Question about Bose Cinemate Digital Home Theater System Speaker
Bose Remote not working
My Bose Remote works everything BUT NOT the Interface did everything unplug, change batteries, etc. nothing
Called Bose that could not help with Troublesooting. Bose stated that I needed to send it in for repairs @ $75.00 + tax & S&H to come well over $100.00 then some. unless someone can tell how to fix the problem.
Seems like it is happing alot with this Product. Bose trying to make more money. was planning on buying the 5 spker system. now not so sure
  • tonyz Apr 22, 2008
    I have the same problem; my Bose Cinemate remote does not work with the interface, but it works with the TV and DVD. Tried everything, changed batteries but it does not work. Need Help!! Now I cannot use the Cinemate because it won┬┤t turn on without the remote.
SOURCE: Bose Cinemate Home Theater
Hello everyone! The Bose interface module is working again. All I did was unplug the power, wait about a minute and then plugged it back in. Whatever it did, it must have reset itself, so now everything is fine.
Posted on Dec 27, 2007
same prob, the tech was no help wants me to send in 75 bucks and pay for the shipping
Posted on Apr 28, 2008
SOURCE: Bose companion 5 problems
Have had Bose companion 5s for about three years. The external volume deveice in not active. If I unplug it, the sound goes dead. The indicator light is stuck on green and is very dim.. The touch feature does not respond nor does the volume. Sound is set very low an barely audible. Can I get replacement external volume control or is the problem inside the base unit itself? Any help out there with a similar problem.
Thanks JT
Posted on May 17, 2008
SOURCE: Unit will not power on
Unplugging it (for only a couple of min.) worked for me.  Press AUX, then ON.  Green light came on after I did these steps.
Posted on Jul 04, 2008
SOURCE: Bose 321 Remote not working
Pull off the front panel, be carefull there is a ribbon attached. Detach the ribbon. There are 2 ribbons attached to the front panel, one that leads to the IR (remote sensor) and other for the controls on the top of the unit.
Most likely the ribbon that goes to the IR sensor detached itself, this is common if the unit is dropped etc. Insert the ribbons (2) re-attach the front panel and the remote should work fine. You'll notice some tape on the IR ribbon, I suggest using some stronger tape, BOSE tape thats not very good.
This happened to me on my 3-2-1 GS II system and fixed it.
The remote will not turn on the Bose System intermitently.Need to turn the power off for TV & Bose unit & then back on for it to work.
If your system is plugged into a surge protecter, the Bose service guy told me that sometimes the Bose system detects a surge and automatically shuts down. Unplug the system for 5 minutes and then plug back in. This works because it happened to my system. I called Bose and this is what I was told. It worked!
Dec 27, 2012 | Bose Solo TV sound system - Black
I am having a Bose Cinamate Digital Home Theater. Original remote of this was lost and bought a new Bose Solo/cinemate system universal remote. It doesn't function with the interface. Will it real
If you can't get this to work, I suggest you try to return the remote and buy and harmony remote. For me it worked very well with everything including old audio amps and you can configure your own activities.
Oct 20, 2012 | Bose Cinemate Digital Home Theater System...
Bose Cinemate remote stopped working
Ive had the same problem, basically happens anytime we lose power or if it gets unplugged. Great speakers, poor design. Im not having any luck this time. Gonna try leaving it unplugged longer, like days this time. The remote feels like the problem, any button just causes the TV/VCR/AUX/ect row to blink, can't program it or anything. Seems like this is a common problem
Mar 16, 2012 | Bose Cinemate Digital Home Theater System...
Bose Sound Dock remote control - only volume works
My remote worked perfectly until I changed the battery. The original battery was CL 2032 and I replaced it with DL 2032. After replacing the battery, only the volume control works. The off button will only fade the sound while the button is depressed. Release the button, and the volume returns to the original level and the unit remains On.
None of the other buttons work.
If you've found a solution, please post it here.
Oct 03, 2009 | Bose SoundDock® (Black) Docking Station...
My Bose 321 series II is not responding to the control remote commands. Everything else does (TV, VCR,etc), but the BOSE receiver does not.
Replace the batteries from the remote control. Press and hold the TV button on remote for 5 seconds. If the red light shines bright, your remote is OK since it is showing it's programmable side. If unit still won't go on using the remote, reboot the whole system by unplugging the power cord and other wire from the Subwoofer. Wait one minute, then replug all and see if the system displays BOSE 321 in front when re-connected. If so, try the remote and if that doesn't work, your dead, the Infra red communication device from the unit to the remote is busted inside the unit and needs to be returned to the company like mine!!!!!
Jul 16, 2009 | Bose (321GS) System
Bose Cinemate green led won't come on.
Do the same thing by unplugging the power, but also unplug the interface module (box with red/green LED light) from the sub woofer / bass module, and wait 30+ seconds. Plug the interface module back in first, and screw it in as tight as possible. Then plug the power back in and try the remote. This should fix your problem. :)
If this doesn't fix it, you will have to purchase/replace this module through Bose. (anywhere from $40-$60 if not under 1-yr warranty.) If you're still under warranty, it's a free replacement.
Jun 08, 2009 | Bose Cinemate Digital Home Theater System...
Remote stopped working
already tried a new remote and new batteries. bose says the ir bulbs need replacement so i'm taking it in. shucks.
Dec 23, 2007 | Bose (321GS) System
Nov 18, 2007 | Bose Cinemate Digital Home Theater System...
Bose Cinemate Digital Home Theater System Speaker Logo
567 people viewed this question
Top Bose Audio Players & Recorders Experts
Electro Med Services...
Are you a Bose Audio Player and Recorder Expert? Answer questions, earn points and help others
