Question about D-Link DSL 200 (DSL-200) Modem
We are not able to connect to the wi-fi connection because i had changed the WEP key;it does come but at the end it goes.What do we do to fix it back right again?it tells LINK NOT ACCABLE
    Scholar:
  • 55 Answers
Access the gui of your router. Change the WEP key there then click on save and restart your router. If all the lights are okay. Try to connect to your wireless using the new WEP key you changed.
Posted on Jul 20, 2010
How do I change the security key of a wifi network on my Epson wf3640 printer
Wi-Fi is rapidly replacing wired LAN in homes and offices. This is the reason most high-end printers now come with Wi-Fi built into them. Now you can print documents wirelessly without attaching cables. However, before you print, you need to connect and configure your printer to print over a Wi-Fi connection. In order for the wifi to work, your printer and your computer must connect to the same wifi router or to an access point/repeater/extender connected to the same router.
1. Open Internet Explorer, on the address bar type 192.168.1.1
2. There's no username and type admin on the password. If admin didn't work, use your own password.
3. When you have the Setup Page open, click on Wireless Tab, then click on the sub-tab Wireless Security.
4. There you can see the Security Mode. If the mode is set to WEP, the WEP Key 1 is your wireless key. If the mode is set to the WPA-Personal, the Passphrase or the WPA Shared Key is your wireless key/PIN.try this steps and fix problems let if you have facing this problems call canon printer technical support Experts toll-free number 1-800-213-8289 for get online help. Epson Wireless Printer Support Number 1 800 610 6962 Help
Jun 25, 2017 | Epson Computers & Internet
Tip
How to Connect Wi-Fi Connection
laptop user must know how to set up. to connect toWi-Fi locations. Using Windows XP in this tutorial, we'll go throughthe steps for setting up a laptop to access a Wi-Fi network. Some Wi-Ficards can be set to automatically detect and connect to Wi-Fi networks,though it is still important to know how to manually set up your Wi-Ficard to connect to a wireless network.
  • Before you attempt to use any Wi-Fi network, find out what the SSID, Channel, Mode and WEP keys are. Some Wi-Fi locations do not require a WEP key. Many Wi-Fi providers have this information on their Web site or they'll give you the information when you purchase access.
  • Ensure you have a firewall program installed and running. This will protect your data.
  • Start up your laptop and look for the Wi-Fi network icon in the bottom right of the screen.
  • Click on the Wi-Fi Connection icon on bottom right of screen and you should see a window that indicates connection, strength and duration. Click onthe Properties tab
    This window shows the type of networking card installed. Click on the Wireless Networks tab.
    Once the Wireless Network Connection Properties window is open, you will have two options depending on how you set up your laptop. If you do not see any networks listed in Preferred or Available networks,you will have to manually add the SSID. Click on Add. You will have toenter the SSID and WEP key (if required). Click OK and you should then see the network you just added in the Available Networks box.
    If you see the correct SSID showing in the Available Networks, then youn eed to click on Configure in order to enter the WEP key if that is required.
    In this window, enter the SSID for the Wi-Fi network you want to a ccess. Make sure you do not have CAPS lock or NUM lock while entering the information. If a Network key is required, click on "DataEncryption and then enter the Network key you have been provided with.Again make sure you do not have CAPS or NUM lock on. Click OK when entered. If you have entered the key incorrectly, a message will pop up and you will need to re-enter the key.
    Next go to Start - and where it says Connect To click on that and you should see choices similar to the graphic below. Click on WirelessNetwork Connection and it should work. Potential Problems & Their Solutions:
    Thereare occasions when the connection doesn't work. In these cases check your firewall software and make sure it allows you to connect to the Wi-Fi network. To check this, disable your firewall software and check the connection again. If you can connect with the firewall programd isabled, you will need to change your firewall settings. If your firewall program is not the problem, check the SSID and WEP key information that you entered. Both of these are case sensitive. If you had obtained SSID information from the Internet, check with someone in the establishment to see if the SSID has been changed.
    on Jun 24, 2010 | Computers & Internet
    How to get wi fi on ds lite
    1. Turn on the Nintendo DSi
    2. Click on the wrench icon to access "System Settings."
    3. Select "Internet" on the third page of System Settings.
    4. Select "Connection Settings" and tap the "None" bar in "Connection 1."
    5. You have the option of setting up a connection manually, or searching for available connections in the area. You may also access your Nintendo Wi-Fi USB connector, if you have one (the product has been discontinued). The easiest thing to do is select "Search for an Access Point."
    6. Your Nintendo DSi will list the names of any wireless access points in range. A gold, unlocked icon next to the connection's name signifies an unlocked WEP (Wired Equivalent Privacy) connection that can be accessed immediately. A locked gold icon signifies an encrypted WEP connection that requires a WEP key (password).
    7. If you are accessing a locked/encrypted connection, enter your WEP key. You may also click "Change Security Settings" to enter a WPA (Wi-Fi Protected Access) key.
    8. If your WEP key is correct, your Nintendo DSi should connect. You can test your connection to verify.
    Jul 24, 2011 | Nintendo DS Lite Console
    Can't get my wi-fi connection to work on it
    Here's How:
    9. You're set! Now you can surf the Internet, purchase games and add-ons in the Nintendo DSi Shop, and play games that allow wireless access and competition (with WEP connections, only).
    Jul 21, 2011 | Nintendo DSi XL Burgundy
    Error Code :51100 Nintendo Wi-Fi Connection Setup
    Error Code: 51100
    The WEP key for the Access Point you are attempting to connect to has changed since you last connected.
    What to do:
      • Errors ending in 0 = connection file 1
      • Errors ending in 1 = connection file 2
      • Errors ending in 2 = connection file 3
      • Errors ending in 3 = Nintendo Wi-Fi USB Connector
    • Verify the Access Point's WEP Key is entered correctly into the Nintendo DS. If your router has slots for more than one WEP key, the first (#1) must be the one selected on your router.
      If you have multiple connection files saved to your Nintendo DS, the error message you received can help determine which connection file may be experiencing a problem:
    Jun 01, 2011 | Nintendo DS Lite
    When i try to connect my DSi to my wireless router the same error code keeps showing on the screen. the error code is 051100-1. any ideas?
    That code comes up when the settings for your wireless router have changed since you last connected. Have you tried re-entering your settings? That should fix the problem.
    Apr 30, 2011 | Nintendo DSi White Console
    Can't connect error code 051100-1
    Error Code: 051100The WEP key for the Access Point you are attempting to connect to has changed since you last connected.
    What to do:Verify the Access Point's WEP Key is entered correctly into the Nintendo DS. If your router has slots for more than one WEP key, the first (#1) must be the one selected on your router. If you need assistance, click here and select your router manufacturer and model number. If available, our router pages can provide specific steps and information that may help you with your router's WEP Key.
    Apr 10, 2010 | Nintendo DSi Matte Blue Console
    Error code 051101
    Error Code: 051101 The WEP key for the Access Point you are attempting to connect to has changed since you last connected.
    What to do: Verify the Access Point's WEP Key is entered correctly into the Nintendo DS. If your router has slots for more than one WEP key, the first (#1) must be the one selected on your router. If you need assistance, click here and select your router manufacturer and model number. If available, our router pages can provide specific steps and information that may help you with your router's WEP Key.
    Feb 03, 2010 | Nintendo DSi Black Console
    Canot connect to internet error code 051100-1
    Error Code: 051100 The WEP key for the Access Point you are attempting to connect to has changed since you last connected.
    Feb 02, 2010 | Nintendo DSi Black Console
    Got error code 51100 on nintenfo ds light dont know how to fix it went to support.nintendo.com but they didnt help
    Error Code: 51100 The WEP key for the Access Point you are attempting to connect to has changed since you last connected.
    Nov 07, 2009 | Nintendo Universal WiFi Link for Gameboy...
    D-Link DSL 200 (DSL-200) Modem Logo
    165 people viewed this question
    Top D-Link Computers & Internet Experts
    Prashant M
    Prashant M
    Mike
    Are you a D-Link Computer and Internet Expert? Answer questions, earn points and help others
