Question about Toshiba Satellite L25-S119 Notebook
AC/DC adapter My ac/dc adapter is not supply power to my laptop. Can I go to any electronics store to get an AC/DC adapter that works with my toshibia laptop
    Genius:
  • 1,027 Answers
Make sure the voltage and amperage is the same and the tip fits.
I use I-GO universal from Radio shack
Posted on Apr 19, 2008
There seems to be no power to our shredder.
Beverly, the power supply for shredder is probably bad. If it has a external power supply, take old power supply with you to a electronics shop and have them match it up for you, with a universal power supply.
Check the attached links,
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
universal power supply Google Search
http://www.walmart.com/c/kp/universal-ac-dc-adapters
Results for Universal AC Power Adapter
SS103 Universal Power AC DC Adapter 500mA
Mar 11, 2016 | Office Equipment & Supplies
I need a class 2 power Supply ac/dc adaptor
Shop for I need a class 2 power S... on Google
Phihong ? Wall Mount AC Ada...
$4.68
Mouser Electr... United Security Products AC2P
$15.44
ELVESsupply... Mean Well ? Desktop AC A...
$13.10
Mouser Electr... Ac Adapter For Black & Decke...
$17.99
eBay Generic Ac Adapter Char...
$5.99
eBay Search Results
    Kastar AC DC Adapter Plug-in Class 2 Transformer Power ...
    www.amazon.com > ... > Car Chargers
    Amazon.com, Inc.Kastar AC DC Adapter Plug-in Class 2 Transformer Power Supply Cord Wall .... Provides power to your device in the event you may have lost or damaged your ...
    Amazon.com: Class 2 Power Supply AC Adapter 6V 200mA ...
Dec 14, 2015 | Computers & Internet
Broke off my ac power supply nipple on the inside of my laptop where can I get a new one to solder on
Hi, if the Notebook is still under Warranty it is not recommended to remove and solder the Notebook with a Female DC Input socket of the Notebook. Although the DC input socket is available in any near by Electronic repair shop, please repair only if the Notebook Warranty is expired.
Mar 29, 2011 | Gateway MD7820u Laptop AC Power Adapter...
Advent k200 laptop does not charge new battery
Im very sorry to hear that, please follow these simple steps for you to be able to isolate the exact problem.
1. Removed the battery.
2. Connect the laptop directly to the power outlet without using the battery just for the meantime.
3. Turn on the laptop. If the laptop is able to power on, that means that the AC adapter is working fine as well as the DC port. If the laptop is not able to turn on, it maybe the AC adapter itself or the DC port.
4. Try to use another AC adapter if possible, make sure that that AC adapter is working fine. If the laptop is still not turning on, the problem is with the DC port itself. In that case, you will need to replaced the Motherboard itself.
Hope this will help...Your response is very much appreciated...
Feb 15, 2011 | Computers & Internet
Advent k 200 laptop does not charge battery
My gateway laptop note book, will not power up, I have checked the cord, battery etc. Went to turn it on one day and no power? someone mentioned that it over heated?
First of all, take the battery off and try to turn it on with the ac adapter (power cord) connected. If it comes up without the battery then it's your battery.
If it doesn't turn on without the battery and with just the ac adapter, try a different ac adapter. You can find one to try at your local pc shop or electronics store. If it comes up with another ac adapter then all you need to do is purchase an ac adapter at the store or order one online (cheaper).
If it still doesn't come on then it's either your dc jack or your motherboard. Normally if it's just the dc jack it will turn on or attempt to turn on when you wiggle the connecter in the ac adapter connection. If it's your dc jack it's relatively inexpensive to purchase online. The problem comes with having to take apart the laptop, desoldering the old and soldering the new dc jack, and putting the computer back together.
Good luck and let me know if you have any other questions.
Oct 23, 2010 | Computers & Internet
HP Compaq laptop won't charge/power from AC due to blown fuse
There's plenty of causes why your laptop would not power up from the AC adapter and won't charge the battery. Here are some possible causes and solutions to this problem:
Number one, if it's on battery power, the battery is dead or the battery is bad and number two the AC adapter could be bad. Let's roll out number one.
1. Take out the battery, remove main supply, hold power button down for 30 seconds. This will drain the charges in your
battery. Put only power supply in, do not put battery in, turn laptop on, put the battery in.
2. If the solution in no.1 doesn't solve the problem, pull the battery out, keep the battery out of the laptop for this test.
Take your AC adapter and check the voltage with a voltmeter. What you want to test for is voltage. Put the meter at 20
volts DC and take the tip, the power jack tip of your AC power adapter. You hold the black, (the negative part) of your
voltmeter on the outside of the power jack tip of your AC adapter and you put the red (the positive part) of your voltmeter
in the hole in the inside of the power jack tip of your AC adapter. Be very careful not to touch the red and the black part of
your multimeter and the power jack tips of your AC adapter together, otherwise it will create a short circuit.
After doing these procedures, if your AC adapter is good it will output a voltage which ranges from 18 to 19V DC on your
voltmeter, depending on the voltage that puts out on your AC power adapter. If your voltmeter doesn't show any voltage,
probably your AC power adapter is bad or damaged. But if your voltmeter shows up voltage, then we have to go to the
next possible cause why your laptop won't power on.
3. The dc jack on your laptop might be bad, if the dc jack on your laptop is bad or not making a connection to the
motherboard then it look the battery is bad as well, because the battery is now not holding a charge or even taking a
charge. Also, even if your AC power adapter is good and when you insert it to the dc jack in your laptop it could not power
up the laptop because the dc jack is not making a connection to your laptop motherboard in other words the dc jack might
got loose, that's why it's not making any connection to the motherboard. The only way to solve this is that you have to
disassemble your laptop, and take the laptop motherboard out and look where the dc jack is connected. After you found it,
take a file tool and file off a spot on the motherboard where you can reattach the power jack and use a wire to reattach
the power jack to the motherboard.
Hope you find this answer helpful. God bless.
http://compunics.blogspot.com/2010/06/podnutz-high-definition-laptop-repair.html
Jun 03, 2010 | HP Compaq Motherboard
My 4520 Acer Laptop will not charge and will not work on AC power alone.......
You First need to test your AC Adapter Cord...
You can test if you have a secondary known working one.. plug that one in to see if same issue occurs.. OR you will need to test the AC Adapter using a multimeter (available at any home improvement store for under $7).. When testing the Plug End on the AC Adapter - Hold The Negative Test Prod Of the Multimeter to the Outer Side Of the Plug Tip, and Put The Positive(red) Test Prod Inside The Plug Tip... See If You Have Power Through The AC Adapter Tip... You Might Need To Slightly Wiggle The Cord Near The Tip End To See If THere Is A Short In The Cord....
If Cord Tests Good....
You Will Need To Replace The Laptops DC Jack...
The DC Jack is the port where your AC Adapter Plugs into on the laptop..
Your Faulty DC Jack Would Need to be desoldered, the motherboard cleaned of all old flux, Re-Tin The Contact Pads and then Resolder a New DC Jack Onto The Motherboard...
Nov 16, 2009 | Acer Aspire 4520-5582 Notebook
Toshiba laptop battery or AC/DC adapter
step 1.First remove the battery out
step 2.Try to plug in the AC/DC adapter and see any Power light or something on your machine. If you have power light on your machine that mean your adaptor is supplying electric.But still there're some adapter that don't really supply a good DC voltage
we need to further check.
step 3: incase no light nothing on your machine you need to use analog meter or digital meter to check that your adapter is giving out DC Volatage around 16-19V
Best of luck, takecare.
Apr 19, 2008 | Toshiba Satellite L25-S119 Notebook
Toshiba Satellite L25-S119 Notebook Logo
65 people viewed this question
Top Toshiba Computers & Internet Experts
pankaj rautela
pankaj rautela
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
