Question about Fisher and Paykel GWL11 Top Load Washer
My washer stops when it is in the draining proses almost when it has draining all water and it wont continue
  • Fisher and P... Master
  • 713 Answers
Hi just read your posting.Now when the machine stops does, it beep and show a series of lights.If it does show lights that are lit then they will be in a row of 8 lights.Starting from left to right which ones are on?Is it the 2nd and 4th or the 5th and 7th ---etc---?Please reply with additional information and I can help you rectify this problem.
Posted on Jul 11, 2010
  • luisa_sgro Jul 13, 2010
    Hi just read your posting.Now the 2nd,3rd,and 5th lights on indicate that the Error is Comms.Error Time-out.This means that your Display is faulty or your Control module is faulty and last the Rotor position sensor is faulty.One of these parts is faulty on your machine,unfortunately there is no way to test for this fault on the individual parts except to change the parts one by one until the machine operates correctly.Sorry for the bad news but if you could please confirm the lights that are on when the machine beeps.Looking forward to your reply.
2nd 3rd and 5th lights on
Posted on Jul 12, 2010
Lid is not locking properly, washer sensor is overfilling, and the washer wont spin
Check door switch: If the lid switch is bad it will not drain or spin. Try this test: With lid open let it finish wash cycle. Press lid switch down with screwdriver. Washer should begin draining. Release switch. Motor should stop. Press switch a second time. Washer should start spinning as it continues to drain. If motor doesn't come on while lid switch is pressed, replace the switch. OR
http://www.youtube.com/watch?v=q942xn_2VXY
Pl click if helped.
Apr 28, 2013 | Whirlpool WTW4950XW Washer
Maytag ecoconserve wont stop draining
something might block the drain valve that prevent it to fully close those cause the water to continue to drain...
Nov 18, 2012 | Maytag CentennialR EcoConserve Top Load...
My washer overflows. it wont stop putting water
This assumes that you have a basic Kenmore / Whirlpool top load, direct drive, neutral drain (it doesn't spin until the pump removes most of the water) machine.
First, see the Sears parts site for your washer:
http://www.searspartsdirect.com/partsdirect/index.action
Enter your model number (110.########) and you'll see a list of major sub-components with diagrams and parts.
(The 110 means that it was manufactured by Whirlpool, you also need to enter the 8 digit model number)
Also see the Whirlpool / Kenmore Service Manual for these washers.
https://secured.whirlpool.com/Service/SrvTechAdm.nsf/2cd44500d572193285256a45004fd9d6/f7e2147fa98b28cf85257122007475cb/$FILE/L-55.pdf
It has testing procedures as well as a good description of how the washer works.
It sounds like a defective water level switch or water inlet valve.
See the following for how to release the console and cabinet on these machines in order to get to the switch for testing.
http://www.american-appliance.com/catalog/newsdesk_info.php?newsPath=16&newsdesk_id=131
Basically, what happens is:
When the washer is turned on, the water inlet switch is closed allowing water to flow thru the inlet valve. When it senses that the machine is to the level selected by the water level dial, the switch opens shutting the inlet valves.
If the switch or valve is defective, water will continue to enter the machine.
The Whirlpool Service Manual has testing procedures (basis continuity tests with a multimeter) for both the switch and valve.
May 10, 2010 | Kenmore 24032\24036 Top Load Washer
My washer wont drain
The washer's pump unit has stopped working. It may not me getting the signal to pump after the wash cycle (controller problem) or the pump has let go and needs to be replaced.
Aug 04, 2009 | Maytag Neptune MAH5500B Front Load Washer
Washer stops after aggatating and wont drain
My Kenmore 70Series washer goes through the wash cycle then just stops when it is to drain and then spin.
Jun 10, 2009 | Whirlpool Washing Machines
Washer continuously fills but drains at the same time during rinse cycle.
you have the drain pipe too low into tthe house drain pipe, raise the washers drain pipe up , you only need four inches down into the hous drain
also the house drain pipe needs to be as high as the lid of the machine before you put the washer drain tube into the house drain
you have a syphoning effect
Apr 20, 2008 | Washing Machines
Maytag washer
Check to make sure your drain hose has a loop at least as high as washer top.  If the drain hose is not looped higher than tub water will continue to drain and it won't stop filling.  If it doesn'y reach the correct fill level it won't agitate.
Oct 29, 2007 | Maytag PAV2300 Top Load Washer
Fisher and Paykel GWL11 Top Load Washer Logo
116 people viewed this question
Top Fisher and Paykel Washing Machines Experts
Gerry Harvey
Gerry Harvey
michael_t919
Are you a Fisher and Paykel Washing Machine Expert? Answer questions, earn points and help others
