Question about Acer Aspire One PC Notebook
Um an ethernet controller is not working...
In device manager, it says that a network adapter is corrupt or missing. do you have a link for and atheros AR5007EG wireless network adapter?
  • lucky_gamefr Jul 11, 2010
    I downloaded the file on my toshiba laptop and transferred it to the acer laptop via flashdrive. There's an error saying, "This installation package could not be opened. Verify that the package exists and that you can access it,or contact the application vendor to verify that it is a valid Windows Installer package". What do I do?
  • 10,319 Answers
Local Area Network is missing on Network Connection for window 7
Do you have an Ethernet connection?
1) What does Hardware Manager say about the device ? Does it exist ? Is is 'operating normally'?
2) Can you add the network in the Network Manager ?
3) Do you see the interface when you enter a DOS (Command) window and enter "ipconfig /all ' more"?
Sep 15, 2012 | D-Link 10/100Mbps Fast Ethernet DFE-530TX+...
Plug & Play recognises Dub E-100 attached and device manager lists it however continually get error 39 driver missing or corrupt. Drivers loaded directly from CD supplied / also download version...
Hi.Try to install again your windows xp.need fresh windows xp installation because same of your operating system software device corrupted and missing.to recognizes that USB network adapter gadget.
Jun 09, 2011 | D-Link DUB-E100 (DBDUBE100) USB Network...
My network adapter was missing and i need to install the network device so i can use my LAN cable
click start control panel administrive tools computer management device manager scroll down network adapters + expand Ethernet driver right click you will have options to update driver disable uninstall or select properties general you will have the options to troubleshoot or to update driver rollback or uninstall a yellow? ! question or exclamation mark or red x means you need to install/update driver right click to install driver
http://download.cnet.com/%7Bvalue=http://www.download.com/network-3c905c-txm-ethernet/3000-2112_4-109025.html
http://download.cnet.com/%7Bvalue=http://www.download.com/network-pro-100-m/3000-2112_4-109029.html
hope this helps
May 26, 2011 | Computers & Internet
Ethernet connection has just stopped working. 80072ee7 error. However, device manager says adapter working properly, orange green lights working/flashing. cable checked to another comptuer without...
Try going into the control panel and then into the device manager. Find the ethernet device and remove it. Then re-boot the computer and the OS should re-detect the card and re-install the drivers. Hopefully this will get the card working again. Let me know if this helps.
Nov 18, 2009 | SMC Realtek 10/100TX PCI Fast Ethernet...
Reformated my Dell Dimension 2400, now under device manager I got the big yellow question mark for Other Devices - Ethernet Controller -PCI Simple Communications Controller Dell's driver support page does...
If you have windows Vista simply Right Click on the entry in device manager and choose Update driver (Requires working internet connection)
Else use the following drivers (Works on XP and vista)
ftp://ftp.us.dell.com/network/R64645.EXE
Oct 16, 2009 | Dell Ethernet Card Network Adapter
CAN NOT GET MY WIRELESS INTERNET TO CONECT,LIGHT IS ON BUT WHEN IT IS ON IT IS TO TURN BLUE BUT IT DOSE NOT. CAN SOME ONE HELP?
First, make sire the switch is in the right position...most of the the time when the switch is on the fron tof the laptop, "on" is to the right. If the switch is in the "on" position, then it is possible that the driver has gotten corrupt or is somehow missing. Try first to update the driver. Go to the control panel > Device Manager (in XP it is in System and then under hardware) scroll down the device manager and click on the + sign by the network adapters. Right click on the wireless adapter and choose update driver. Let windows go through the update and reboot, if this doesn't work, go back to the network adapters and this time right click on wireless adapter and choose uninstall. Reboot and when windows starts, it will recognise the hardware and install the appopriate driver for it. It would be better if you were connected to the internet by an ethernet cable for this, that way if the wireless is down, windows can search online through the ethernet cable and get a fresh driver....but if not it isn't totally necessary.
Sep 22, 2009 | Compaq Presario Notebook
Network Adapter/Ethernet Controller
Nothing wrong with having two network adapters installed on your computer. If you have this DWA-552 wireless adapter installed as well as an onboard NIC, the correct thing to do is have both drivers installed so you see them both in your Control Panel->Network Connections window.
If you really want the onboard nic to go away, go into device manager and disable it - not uninstall it.
Mar 08, 2009 | Computers & Internet
Missing ethernet controller+Pci device+ sm bus controller
PCI Modem is your dial up modem, Ethernet Controller is your Network Card, and SM Bus Controller is your Motherboard Chipset drivers. There missing because your Operating System has Either Corrupt Drivers or they were never installed in the first place. Sounds like a fresh installation was done and nobody bothered to look in the device manager to see if any hardware drivers were missing.
Feb 07, 2009 | ASUS P5PE-VM Motherboard
Driver missing
all you need to do is to update the drivers for the SM Bus Controller.
May 05, 2008 | Computers & Internet
Acer Aspire One  PC Notebook Logo
321 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Alun Cox
