Question about HP Officejet 6500 Wireless All-in-One InkJet Printer
I have done up a word doc with logos and want to print them onto an iron on transfer sheet of paper. The problem is I need the images mirror reversed. I have changed the type of paper in the set up to iron on transfer but this doesn't reverse the images. Just wondering if there is a way to do it on the printer
  • 749 Answers
After pressing the print icon go to properties and go to advanced settings, then at printer features just turn "ON" the mirror image.
Posted on Jul 11, 2010
Can HP Officejet 5740 print mirror image onto transfer paper?
Most printers don't do well with t-shirt transfer check HP web site for spec's on your machine
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
Oct 21, 2015 | Office Equipment & Supplies
How do I print a mirror image from canon pixma MG5250 mirror image?
In the printer driver settings, where you can select the paper type, you have to choose "other paper" and select "T-Shirt Transfer".
Jul 18, 2014 | Canon Pixma Mg5250 Imageclass Inkjet Scan...
Using a C3100 series HP inkjet printer, I'm trying to print HP Iron-on Transfer Paper but when I select that option, I cannot get the appropriate reverse image need for ironing on the transfer. What's...
The steps vary by printer. I've got a c7280 installed and the options for me are to click Print > Preferences > Advanced > Mirror image. When you click on Mirror image, you change it from 'off' to 'on'. Click OK to save the setting and print. Be sure to change it back after you're done printing your transfers.
I am an HP employee. I do not represent HP on this site.
Sep 14, 2010 | HP Photosmart C3180 All-In-One InkJet...
Where is my mirror image feature?
Looking at the User Guide, it appears that the Mirror Image option may require you to select "Iron-on transfer" as the paper type (see p. 96 in chapter 7):
To reverse an image for iron-on transfers
1.
On the File menu in your software application, click Print.
2. Make sure the HP All-in-One is the selected printer.
3. Click the button that opens the Properties dialog box.
Depending on your software application, this button might be called Properties,
Options, Printer Setup, Printer, or Preferences.
4. Click the Features tab.
5. In the Paper Type drop-down list, click More, and then select HP Iron-on Transfer
from the list.
6. If the selected size is not what you want, click an appropriate size in the Size list.
7. Click the Advanced tab.
8. In the Printer Features area, select On from the Mirror Image drop-down list.
9. Click OK, and then click Print or OK in the Print dialog box.
Jun 25, 2010 | HP Photosmart C7280 Laser Printer
How print iron on transfers
Yes, you need to "MIRROR" the image. Go to printer properties and select the ADVANCED TAB. Click on the MIRROR setting then print onto the transfer paper. The image should print out backwards like you are looking at it in a mirror. When you iron it onto a shirt, it will come out correct.
Jun 17, 2009 | HP Officejet Pro L7680 All-In-One Printer
How do I select mirror image (reverse image) from HP Photsmart
When you select Print and the Print window opens, select Preferences.
Click on the Advanced tab. Look for the "Mirror Image" option. It should be "Off". If you click on "Off" the drop down menu should appear to change it to "On". Click "OK" at the bottom. Then click "Print" on the Print window.
Don't forget to change it back when you are done. :-)
(Note: If the Mirror Image option is not on the Advanced tab, look on the Effects tab.)
Apr 22, 2009 | HP Photosmart C7280 Laser Printer
Setting up printer for reverse/mirror printing
I used to use iron on transfers all the time for different things. The setting is usually available whan you attempt to print the image you have different options in properties. Under the advanced tab in printer properties there is something called media type. You can set this to iron on transfer. To locate printer properties in XP for example go to Start>Control Panel>printers>view all printers right click on the printer you intend to use and select properties.
Mar 12, 2009 | Canon Office Equipment & Supplies
Mirror image
Printing Iron-on Transfers
Load the iron-on transfers.
With your document open, click File, then Print. The Print dialog box appears.
In the Print dialog box, click Properties, Preferences (or Options).
Select a print quality:
In the Print Properties dialog box, click the Quality/Copies tab.
From the Quality/Speed area, select Normal or Better.
Select a paper type:
In the Print Properties dialog box, click the Paper Setup tab.
From the Type area, select Iron-on Transfer.
If your software program does not have mirror or iron-on settings, select a print layout:
In the Print Properties dialog box, click the Print Layout tab.
From the Layout area, select Mirror.
Click OK.
To print your iron-on transfers, click OK.
NOTE: To prevent smudging, remove each iron-on transfer as it exits the printer and then let it dry before stacking.
Mar 29, 2008 | Lexmark P4350 All-In-One InkJet Printer
Brother mfc-440cn
by uesing a special software.
The mfc cant print any mirrow images by itself.
But why do you need to print a mirrow? as far as I remember is the print straight right thru. The foil has to be turned onto the shirt before you run the iron?!!!
Jan 29, 2008 | Brother MultiFunction Center MFC-440CN...
HP Officejet 6500 Wireless All-in-One InkJet Printer Logo
759 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
