Computers & Internet
The problems to my PC was i can't boot up cause the message show " Error.... loading operating system.
For this problem you need to reinstall the operating system of your pc
To reinstall the operating system you need *A copy operating system loaded in a DVD or CD
To reinstall *Insert the os CD to DVD drive *When your PC's logo appears press F12 *Select boot from DVD/RW++ *Select "INSTALL NOW"(in Windows operating system) *Select a drive in which the operating system is to linstall *Follow the Instructions....
Thank you
Don't Forget To rate
Jan 25, 2011 | Dell (E210882) Motherboard
Multiboot computer, Second OS unavailable after reinstall of XP
The problem can be solved easily if the second operating system was a windows based operating system.If it was a windows operating ,the following steps will give you a solution
In order to regain the boot path for old operating system
follow the following steps
1.Insert the Microsoft windows xp installation cd into a cd drive and boot the computer from the cd
2.In the microsoft setup page select the option of R ie recovery console
3.Select the operating system in the recovery console by selecting the operating system NO eg 1 and type the administrator password
4.Type the following command in command prompt
bootcfg /rebuild it will search for existing operating system in the hard disk and prompt you to add select yes .
5.once you completed type exit
May 06, 2010 | Microsoft Windows XP Professional
Problem with my operating system windows7 ultimate
You need to reinstall any other operating system.
If you have any imp. data then boot into safe mode, back up your data then reinstall windows
Jul 08, 2009 | Computers & Internet
Operating System Not Found
On my Windows 7 laptop, I have got "Operating System not found" with black screen, to fix problem,Windows Boot Genius helped me finally!
Mar 17, 2009 | HP Computers & Internet
The problem of software counterfeiting is occured in my PC
you are using pirated operating system or your windows is not registered, if the second is the case then you can register your operating system or you have to reinstall your operating system.
Feb 01, 2009 | Microsoft Windows XP Professional for PC
My ibm wont start up??????
The problem is going to be with either the operating system or the hard drive, and you will need an operating system disc in order to solve this problem. After acquiring an operating system disc you can try an operating system repair. If the repair doesn't take, then try to reformat the drive (NTFS) and install a fresh version of the operating system. If you have any problems during or after the format and fresh install, then the hard drive has failed and needs replaced. A hard drive failure is the most common with this type of problem, but occasionally the operating system will glitch and cause it. Either way you will need an operating system disc if you plan on fixing this yourself.
Jul 23, 2008 | IBM ThinkPad T21 Notebook
Operating system not found
Operating system not found? I have got Windows Boot Genius to fix problem safely!
Oct 14, 2007 | Fujitsu Siemens LifeBook S-6000 Notebook
Microsoft Windows XP Professional for PC Logo
19 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Piyal Perera
Piyal Perera
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
