Question about Admiral AW22 Top Load Washer
Admiral model #LATA400AAM
Water fills and everything, but won't spin or agitate. Please help! Can't afford a new one. Thanks.
  • Eric4061 Apr 20, 2008
    Do you know where the lid switch is located?
    Genius:
  • 1,073 Answers
Check the lid switch first
Posted on Apr 20, 2008
My washer will not agitate,makes like a little sound.does everything else
check the cam dogs in the agitator, the motor coupler or the belt and the door switch
Sep 30, 2014 | Admiral Washing Machines
Admiral washing machine AAV7000AWW won't stop filling or agitate?
It is either the inlet velve or the cycle programmer faulty
May 24, 2008 | Admiral AAV7000A
Admiral top loader no spin cycle
no i would cheak that switch out that u pushing down on mightbe bad try that 1st ok thx nick
Mar 15, 2008 | Admiral AW22 Top Load Washer
Admiral washer leaking water from bottom
What is the model number of the unit?
Nov 24, 2012 | Admiral Washing Machines
Washing machine won't fill. i filled it by hand with water, it won't agitate either, only spins.
The inlet solenoid is probably bad. And it won't agitate unless it fills and stops filling automatically.
May 17, 2012 | Whirlpool Washing Machines
WASHER FILLS WITH WATER, THEN WON'T AGITATE. TURN KNOB TO SPIN AND IT DRAINS THEN SPINS. STILL WON'T AGITATE
WASHER FILLS WITH WATER, THEN WON'T AGITATE. TURN KNOB TO SPIN AND IT DRAINS THEN SPINS. STILL WON'T AGITATE please show me a diagram
Jun 14, 2011 | Whirlpool LSR7333 Top Load Washer
Washer won't fill. will only agitate or spin
Set the washer to the position where it should be filling up with water. With the solenoid leads unplugged check if its getting 120 volts to it using a voltmeter or a circuit tester. The solenoid I am mentioning about is the one that opens up to let the water into the tub. When 120 volts is applied to it the solenoid opens up the water valve. It is located on the back of the machine. Then we go from there.
May 28, 2011 | Admiral Washing Machines
Possible timer problem, timer reverses motor to agitate this is not hapeniing, check timer or wiring to motor.
Nov 02, 2008 | Admiral AW22 Top Load Washer
Admiral washing maching model aav7000aww
Hello donerehart
You said, water and spin cycles are fine, but won't agitate... what can i do?
Sounds like the timer in the dial will not progress!
Sep 05, 2008 | Admiral AAV7000A
Washer fills, drains instead of agitating, fills, etc
ON THIS MACHINE WHEN IT AGGITATES MOTOR ROTATES ONE DIRECTION, WHEN IT PUMPS OUT AND SPINS IT ROTATES THE OPPOSITE DIRECTION. YOUR MACHINE IS ROTATING THE WRONG DIRECTION WHEN IT FILLS., INDICATING THAT THE TIMER IS SENDING VOLTAGE TO WRONG WIRES. SOLUTION , REPLACE TIMER.
PS: MAKE SURE ALL WIRES ARE PLUGGED IN TO MOTOR. WHILE THIS IS UNLIKELY , I HAVE SEEN THIS BE THE PROBLEM.
FXIT
FXIT
FXIT
Nov 24, 2007 | Admiral AW22 Top Load Washer
Admiral AW22 Top Load Washer Logo
59 people viewed this question
Top Admiral Washing Machines Experts
Dan Webster
Dan Webster
Sal De GO PATS
Are you an Admiral Washing Machine Expert? Answer questions, earn points and help others
