Question about Wahl 8081
I want to replace the upper and lower blades on my wahl 8081.
What kind of blades to u buy for a wahl 8081
Posted on Sep 18, 2011
  • 3 Answers
Yes go to Sally's Beauty Supply they have the blades.
Posted on Jul 11, 2010
How to replace Wahl 9590-210 Pro-series blades
The entire blade sets simply pulls away and unsnaps from the body. The full new blade cartridge snaps back on the same way
Wahl Pro Series Size 10 Replacement Clipper Blade
Jan 22, 2017 | Wahl Health & Beauty
I'm going to Italy. Is it dual voltage?
Italy uses 220 volts, 50 cycles alternating current (AC). If your appliance works on both 110 or 220 then IT'S dual voltage and should work. If it only runs on 110 then you will need a voltage converter to use it on 220.
Dec 03, 2015 | Wahl 8081
Need to assemble
i need help in the wahl detailer 5 star the back piece broke where the scrues go so i need a new one some one know were to buy the back piece
Nov 04, 2012 | Wahl 8081
How to put my wahl 5 star detailer back together
my back piece where the scruess atach broke help please where can i buy a new back piece
Sep 26, 2012 | Wahl 8081
How to reassemble my wahl clipper model 8081
Okay, if you took this machine apart don't worry. You would have noticed when you loosened the first two screws closest to the blade (but still on the body of the trimmer) a small white part of the trimmer flew out...you were probably think wtf? Yeah, okay. If you took all four screws out, make sure you align the cord within its allocated space on the frame and screw in the bottom two.
1. Now, leave the top two screws about 75% loose so that you can slip the white piece back.
2. You will notice that there are two prongs sticking out of the hole where the blade is suppose to go. Make sure the "Detailer" enscribed on the front of the trimmer is facing the ground (or opposite yourself). Align the white piece so that the groves are facing the prongs and the other half of the white piece is facing yourself.
3. Slide the white piece down as far as reasonable, without forcing it. There is a little hook on the white piece, and a corresponding groove on the casing of the Detailer. Make sure that you align the white part so that the hook aligns with the groove, also make sure that you have aligned the groove on the back side of the white piece with the small round tip of the motor.
4. Okay, so this is the tricky part, you will probably be saying...the white piece is still sticking out. Well this is initally why it flew off when you took the machine apart. The blade acts a spring load for the white piece and the top two screws on the casing holds the remaing pressure forced on the white piece. What you need to do now is align the blade and its screws with the corresponding holes on the maroone casing and push the front of the blade down on the white piece and tighten the screws. The machine should now be working.
Hope this helps.
Oct 18, 2009 | Wahl 8081
I took my Wahl clippers apart to clean ......
Okay I fixed mine. this is I what I did and it works now take the big blade and put it on a table, take the little blade and put on top of the big blade if you look closely at the big blade you can see where the little blade went, make sure you allign the blades. next take the white thing dont know what you call it bit it rotates the blades put that on the little blade, take the gold piece align with holes to the big blade and take the silver piece allign with holes and then put the screws back in. when you put it on the clipper make sure the white piece goes in the hole that rotates the blades and sould go in fine
Jun 08, 2009 | Wahl 8550
Wahl 8081 Logo
240 people viewed this question
Top Wahl Health & Beauty Experts
shaveroutlet.com
shaveroutlet.com
Anglia Clipper...
Falling star
Are you a Wahl Health and Beauty Expert? Answer questions, earn points and help others
