Digital camara has a yellow lined sreen,can get into menu ,but can't make out what is on the screen.just shows the yellow lines and the blurred lines of the menu
HI,
The first thing i want you to try is remove the battery for 10min and then put it back.If you still face the problem then i blieve you wil have to get it repaired.
Goodluck..
No,just remove the batteries and then wait for 10min,then put it back in and turn it on.
I hope i am clear..
Yes,may be it can be the cause of the problem.Try changing it to 60.Did this problem occur when you changed the settings?
I hope you have a user manual it will help you out.If not i'll give you the contacct details of them and you can just sned them an email requesting for a manual and they will send it to you.
Did you try removing the batteries for a few minutes?
May i please know the model and the make of the product in details so that it can help me resolving the issue is a more prompt manner
Do a flea power this will resolve the issue you have to release the static power of the camera. To do so take the battery out and push the power button or turn the power button on for 1 minute without having the battery in and that should take care
incase that doesnt help please update me the status ill provide more solution and if fixed dont forget to rate fixya.
Thanks
i've got a meade captureview 8x42 digital.don't understand if i take the batteries out how can i turn it on then
also would having this camara set on 50mhz cause this problem
