Question about Freezers
The freezer is not working is not cooling at all. The compressor seems to be running but it gets very hot really quickly.
  • Freezers Master
  • 17,130 Answers
There is a possible chance that your compressor unit is faulty. You could have a failed valve within the system, check for oil leak gas leak. if so you will need to refill oil/gas. However since you have not indicated the age of the freezer, if the unit is older than 6 years , I would recommend that a new compressor unit be fixed or you must consider after looking at the cost of this replacement for a new unit which would be more power efficient and carries along a warranty.
Hope this helps.Good day
Posted on Jul 11, 2010
My upright freezer runs more than it is off
general design requires compressor on off ratio to be total run time to be 18 hrs on per 24 hr day off time allows compressor to cool down averaged over the day cool air is required around the outer walls of the fridge to cool the condenser coil at the rear also
Oct 03, 2017 | Frigidaire Freezer Refrigeration White...
Upright self def. freezer not getting cold
Is your compressor running? Try this: place your hand on top the compressor, quickly-in case it's hot-it should be vibrating and cool/warm to the touch. If it's not running then the cheapest/fastest test is to try a 3in1 start kit from a local appliance shop. The 3 in 1 start should be around $14 to $20 to wire up. It's extremely simple to wire up, just ask the clerk at the appliance shop's parts counter and they will explain it. I hope this helps you out!!! :)
Nov 19, 2012 | Frigidaire 20.3 Cu. Ft. Frost-Free Upright...
I have a Frigidaire upright freezer. I unplugged the freezer for approx. one month because I did not need it. After plugging back in, the compressor seemed to start ok. I left running overnight. the...
besides hitting the compressor with a hammer. unplug and lay on its side for 2 hours then upright for 24 hours plug back in. Never ever unplug a freezer
I’m happy to assist further over the phone at https://www.6ya.com/expert/james_1cb31da1bc8c6102
Oct 04, 2017 | Frigidaire 12 cu. ft. / 340 liter Upright...
I have a Turbo Air TGF-49F freezer and it is not cooling. The compressor unit seems to work but when I turn the unit on all I hear is the compressor running continuously but nothing gets cold.
Difficult for you to check this I'm afraid, if the fan on the cooling unit is working unless you have an experienced 'ear' you will not hear the compressor running or worse still occasionally clicking.
Possible faults are
1. Compressor not running (the fan will run even if the compressor does not) electrical fault
2. Compressor seized (consult your service guy) also true for the rest of these
3. Compressor not pumping
4. Refrigerant leak
Not much hope for a cheap repair
Apr 14, 2011 | Turboair 49 cu. ft. Upright Freezer...
Was staying cold and then just stopped cooling. compressor sounds like it comes on but does not stay on feels like it is running and gets really hot have not found a fan
Try replacing the compressor relay (no more than $30) ,but if still doing the same ; the compressor has a start problem and you might have to replaced it.
Sep 28, 2009 | Freezers
Chest freezer repair
I had the same problem with an upright and so I bought a piercing valve and charged the compressor with 134R and has been working great since.
Jul 05, 2009 | Freezers
Won't freeze
Is the compressor running the whole time? If so may have a problem with a refridgerant leak....check the compressor in the rear of unit, feel if its hot....may be as simple as a relay.
Jun 17, 2009 | Kenmore Freezer 20.3 cu. ft. Frost Free...
1991 Kenmore 16 model 253 in storage for 7 years. Plugged it in and turned it nn last night and seemd to run fine, nice and quiet just like before. Today it is not cold and the comressor seems to be r
If the freezer was stored and not running for 7 years it may have lost coolant.  Since the compressor is running recharging the coolant may fix the problem.  Hot compressor might indicate low coolant since its motor is immersed in it.
May 30, 2009 | Kenmore 19.7 cu. ft. / 558 liter Chest...
Kenmore freezer is not cooling
Listen for some type of noise from the back lower part of the freezer. This could indicate a problem with the compressor. It is not a fast fix problem. Get your frozen foods to a cold temperature. If the compressor is running and you are not getting the cooling your system could have lost its refrigerant charge. If the compressor is cool and not running check the temperature control. It may have failed. Unplug the power to the freezer and remove the temperature control. Jumper the two main wires that attach to the temperature control and insulate them with electrical tape. Plug the freezer back in and the compressor should start and cool. If this makes it run replace the thermostat.
Jul 06, 2008 | Kenmore 13.7 cu. ft. / 388 liter Upright...
Freezers Logo
85 people viewed this question
Top Freezers Experts
Dennis Boxerman
Charles T Nevin
Charles T Nevin
AJMAL KHAN
Are you a Freezer Expert? Answer questions, earn points and help others
