Question about Car Audio & Video
CD player not working, but gives error message: ICDE
I have a Hyundai Tucson 2007 with stock CD player MP3 WMA. When I recently tried to put a CD in it wouldn't take it, and when I helped push it in a message came up: ICDE I can't play anything on it, not even radio. Tried replacing the audio fuses, but no luck, although when I replaced them it spit the CD back out. It still displays the same message. Any suggestions?
    New Friend:
Easy fix - firstly, you'll need to remove the stereo to get to the serial number. Have the following tools ready, either: a) 2 metal rulers b) 1 metal ruler and 2 kitchen knives you don't mind bending c) 2 kitchen knives and one fork you don't mind bending d) possibly 2 forks will also work
Okay, here goes (I used option c):
1) use a kitchen knife to remove the black plastic border around your stereo. 2) on either side you should see the metal bracket and a smaller metal flap - place your fork between the bracket and the flap on the left hand side. jam it in quite far, so it can release the internal clips. 3) place your knives so that the flat (non-cutting) edges are touching and jam it in on the right side (basically so it works like a metal ruler for the clips, which I didn't have on hand) 4) use leverage to prise the whole unit out slightly. You can then remove it by hand. You don't need to remove it fully, you just need to see the serial number, which is on the top in the upper, right corner. 5) take the last 4 numbers of the serial and do some maths! You need to add 1/2/1/2 to the numbers in sequence. For example, if the last 4 numbers are 9462 then your maths should give you 0674 (9 1, 4 2, 6 1, 2 2). Another example is 1234=2446. Remember the number you end up with!! 6) start the electrics of your car (2 key turns). The radio should say ICDE. 7) For this example, pretend the number you ende dup with is 0674. Press the "1" on your stereo until the first number after ICDE says 0. Press "2" until the second number says 6. "3" until the third says 7 and "4" until the fourth says 4. You should end up with the display saying: "ICDE0674". Press the "5" on your stereo and MAGIC, your radio is working again!! 8) push the stereo back in at re-attach the face plate.
p.s. I accept no responsibility if you get zapped or break anything while trying this. I may feel a bit guilty (but not responsible, remember) if I hear on the news that you got zapped though. enjoy your tunes!
Posted on Oct 12, 2010
  • cadegirl Aug 25, 2011
    Brillant advise...thank you SOOOOOOO much!!!!!!
2007 Tucson radio will not work after car was boosted?
always boost wit ALL accessories OFF check fuses otherwise you may have fried the radio
Nov 14, 2014 | Hyundai 2007 Tucson Radio
2007 Hyundai Tucson - no hot air from heater.
Your car is low on coolant most likely.
Nov 04, 2014 | Hyundai 2007 Tucson
Cd player error
so is this a stock RAD/cd?
stock JBL 6 disk player in dash>? or? what? name and model #
mp3 and wma format. but not DVD
or
JBL premium 4-disc in-dash CD changer
io the single disc player, 3 kinds sold. new.
and now comes the big question.
TELLS where you got the disk, or name it, or tell how it was made if home made. we dont know that.
is said CD a CDDA? or not. (always try CDDA first)
is CD a real music disc. from a real store, CDDA, is that.
or CDR, or DVDr, or CDRW, or other record-able media
is music MP3? files.
see, the old units dont play modern media.
try 2 real discs, not scratched.
do they play?
one other way, is to name the radio, brand, like JBL then get the
p/n off it. (hard) then look up the product data sheet on it,
bingo, what it can and can not do is there.
but this does it all, mostly
does what yours will not do.
http://www.flyaudio.net/product_id.asp?id=113
Jan 02, 2014 | 2007 Toyota Camry
Hyundai mp3 player mp3-03 error 5
you could try to power down the radio, by either pulling the fuses or disconnecting the battery. But usually if everything else works, you will need to have the radio replaced or sent for repairs
Feb 25, 2012 | Hyundai Cars & Trucks
I have a 2007 hyundai accent with factory radio with single cd player.i will play a cd then try to play an other cd. it takes a long time loading then error message. i have no codes after error...
Probably the player mechanism is defective. After all, it is a 2007 Accent. Inserting CDs right side up and upside down does nothing to improve operation.
Jul 18, 2017 | Hyundai Accent Cars & Trucks
What does ICDE mean on a Getz stereo MP3 player
Did you remove the battery or jump-start the car recently? that gives your radio an ICDE error.
To fix it: Easy fix - firstly, you'll need to remove the stereo to get to the serial number. Have the following tools ready, either: a) 2 metal rulers b) 1 metal ruler and 2 kitchen knives you don't mind bending c) 2 kitchen knives and one fork you don't mind bending d) possibly 2 forks will also work
Sep 26, 2010 | 2007 Hyundai Accent GS Hatchback
I can't get my MP3 to download and play WMA Format
Here is the asterisk behind WMA compatibility - there are two types of WMA files - protected and unprotected. 90% of WMA files are DRM-protected, hence they are either not usable in mp3 players that say they can play WMA's, or the song has a DRM restriction on it that prevents it from being played on an mp3 player without purchasing additional rights.
To avoid the problem completely, only download songs that are in mp3 format. It may be more expensive initially, but they are better in the long-term - even if you found a WMA file that eventually works with your mp3 player, the protected WMA files have an expiration date, so they would stop working after 30 days, 90 days, 1 year, or 2 years depending on the specific license for each song. Mp3 files never expire, never give you error messages, and work with nearly (if not all) 100% of mp3 players.
-Tha Mp3 Doctor
Mar 30, 2009 | Audio Players & Recorders
Problem with CD player
get a good cd player not a stock one sorry best i can do
Mar 13, 2009 | Hyundai Motor 2002 Elantra
Car Audio & Video Logo
1,628 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Marvin
Marvin
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
