Question about Maytag Neptune FAV6800AW Top Load Washer
Code uc and not spin
Machine wash but the last 12 minutes comes uc code and does not spin
  • 526 Answers
Most likely a very common clutch malfunction possibly brought on by a leaky Tub Seal.
See if this post will help Clutch Fix
If you have other questions I will try to help.
Rich
Posted on Jul 11, 2010
Getting dc and uc codes. Took clutch apart and cleaned and checked spring as suggested. Everything in there is ok. I don't have an upper bearing just the 1 way bearing. There is a lot of wobble in the spin...
Is the wash tub rotating CW in the wash cycle (tumblers should rotate only)? You can release the washer top to observe. If so I feel there may be binding in what I call the Spinner support bearings you can see those at the end of my Clutch Fix post.
Are you taking dc/uc unballance error codes while in wash cycle or just during spin cycle?
I believe somewhere around series 12 and above the machine design went to the integrated lower tub bearing/One-Way roller clutch bearing.
Any sign of wash water contaminating the Clutch Pulley One-Way bearing (rust)?.........Rich
Oct 16, 2010 | Maytag Neptune FAV6800AW Top Load Washer
Neptune Washer Spin Cycle
If your FAV6800A or FAV9800A wash tub is banging around in Spin Cycle of the Wash Cycle and your Control Board signals a dC or uC error code to the console I feel you have a Clutch malfunction. I feel the TDS is working as designed with the unblance error code shut down.
See my Clutch Fix post for more info related to dC and uC unbalance errors with the FAV6800A and FAV9800A TL’s and the repair action…….Rich
May 10, 2010 | Maytag Neptune FAV6800AW Top Load Washer
Maytag FAV6800AWW TL washer is throwing error code uC even when running empty cycle. It sounds like there may be a bearing going bad as it is more noisy than it should be when spinning. It stopped at 12...
Don,
I ask folks to give me some feedback when troubleshooting dC/uC errors with a feel for Wash Basket CCW/Spin direction drive system resistance.
It sounds like the Outer Tub Bearings are going which means you have a Tub Seal Leak that took them out. The Clutch One-Way Roller clutches are probably contaminated. I would bet a bit rusty and are sticking not locking up completely in Spin Cycle causing tumbler movement at the start of Spin Cycle. See my Clutch Fix post I go into a lot of detail for a fix and just what is causing the unbalance errors in Spin Cycle
You could drop the clutch out and see if you can clean up the bearings and relieve the dC/uC unbalance errors for a while longer.
Replacing the bearings is a bit more work see these post for what is involved. If your series is a 12 or above you may have to do as this forum member did.
http://www.fixya.com/support/t3973659-fav6800aw_sn_15_top_loader_r_nunit
Series 10 & 11 from what I have learned use the upper One-Way Roller Clutch bearing ring and not the integrated Lower Outer Tub bearing as in I believe the Series 12 and above do.
Series 10 Outer Tub Bearing work I and another forum member are working on. The links will give you some direction if you DIY. http://www.fixya.com/support/t4028403-just_replaced_new_clutch_fav9800aww
What are the first two digits of your Serial Number? Will be 10 through 17.
Post back if we can help I’m an owner like you not a repair person. I feel the cost to have the Outer Tub Bearing replaced will trigger you to make a replacement decision……Rich
Mar 13, 2010 | Maytag Neptune FAV6800AW Top Load Washer
I have a fav6800 maytag washer, I am getting a UC code. If the drain is blocked in someway will it give this message? the machine works fine till it comes to the rinse and spin and then error code comes...
What are the first to digits of your machines serial number? It will be 10 thru 17.
Did the machine bang around in Spin Cycle during the wash Cycle with the uC error code?
The FAV6800A and it’s sister FAV9800A LCD display version of the machine suffer from a chronic Dry/Rusted One-Way Roller clutch issue. See this Clutch repair post on this forum for clutch maintenance and or replacement and this post on another forum. Read how to check the failure of the One-Way Roller clutches to slip in the CCW/Spin direction at this post.
If you are just a bit handy you can do the maintenance or order a replacement from AZ they have the best price around $56. I will help you every step of the way…..Rich
Couple of links to the Service Manual and Sears Parts Direct for reference.
I’ll paste in how to check the Tub Displacement Sensor. I don’t feel that is the issue but is will give you a chance to go into Service Mode and check thru the lid for proper operation.
Tub Displacement Sensor Diagnostics check. This test is done with the washer lid raised see page 19 of the SM for the details.
It is possible the Tub Displacement Sensor may have failed try this check which is in the Troubleshooting guide stored in your washer console or refer to the SM.
a. Enter the Service Mode by pressing and holding the Enviro Plus and Spin Only keys for three seconds or the display reads “00”
b. Press the Super Wash key display reads “in”…something like that.
c. Press Delicates the Display will show “UC” (Unbalance Closed).
d. Push tub to the back right corner of the machine the display should change to “UO” (Unbalance open). Release tub and the display will show “UC” (Unbalance Closed).
e. Press Hand Wash.
f. Pull tub to the front left corner while pushing the tub down the display should change to “UO” (Unbalance open). Release tub and the display will show “UC” (Unbalance Closed).
If you get these results your TDS sensor should be just fine and not the cause of dC or uC unbalance errors……fix the clutch and your machine will be
J
Jan 18, 2010 | Maytag Neptune FAV6800AW Top Load Washer
My Maytag Neptune TL FAV6800AW Washing Machine is receiving the dC error code on every load. It sits at 12 minutes remaining and attempts to spin several times before throwing the codes.
Hello zacas6,
dC/uC unbalance errors are caused almost all the time by a Clutch malfunction. Take a look this post and see if you want to DIY the repair. I will help you through the process.
I would also check the Tub Displacement Sensor. This a thru the lid check and you get a feel of how to enter Service Mode.
e. Press Hand Wash.
I have some additional info if you decide to remove the Clutch in the machine if you are going to DIY.
Rich
Nov 30, 2009 | Maytag Neptune FAV6800AW Top Load Washer
Neptune TL, stops at the 11 minutes to end and will not go past, I have to shut off, hit spin cycle to finish load
Hello krabby64
Is your FAV6800AW or FAV9800AW failing with error codes dc or UC or both to the Console display? If you are I believe you are experiencing a clutch malfunction with your machine. Take a look at this post and see if your problem is similar.
If you have error codes to the display when the machine fails in the last 11 minutes (I believe start od spin cycle) can you let us know what those error codes are?
Oct 19, 2009 | Maytag Neptune FAV6800AW Top Load Washer
Was washing ok until the last spin then it stop and uc lights are blinking what is uc?its does'tspinat all now
The "uc"code on the Neptune indicates a "continuous unbalanced circuit". Check to make sure that the weight of the clothing is distributed evenly in the tub. There can be a few causes for the generation of this code and you might want to consult an appliance technician for assistance. Bad shocks can cause this by permitting the tub to be out of balance, but you didn't describe any banging, etc. The tub displacement sensor could be at fault. The pump and pressure switch should also be checked for proper operation and to make sure there is no obstructions in those components. Really sorry for your trouble and I hope this helped. Best wishes.
Sep 11, 2009 | Maytag Neptune FAV6800AW Top Load Washer
UC code, doesn't spin out correctly
on last spin washing machine will not spin all the water out.
May 16, 2009 | Maytag Neptune FAV6800AW Top Load Washer
Maytag neptune mah8700. Will spin at the end of quick rinse cycle but not on any other cycle. Error code I get is SUSP. Washer does drain out.
Hi
My name is Gloria, my neptune washer will not spin on the last spin cycle of any of the washing cycle. A code of uC comes up.
Aug 08, 2008 | Maytag Washing Machines
Maytag Neptune FAV6800AW Top Load Washer Logo
220 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
