Question about Stanton ST-150 Turntable
I received the turntables and mixer but Im having trouble installing everything together. Is there any companies that can help you install the turntables, mixer, and speakers
  • 17,130 Answers
Not to worry if you can take some pains and be confident. First of all arrange the turntable, the mixer, the amplifiers and the speakers. Connect the turntables two RCA pins to the PHONE pins L and R. of the mixer. Using another set of RCA cables to connect the output of the mixer to the amplifier's AUX inout L and R. Try to connect the red and white in accordance to the L&R. The speakers should be cconnected to the left and right of the amplifier's main. if you have front and rear use them but connect with the polarity of the red and black polarity . Use a good power supply multipin unit to connect all the power. Do not switch on until you have checked once again. Now switch on and play your favourite record. DO take time to do and you will suceed. Good day
Posted on Jul 11, 2010
Why won't both my turntables play out of my mixer?
I am guessing but it sounds like a gorse impedance mismatch. You should never connect two outputs together unless they are specifically designed for that. Since you are listing to mono why not send each output to the Base Amp the other to the cabinet. That should resolve the problem.
Mar 29, 2013 | Numark Im1 2-channel Pro Dj Mixer With...
Im new with the use of the record player since im tired of MP3's. i bought a Numark TTusb turntable connected everything, but the sound is low. i have to crank the volume to the max, and only get low...
A turntable use a magnetic cartridge and its output is only 5 to 10 millivolts.A moving coil cartridge is even lower,.2 to .5 millivolts(thats 1/2000 of a volt)in contrast, a mp3 puts out a 300 to 900 mv signal..so does a CD player. Your turntable does not have enough signal.You need to get an amplifier that has a phono input. Years ago,radio shack used to sell phono preamps that could plug into a tape or cd input.The other option is to buy a used mixer that has a phono input.The mixer output can drive the cd input easily,as the max output from a mixer is 1.5 volts to 2 volts.
Dec 30, 2010 | Numark ttUSB Turntable
ION Discover DJ mixer "Scratch/Search" switch
plug in the turntable first, then start the program.
if all lights are lit try again .
hope it helps
Dec 24, 2010 | ION Audio Discover Dj Turntable
Technics SL1500 will not connect to new Sony STR-DH100 receiver
Unfortunately, a turntable runs on a different frequency, and if there is no button at the back of your receiver to change the frequency setting on that channel, it wont give you any sound. the best bet is to go to your music store and purchase a small DJ mixer. connect that to your receiver, and run the turntable through your mixer. the mixer will have the neccesary flip switches and "ground" connections
May 06, 2009 | Audio Players & Recorders
Home stereo audio problems
Could be a bad patch cord, a setting on the mixer, a faulty mixer (unless it works ok with other amps), or a dirty control on the Sony amp if it has analog controls. Have you tried connecting other sources to the Sony?
Sep 27, 2008 | Audio Players & Recorders
No music
Where do you have the turntable connected? Is it going into a DJ Mixer, a Receiver, or a Power Amp?
No matter the unit, make sure you have it plugged into the PHONO INPUT connection on the rear. If your receiver/amp does not have this, then you will need a PHONO PRE-AMP - The turntable connects to the PHONO PRE-AMP, and the PRE-AMP connects to the LINE IN or AUX IN of your receiver.
If you are connected to the PHONO INPUT of your mixer/receiver/amp, then the problem might be one of the following on the turntable:
1) Tonearm
2) RCA Cables
3) Cartridge
There is no easy way to see which one of these is the culprit, it's just a matter of elimination.
But, you didn't provide much information. If you can be more specific as to how you have your turntable connected, what kind of cartridge your using, and whether or not, you've determined that the problem is indeed the turntable and not your mixer/receiver/amp, or even your speakers. This would help in determining what the issue might be.
- Davis
DJ Pro Audio
www.DJPROAUDIO.com
www.DJPROLAB.com
Jul 16, 2008 | Audio Players & Recorders
Technics Trouble... Please Help
You will have to replace the RCA cables on your turntable. You can try to do this yourself, however soldering experience is required. You can purchase the parts HERE - and install yourself, or try to find a reputable service center area to replace the cables.
A word of advice, try not to use the original RCA cables that are installed with the turntables, as they aren't of the greatest quality. Try and put a better brand, or use the MOGAMI cables, available HERE.
Have fun!
- DJ PRO AUDIO
www.DJPROLAB.com
Mar 20, 2008 | Technics SL-1210 Turntable
Turntable setup into an hp 7590
In theory as long as you have a sound card installed, yes you can connect your turntable direct to your computer simply by connecting it to the audio input.
You will probably need a patch lead with twin line phono connectors on one end and a stereo 3.5mm jack plug on the other end.
Please note, the turntable or phono inputs on amplifiers are unlike all the other inputs, because they have a particular frequency response tailored for use with a headshell cartridge.
If you connect your turntable to an input that has not been tailored to the RIAA response curve, it will sound tinny. This is what probably happens when you connect to your computer. The input may also not be sensitive enough.
You may be able to adjust the frequency response if your sound card includes an equaliser. Alternatively, you may be able to download some audio software that will allow you to equalise your turntable.
All in all though, I'm sorry to say you would be better off with an outboard preamp.
Mar 08, 2008 | Technics SL-1200MK2 Turntable
Static
It's possible that your ground wire or rca cables have shorted out. Also check where the cartridge is installed in the tonearm to see if the 4 contact pads are corroded or pushed back. Make sure the ground wire is screwed firmly into the mixer or receiver. if oyu have tried these options and still get static, replace the tonearm.
www.djproaudio.com
keep me posted
Nov 06, 2007 | Technics SL-1200MK2 Turntable
Open Questions:
Stanton ST-150 Turntable Logo
Top Stanton Audio Players & Recorders Experts
 Grubhead
Grubhead
Michial Gueffroy
Vito Vacirca Jr.
Are you a Stanton Audio Player and Recorder Expert? Answer questions, earn points and help others
