Question about Jabra BT2050 Bluetooth Headset
Cant pair to cell phone
What should i do to connect it if i dont know the paring code
  • 2,359 Answers
According to the FULL INSTRUCTION SEE PAGE 6 HERE
The default code is 0000.
Posted on Jul 11, 2010
Where is the paring code
If you need to enter a paring code to connect your bluetooth headset you will find it in the documentation that came with the headset.
Having said that... 99 times out of 100, the paring code is four zeroes (0000). This is so common that most newer headsets don't even ask you to enter a paring code.
If that does not work, you'll need to have, or obtain the manual or setup guide from the manufacturer's website. Go directly to your manufacturers website, click on support, technical and manuals (different on every manufacturers site, so have patience).
Jul 06, 2016 | Radio Communications
I need a pairing code for a Logitech Bluetooth mouse M-RBB93
If the mouse refuse to connect, you should delete it from your Devices, then re-add. (for exact directions, Weldon Dube below has awesome step by step directions)
When it comes to paring, it uses the basic paring code of 0000 (4 zeros)
Jan 10, 2012 | Logitech M-RBB93 Mouse
Dont know how to put jabra bluetooth earpiece it into pairing mode
Start with your headset turned off. Then, press and hold the answer/end button, until the indicator light is steadily lit in blue. It is in paring mode now. Then, make the bluetooth application on the device you want to pair your headset with, search for new devices. After a while, the BT350 headset should appear in the device' screen. Select it and make it connect. If a pairing code (or PIN, or passkey) is requested, enter '0000' (four zeros).
By the way, if your headset's user manual happens to be missing, feel free to download it from this location.
Hope it works for you.
Regards, Carlos
Jul 08, 2010 | Jabra BT350 Wireless Headset
Paring the Bluetooth
You have to enter the security code into your phone once the phone receives the connect to signal from the radio, the default code is 1111
Apr 26, 2009 | Pioneer AVIC-F700BT Car GPS Receiver
How to connect my bluetooth phone to my audi bluetooth car radio
For most bluetooth devices, the default paring code is 0000.
Mar 19, 2009 | Nokia 3110 Cellular Phone
I dont know how to make my blue tooth go into discovery mode i just dont
Press and hold the phone key in till the lite turns purple then open up the mike and it will be in "paring mode"
Mar 16, 2009 | Motorola Mobility H700 Wireless Headset
HELP....
Well my user manual for HBM-550 says:
Prior to using the Headset for the first time, you must pair it with a Bluetooth enabled handset.
With the HBM-550 off, press and hold the Pwr/End button for 5 seconds,
You will hear two short beeps and the LED indicator will flicker in red and blue alternately, when the divice enters Paring Mode.
Using your Handset, find the Bluetooth Menu and "search for" or "add" new devices.
Select "LG HBM-550" from the list of devices and pair it with your handset.
When asked for the pass/PIN code during the paring procedure, please enter "0000" (4zeros).
Once paring has completed successfully, you will hear a beep.
After paring successfully, be sure to "Connect" to the HBM-550.
If you want to pair with other devices in the future, the headset must be placed in pairing Mode.
If the HBM 550 is in "Paring Mode" for 3 minutes, without being paired to a device, the Headset will automatically turn off.
Aug 13, 2008 | LG HBM-550 Wireless Headset
Pare help..
Please ask the smartbro for the router, from the router then connect to switch, maybe u should by 8 port switch which i recommend the d link or the linksys switch. do you know how to terminate the UTP cable?
In each connection u need a 2 Units RJ 45, You should a crimper to terminate it each end point.
guide to create network cable.
http://www.wikihow.com/Make-a-Network-Cable
U don't need a server as long as you have router. bale ang kailangan lang ay pangalan ng bawat computer ay iba iba.
smart bro --router--switch(8ports) --Comp1
-- comp2
-- comp3
-- comp4
-- comp5
-- comp6
-- comp7
sana makatulong. melnavz
Jan 29, 2008 | Toshiba Satellite A100-S8111TD Notebook
My phone
Pairing your Cell Phone to your
Bluetooth Headset:
(FROM Bluetooth Headset)
1. Make sure Bluetooth Headset is fully charged!
2. Hold down talk button (center button of headset) up to
(Five) 5 seconds, then WAIT until you see a solid blue
light then immediately flip open earpiece part of headset.
THIS MEANS the HEADSET IS NOW IN PROGRAM MODE.
AT THE SAME TIME/ WHILE BLUETOOTH
IS STILL OPEN & IN PROGRAM MODE….
(FROM CELL PHONE)
1. Click on “Menu” (Left Button)
2. Scroll to Bluetooth icon. (Lower Right Hand side of menu)
3. Click “Ok” button
4. Then click on “My Devices
5. Click “OK” again
6. Select “FIND NEW”: Cell phone searches/connects to pair up
with Bluetooth Headset.
7. Once your Cell phone discovers your new headset, select
ADD” or click on the recently paired headset device.
8. You will then be prompted to enter a pairing code.
Use either..
a. 0000 or
b. 1111 or
c. 9999
Congratulations on paring/ connecting your new
Bluetooth Headset
w/ to your new Cell phone!
Jan 16, 2008 | Kyocera Switchback KX21 Cellular Phone
Jabra BT2050 Bluetooth Headset  Logo
302 people viewed this question
Top Jabra Radio Communications Experts
Greg Cann
Greg Cann
Michael Vincent Cruz
Jerry Greenberg
Jerry Greenberg
Are you a Jabra Radio Communication Expert? Answer questions, earn points and help others
