Question about Vacuums
If i do a sum such as 3 & 1/4 + 4 & 2/3 i get the answer back as 95/12 how do i get the answer as a mixed number again?
    Master:
  • 501 Answers
12 into 95 =84 11/12ths
Posted on Jul 11, 2010
I have the Platinum keurig and the water is going back into the reservoir and not into the cup??? is it beyond repair?
Are you getting a message saying to "de-scale" it may need a good cleaning. That's usually the issue & the quickest fix. If the Keurig (or any other coffee maker) gets lime/calcium build up on the internal components it will ignore whatever has been programmed into it & just keep cutting off, keep making partial cups & just not working properly. Run some white vinegar thru it - fill the reservoir with a strong vinegar/water mix, remove any kcups/my kcup filters, also remove the reservoir carbon filter ( fyi - that's not going to eliminate any lime/calcium in your water - it's just to eliminate any bad tastes/odors) and "make" how ever many cups it takes to empty the reservoir.Depending on the build up - you may need to do this 2 or 3 times. Also run about 2 more reservoirs of just clear water to help rinse out the vinegar mix (otherwise your next cup of coffee will not be what you expected).
This may eliminate your problem & should be done every 2-3 mths. If that doesn't solve it - your Keurig may already be too far gone. Good Luck.
Jul 09, 2011 | Vacuums
Shows that it is ready to brew, but says "de scale"
What model do you have? I'm guessing we are talking coffee maker, is it a Keurig? If you're getting a message saying to "de-scale" it need a good cleaning. That's usually the issue & the quickest fix. If the Keurig (or any other coffee maker) gets lime/calcium build up on the internal components it will ignore whatever has been programmed into it & just keep cutting off or keep making partial cups. Run some white vinegar thru it - fill the reservoir with a strong vinegar/water mix, remove any kcups/my kcup or filters, also remove the reservoir carbon filter ( fyi - that's not going to eliminate any lime/calcium in your water - it's just to eliminate any bad tastes/odors) and "make" how ever many cups it takes to empty the reservoir. Depending on the build up - you may need to do this 2 or 3 times. Also run about 2 more reservoirs of just clear water to help rinse out the vinegar mix (otherwise your next cup of coffee will not be what you expected).
This should eliminate your problem & should be done every 2-3 mths, regardless of whatever the model of coffee maker you have. Good Luck.
Jul 08, 2011 | Vacuums
My Keurig will not stay on long enough to brew even one cup of coffee. The automatic shut off is on the off position. It only stays on seconds.
When is the last time it was cleaned? That's usually the issue & the quickest fix. If the Keurig gets lime/calcium build up on the internal components it will ignore whatever has been programmed into it & just keep cutting off or keep making partial cups. Run some white vinegar thru it - fill the reservoir with a strong vinegar/water mix, remove any kcups/my kcup, also remove the carbon filter ( fyi - that's not going to eliminate any lime/calcium in your water - it's just to eliminate any bad tastes/odors) and "make" how ever many cups it takes to empty the reservoir. Depending on the build up - you may need to do this 2 or 3 times. Also run about 2 more reservoirs of just clear water to help rinse out the vinegar mix (otherwise your next cup of coffee will not be what you expected).
This should eliminate your problem & should be done every 2-3 mths. Good Luck.
Jul 07, 2011 | Vacuums
Need to clean cuisinart 12 cup coffee on demand coffe pot. How do I clean?
Do you have the DCC-2000?
To delime a multi-cup coffee maker, mix white vinegar with water (1/3 vinegar and 2/3 water) and fill the water reservoir completely. Then turn the coffee maker on. Wait until the unit completes the "brewing" cycle and beeps 5 times. Turn off the coffee maker. Discard the liquid after the cycle. Then fill the reservoir with clean water and turn on again. When this cycle completes, again discard the liquid. Repeat the water rinse if you notice an odd taste to the coffee afterwards. (If the coffee maker still has deposits, repeat the vinegar cleaning cycle and rinse cycles.) There are commercial deliming products, mix them with water following the package directions.
The manual for the DCC-2000 is available as a link here: http://www.cuisinart.com/products/coffee_bar/dcc-2000.html . The direct link to the manual is http://www.cuisinart.com/share/pdf/manuals/dcc-2000.pdf .
I hope this helps.
Jun 19, 2011 | Vacuums
I have a Bissell ProHeat Turbo 2x, it isn't mixing the water & cleaning solution and isn't spraying. What do I do?
Isn't Spraying:
Possible Problems->Solutions
-Water Tank may be empty-> Fill Heavy duty bladder with hot tap water.
-Formula Tank might be empty-> Fill with Bissell fiber cleansing formula for cleaning.
-Tanks may not be seated completely-> Turn power off and reset the tanks.
-Pump may have lost prime-> Turn power off, then on again, wait one minute then depress the trigger
You can also contact Bissell at: 1-800-237-7691 begin_of_the_skype_highlighting 1-800-237-7691 end_of_the_skype_highlightingto help you out on why the cleaning solution and water aren't mixing, but first try fixing the first problem, you never know, it might cure the first one. :)
Hope this helps!
Remember to give me 4 Thumbs Up
for all the hard work to the Community! :D
~~Dayminner
Jun 04, 2011 | Bissell Vacuums
I am having problems setting the alarms on my Emerson Smart Set clock
Directions for Resetting the Daylight Savings Time (DST) Start & End Dates on the Emerson Research Smartset Dual Alarm Clock Radio (cks5055s):
  • This should work for all Smartsets, but I cannot make the guarantee (and no, I don't have any other directions, sorry)!
  • Adjusting the DST Start Date on an Emerson Research Smartset:
    1. Depress & hold the MONTH/DATE and the ALARM1 buttons (at the same time). After 3 seconds the display will show the DST 'start' month, week, and date. It should be alternately showing "4 F" (April and first week week) and "4. 1".
    2. While still holding the MONT/DATE and the ALARM1 buttons, press the DOWN (or "-") button 3 times, until the display is showing "3" (March) and the week as "F2". It should alternately flash "3 F2" and "3. 11".
    3. After this is set, the clock should "automatically" reset itself
  • Adjusting the DST End Date on an Emerson Research Smartset:
    1. Depress & hold the MONTH/DATE and the ALARM2 buttons (at the same time). After 3 seconds the display will show the DST 'end' month, week, and date. It should be alternately showing "10 L" (October and last week week) and "10. 28".
    2. While still holding the MONT/DATE and the ALARM1 buttons, press the UP (or "+") button 1 time, until the display is showing "11" (November) and the week as "F". It should alternately flash "11 F" and "11. 4".
One thing to note, if you ever have to change the lithium backup battery for the Smartset clocks, it will revert back to it's factory defaults and you'll have to go through his all over again.
And this conclude's Search Marketing Guru's public service announcement. :) We'll be back with relevant online marketing posts with our next posting!
Nov 03, 2010 | Vacuums
Irobot scooba 5800 spins quickly then sets off backwards
Remove and clean all of the wheels, and make sure the cliff sensors under the bumper are clean. Tap the bumper with your hand-- really smack it a couple of times. It sounds like the Scooba believes it's stuck against an obstacle.
May 10, 2009 | iRobot 5800 Scooba Vacuum
Removing the top of the 7901-1 Bissell Proheat
Unscrew the cap for the flow indicator, remove the 6 screws, the top will come off. When you put the top back on, make sure the piston is hooked on the smart mix knob(underneath the top cover) set the smart mix valve in the wtaer only setting, then put the top back on. Turn the smart mix valve to make sure it is turning like it should, then re-install the 6 screws and the flow indicator parts. (don't over tighten the screws)
May 16, 2008 | Bissell 7920 ProHeat Pro-Tech Upright...
Little green machine solution
on the solution tank of the green machine has a line on ot showing how much solution
May 11, 2008 | Bissell 1720-1 Little Green Wet/Dry Vacuum
Can't reassemble!!!
The piston is put on the bottom of the smart mix knob, turn the knob to the water only setting, then put the top housing back in place making sure that the piston went into the slot, after the top is all of the way down, turn the knob, if it turns easily, then it is in place.
Feb 10, 2008 | Bissell 1699 ProHeat Clear View Upright...
Vacuums Logo
24 people viewed this question
Top Vacuums Experts
AskDyson
AskDyson
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
