Question about RTO Fuel Pump Carburetor Transmission Tester Gauge Tool
I change my fuel pump in a 1998 acura 3.5rl and now my motor only turn over, want start? Do the fuel pump have a reset or restart button, if so where?
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
    Scholar:
  • 71 Answers
It has a fuel pump relay and fuse. No reset tho. Can you hear the fuel pump kick on? If no than try changing the fuse or it could be other sensors that are not properly placed causing the fuel pump not to work. Another possibility would be putting a bad fuel pump in place of a bad fuel pump. Was the fuel tank cleaned when it was done? If not it could have debris floating around in the fuel pump causing it to do that.
Posted on Jul 11, 2010
My 98 gmc safari starts but won't stay started unless u keep putting gas into the throtal thing behind the airvent I already changed the fuel filter still doing the same thing help
It might be your fuel pump not getting fuel to throttle body. Disconnect fuel line to throttle housing get someone to turn car over and see if fuel is getting pumped up. If not the pump could be faulty or fuel filter blocked. Also check to see if you car has a fuel cut of reset button it could just need a reset.
May 22, 2015 | 1998 GMC Safari
1999 ford ranger no power to fuel pump new pump 1 month ago tryed reset button no change
Have you tried changing the fuel pump relay, or fuse? I have always went by one rule first and that is (never overlook the obvious) most of the time it's something simple hope this helps
Oct 10, 2014 | 1999 Ford Ranger SuperCab
1999 acura integra turns over but won't start. Replaced fuel pump and main relay, however the old fuel pump was good. Pump will not turn on.
Check a Chilton or Haynes manual for an impact switch that turns the pump off in a collision. Usually all you have to do is push a reset button on it. Once you find it. Also, make sure the main relay is the one, there may be a fuel pump relay, too..........
Nov 25, 2013 | Cars & Trucks
1998 expedition, won"t start, cranks,
Fuel pressure test , is there spark ? Videos on youtube showing how to check .
Jul 20, 2017 | 1998 Ford Expedition
Not firing when starting engine. first acted like it ran out of gas. fuel pump working is there a restart button on top of motor to help with this.
no reset button...but look for a fuel filter in your fuel line next to the intake, or farther down the fuel line....
Mar 02, 2010 | 1998 Jeep Cherokee
When i turn the key on the fuel pump comes on but when i start the car the pump shuts off and the motor will die in ceconds
fuel pump turning off is normal that meens it has reached its maximum presure in the fuel line, you might have to locate the fuel cut off switch in the engine bay normally located arround the firewall/bulk head, its normally a red or black button looking thing with a rubber top, try pressing that it might reset the fuel line to the injectors...this is just the start it could be more involved, but check that anyway hope that helps
Feb 12, 2010 | 1998 Pontiac Grand Prix
1992 acura legend wont start. Battery ok and starter motor turns over. could it be the fuel pump or a relay?
It could be within the firing, coil,rotor button. The rotor button can get worn down. I'm not sure if you have a distributor or coil pack, but either way these could be the problem just as well as the fuel pump. take the inlet loose at the fuel rail, turn engine over to see if gas is being pumped to the rail, if so then you know it's not the pump. which is $500+ to install
Jan 15, 2010 | 1992 Acura Legend
Need to find reset button on 1993 acura integra
there is no reset, often when the fuel tank is run low allot it fry's the electric fuel pump (it is cooled by the fuel it sets in), u are going to have to replace the fuel pump, it is in the gas tank.
Mar 13, 2009 | 1993 Acura Integra Hatchback
1998 Acura TL engine turns but will not start
check feul main relay it happen to me
Mar 12, 2009 | 1998 Acura TL
RTO Fuel Pump Carburetor Transmission Tester Gauge Tool Logo
132 people viewed this question
Top RTO Measuring Tools & Sensors Experts
jdthefixer
Steve
Tim Venetis
Are you a RTO Measuring Tool and Sensor Expert? Answer questions, earn points and help others
