Question about Kohler Home
How do you fix error code 061 - Kohler Home
2 Suggested Answers
Logjam
  • 159 Answers
SOURCE: Error code 061 and the ADF door is closed
In this case make sure that the plastic tab that actuates the sensor is not broken off. If it is, try and find some way to defeat it. Other wise you will have to replace the whole transmit door assembly.
Posted on May 27, 2008
Error 061-321 xerox workcentre 5024 - Xerox Office Equipment & Supplies
061-321 ROS Motor Fail
BSD-ON: CH6.5
The number of rotation of the ROS Motor did not come within the standard range within the specified time (5 s) after the ROS Motor On.
Cause/Action
1. Turn the power OFF and ON.
2. Check whether the Drum Cartridge is installed.
3. Check the ROS Motor (Output Check [061-001]) for operation failure.
4. Check the LD +5VDC power supply of the LD PWB J140 pin-8.
5. If no problem is found, replace the following parts in sequence:
• ROS Assembly (PL 2.1)
• ESS/MCU PWB (PL 18.3)
http://turbobit.net/upqkewkg8xjt.html
Feb 18, 2017 | Xerox Office Equipment & Supplies
Can anyone help me I have problem with code E061 with Toshiba Copier e-studio 850
Please check if your paper orientation and size in the first cassette matches the copier's display settings. If your machine is set to letter size paper, but you have LD in your first cassette you will get e-061
Nov 27, 2011 | Office Equipment & Supplies
Today when I wanted to print something the following problem appeared on my Phaser 6125: Error 061-370 My printer is rather new and has about 2000 copies done. I've turned the printer off, waited a...
An internal error has occurred. Turn the printer off and on. If the problem is still there the laser needs to be replaced. If the machine is less than a year old then the machine will be fixed under warranty.
Mar 04, 2011 | Xerox Phaser 6125 Laser Printer
Keeps giving error code 061
Hello sir; Did you recently replace new toner, if you did, please go back to check out does the door close right, otherwise you have to check the corona wire is broken?
Jan 04, 2010 | Canon CLC-700 Copier
Error code E061 0093
its a problem of dirty primary assembly or the corona and grid wires are dirty or check your front door actuators if the laser window is not open,laser can't reach the drum and will result Error 061 hope this will help
Jun 08, 2009 | Canon CLC 1180 Copier
XEROX PHASER 6180 LASER ERROR 061-370. WHAT IS THIS?
Chain Link 061-370 An error was detected in the Laser Unit.
Initial Actions
? Cycle printer power.
? If the problem persists, follow the procedure below.
Sep 04, 2008 | Xerox Office Equipment & Supplies
Apr 29, 2008 | Panasonic Panafax UF-885 Plain Paper Laser...
Look up error code E00061001 for Canon 5020i
Title : E-061 Error Code Problem :
E-061 code is occurring for the IR5000/6000
Solution :
Check, re-seat or replace the Primary Corona Assembly
Apr 25, 2008 | Canon imageRUNNER 5020i Copier
Home Logo
306 people viewed this question
Top Kohler Home Experts
john h
Tim Whalen
Mike
Are you a Kohler Home Expert? Answer questions, earn points and help others
