Question about Cortelco Medallion 3220 Corded Phone
My Cortelco Medallion 3320 phone is flashing "L2 vmwi on !" over and over again and won't stop. What does this mean and how do I turn it off?
I have a uniden deft 1735 phone and the red light keeps blinking
it is the vmwi in the global set up
press the menu button
press the down arrow to get to answering set up
keep pressing the down button until you get global set up
press the down button until you get the vmwi word press the menu button
press the down button to change from no to yes
press the menu button then press end
the light will stop flashing
If you get it right , right it down as the nbn sets that light off on a regular basis
Oct 17, 2017 | Uniden Lands Phones
How to stop red flashing light on uniden cordless phone
press menu down to answer set up keep pressing the down button until you get vmwi press menu change to yes
press menu then end
Sep 23, 2017 | Uniden Lands Phones
Uniden 6.0 dect messege light will not stop blinking
resetting the voice message indicator
if the voice message indicator icon remains after you check your messages , you can reset it
1---with the phone in standby, open the menu
2 select the global setup, then select the VMWI reset
3 select yes
the flashing light will then go to full on as in the phone standby situation
refeence from the uniden user manual
May 16, 2017 | The Watches
We have a Uniden N32 Model XDECT7055. How do I remove the red flashing light on top of all the phones.
If that is the Voice Mail Waiting indicator light at the top of the handset and on the base, you need to press Menu on the base. Use the up/down arrows to select VMWI Reset. Press Menu again to select this sub-menu. Use the arrows to highlight Yes and press Menu again. You may need to contact your telephone company to make sure that the voice mail service is still compatible with the Frequency-Shift Keying message notification. Some broadband (particularly DSL) systems can cause telephone interference. Check with the broadband provider if you need a DSL filter (or similar item) to keep the interference from corrupting the VMWI information.
The procedure is on page 17 (19 of the PDF) of the manual for the Uniden XDECT7055. This is available here: https://www.uniden.com.au/resources_main/pdfs/XDECT_7055_3WP_OM.pdf .
I hope this helps.
Jul 23, 2016 | Uniden Cordless Phone
Cant turn off flashing red light that indicates a message, but we do not use the message function.
You have unheard messages on the voicemail system provided by your telephone company. This system records messages when someone calls while you're already on the phone. Please contact your telephone company for instructions on accessing their voicemail system.
Jan 09, 2013 | Lands Phones
Cortelco 2740 how does it work?
here is the PDF file that contains the manual for the Cordelco 2740
http://www.cortelco.com/manual/2740_manual.pdf
Oct 31, 2012 | Cortelco Lands Phones
Voicemail flashing light will not turn off even after deleting all messages.
SOME WORKAROUNDs - which MAY NOT WORK for everyone!
while ensuring that the TBB line is ON HOOK - NOT OFF HOOK:
1) LISTEN to your NEW VM through the Portal. If you listen through Email forwarding - this will NOT cancel the flashing VMWI.
2) Access your TBB VoiceMail from another phone (cell) or through RemotePhone. LISTEN to your NEW VM from there.
The flashing VMWI should be OFF and back to normal operation! You need to repeat the above steps for any NEW VM.
•You need to have at least one NEW VM that you have not listened to for the above to work. So if there are no NEW VM, phone your TBB line and create one. Then LISTEN to it from the Remote Phone/ cell phone, or delete it from the Portal, and the light should go off.
•Note that listening to or deleting OLD VM (whether in CURRENT or SAVED folders) will do nothing!
Jul 02, 2010 | Cell Phones
The base unit has a flashing light. Why and how
Usually the flashing light is a New Message waiting indicator, meaning you either have a message on the built in answering machine, or you have Voice mail service provided by your telephone service provider. If you have checked both of these and there is no message either place, you need to do the VMWI reset procedure in your manual, if you don't have the manual you can look it up at Uniden.com
Jul 08, 2010 | Uniden Cordless Phone
Displays new voice mail and VMWI constantly blinking when no voice mail
Subscriber is T-Mobile@Home. First, cleared all messages from T-Mobile voicemail.
Now to fix your GE phone:
Push the program key. Select Handset Setup Push the program key Select Default Settings Push the program key Select 1 Yes. Push the program key
Hope this helps.
Mar 06, 2008 | Uniden Cordless Phone
GE 28128
I called support - took forever to get through
Told to unplug phone line, batteries, and AC, then wait 15 minutes.
Then reintall in order of batteries, then AC, then phone.
But once the AC gets plugged in, the light starts blinking again.
The technology of bluetooth with my cell is great, but the interface sucks and the light that won't properly recognize things is incredibly annoying. This one is going BACK....
Oct 25, 2007 | Uniden Cordless Phone
Cortelco Medallion 3220 Corded Phone Logo
144 people viewed this question
Top Cortelco Lands Phones Experts
Computer Repairing
Computer Repairing
Are you a Cortelco Lands Phone Expert? Answer questions, earn points and help others
