Tv pictures stops after 5 minutes when you turn the set off and then on again it is ok for several minutes and then cuts out. the sound is always there
  • Televison & ... Master
  • 1,229 Answers
In general you have a bad signal board. It would be the board with the RF connections and RCA jacks! Thanks for asking!
Posted on Jul 11, 2010
  • matt martin
    matt martin Jul 11, 2010
    Answers a question about flat panel TVs in most cases!
Sony Plasma KDE 42xs955 has delay in of 5 to 10 minutes for picture to appear. Sound turns on immediately
Contact the authorized service centre for Sony. This is not a fault that a normal user can do anything. Electro help
Oct 22, 2014 | Sony KDE-42XS955 42 in. Plasma HDTV
My thomson projection tv serial number atn706327 keeps cutting off every 5 minutes the fan stops and the picture goes away could you help please
This sounds like the protection circuit operating. With projection TV's, the cooling fan is essential to prevent damage from overheating. The fan contains a pulse generator to indicate rotation. If the pulse stops, the protection circuit will turn off the set. 5 minutes may be how long the fan takes to seize when it warms up. Also possibly heat sensitve parts along the cooling path covered with dust causing heat sensors to operate.
Jan 19, 2011 | Thomson Televison & Video
Toshiba tv screen goes black every 5 minutes with sound still on
Is it ok when you watch regular TV thru the cable or sat?
Jun 16, 2009 | Toshiba 46HM95 46" HDTV
Sony trinitron kv-32fs13 32''
when the lights flash those are codes that tv repair men have.youd be better off buuying a new tv,they are less than 500.00 nowadays
May 20, 2009 | Televison & Video
No picture at all,sound ok 3 tube crts off after 4secs when on
might be a crooked flyback transformer, first check for shorted transistors around the transformer and components at the horizontal output stage..
Mar 31, 2009 | Philips Televison & Video
High Definition Projection TV
The flashes are a diagnostic. It should be only one flash pattern, either a 5 or a 10 (there are several other patterns in between as well). Please verify the number of flashes after power on, several times, and post back here, and I will be able to help with the fix. Based on your initial description, it my be the HV distribution.
Apr 02, 2008 | Sony Grand WEGA KDP-65WS550 65" Rear...
No picture but has sound
hello .this does sound like bad solder joints .all printed circuit boards do this after a while due to heating and cooling .is not advisable to try to repair yourself .possible electric shock and spiking .will do a lot of damage .take to a shop to have repaired
Oct 30, 2007 | Sony KV-36XBR450 36" TV
Tv turns off at irregular intervals
MOST PROBABLY DRY SOLDER IN THE POWER SUPPLY SECTION OR REPLACED THE HORIZONTAL DRIVER TRANSFORMER . MUKU
Oct 16, 2007 | Durabrand DWT1905 TV
Televison & Video Logo
37 people viewed this question
Top Televison & Video Experts
Marvin
Marvin
