Question about Samsung TL240 Digital Camera
My samsung tl240 lens is stuck wont retract cant take pictures cant zoom. Was neverdropped just froze an stopped working
  • 3 Answers
<div><br /></div> <div>remove the battery and memory card. blow out any dust. put back the battery in and turn it on without the memory card. see if you can take pictures, if so then its your memory card. Check the link below. </div> <div><br /></div> <div>http://ars.samsung.com/customer/usa/jsp/faqs/faqs_view_us.jsp?SITE_ID=1&amp;PG_ID=0&amp;AT_ID=264556&amp;PROD_SUB_ID=0&amp;PROD_ID=1008&amp;EMAIL_ID=</div>
Posted on Aug 29, 2010
  • timetocallit Mar 11, 2011
    Had similar problem with my SAMSUNG TL240 and searched for solutions. Thank you for the answer. IT WORKED!
My Samsung tl240 lens won't go back in and it won't turn off.
I'll turn it on but the lense wont go in and the screen would be pitch black.
Oct 11, 2010 | Samsung TL240 Digital Camera
Samsung TL240 touchscreen not working
http://ars.samsung.com/customer/usa/jsp/faqs/faqs_view_us.jsp?SITE_ID=1&PG_ID=0&AT_ID=264556&PROD_SUB_ID=0&PROD_ID=1008&EMAIL_ID=
Jul 29, 2010 | Samsung TL240 Digital Camera
Lens stuck out
The lens has probably got something in the retraction mechanism that is stopping it retracting. This can be something as simple as sand or grit or as a result of a drop or knock. In most cases the camera will need to be stripped apart to remove the lens assy before it can be repaired. This is best left to a professional camera repair shop.
Jan 22, 2010 | Casio Exilim EX-Z77 Digital Camera
My batteries run out on my samsung d1070 camera and now the zoom is stuck and the camera wont turn on it just beeps
I suggest that you place the camera in a safe place ware the extended lens will not be damaged, than remove and recharge the battery. After replacing the battery, the lens should automatically retract and you should be good to go. Hope that this helps, God bless...
Aug 16, 2009 | Cameras
Hi, my zoom is stuck out and won't retract.
Your lens motor is most likely burnt out. The only way to continue taking pictures is push the lens in manually, You may have problems with the focus after doing this, so just turn the lens manually until you are zoomed in properly. If you have a warranty now is the time to use it.
Jun 26, 2009 | Fuji FinePix A600 Digital Camera
Zoom wont adjust
Hi there. I can help you with that.
The number one problem with cameras with lenses that won't retract or or move out into position is dirt, grit or sand in the lens mechanism. The best way to fix this is to get an air compressor and put the tip up the lens and blow air into the space around the lens. Run the tip of the compressor nozzle around the lens and turn the camera back on. See if that helps. If it doesn't do it one more time.
If it helps, great. Stop there. If it doesn't help, let me know in a comment and I will tell you a couple more things to do. I want to wait, because they are things that you should only try if you are ready to trash the camera, but they usually work. Hope the air compressor works.
Rob
Feb 21, 2009 | Canon PowerShot SD750 / IXUS 75 Digital...
Zoom error
worked on allot of fuji's. first detease, a gear is slipping in the lens retract assembly due to a crack or wear or jam
2nd guest .. zoom errors means its really stuck tight
the gears can be ordered and replaced and one more possibility is that the motor that drives the gear is bad
Also if dropped or zoom lens jammed hard... lens assembly needs total realignment or replacing..
May 23, 2008 | Fuji FinePix F460 Digital Camera
Kodak EasyShare v803 Is Frozen And Will Not Shut Off Or Retract Lens
same model as mine. Next to the memory card slot m rectangular black box.. battery pack. press it and it comes out , put it back and hold the on switch... presto!
Jan 01, 2008 | Kodak EasyShare V603 Digital Camera
Digital camara zoom
samsung digitmax d73 zoom lens will not retract, just pull lens outward gently it will click, then turn on camra ,you should be able to zoom now turn off camra lens should return & close
hope this helps
Oct 17, 2007 | Samsung Digimax S600 Digital Camera
Samsung TL240 Digital Camera Logo
772 people viewed this question
Top Samsung Cameras Experts
Kazim ERGUNEY
Kazim ERGUNEY
Are you a Samsung Camera Expert? Answer questions, earn points and help others
